Best Ipod solution?
Discussion in 'Audio & Video' started by garrettc134, Jan 9, 2010.
  1. Jan 9, 2010 at 9:55 AM
    garrettc134
    garrettc134 [OP] Active Member
    So I'm looking for the best way to integrate my iPod into my 05 tacoma. I've seen the PA15-TOY mentioned several times but for 150 stones I might as well buy another head unit with more features right? Another option I am interested in would be a double din dvd player that can connect to the iPod. Only problem with this is my price limit is ~$300 so I have to stay towards the low end. Has anyone had any success with this? I would appreciate pictures because I also want to see how it looks. Thanks in advance for your help.
  2. Jan 9, 2010 at 10:02 AM
    J-Bird
    J-Bird Well-Known Member
    SB, Ca
    09 TRD off-road 4x2 DC
    soon
    so u want to be able to control ur ipod with out actually touching it right? the cheapest and most effective soultion i found is kensington's liquidAUX. Atleast thats wut worked for me. i can play/ pause, skip tracks and it charges my iphone.
    anyways my fav without having to modify anything.
  3. Jan 9, 2010 at 2:26 PM
    garrettc134
    Those sound like good solutions but are they better than getting a new unit for $150 with bluetooth, usb reader, hd radio and some other goodies?
  4. Jan 9, 2010 at 2:38 PM
    05TRD4WD
    05TRD4WD Well-Known Member
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    ; 17 x 9 xd revolvers wrapped in 295/70-R17, volant cold air intake, Gibson exhaust, BHLM, Yellow fog covers, access rollup tonneau, kenwood dnx-9960, all jl audio, jl stealth box, 900/5 amp, Fab Tech 6" lift
    i had an isimple fm transmitter for my ipod and was installed and worked well
    i took it out because i got a new headunit for christmas.
    and now im lookin to sell it
  5. Jan 9, 2010 at 2:45 PM
    garrettc134
    sorry but I absolutely hate fm transmitters and so that's not even an option
  6. Jan 9, 2010 at 3:08 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    There are actually new FM transmitters that are actually hard wired. I was looking at buying one for my girlfriends Acura MDX. You unplug the FM antenna wire from the back of your radio, plug the FM antennae wire into the interface unit, then plug the interface unit into the FM antennae jack on the factory radio. It eliminates any of the static and interference you would get from a traditional FM modulator and gives you great sound quality. They range between $80-$150.
    Personally I would buy an aftermarket headunit. Especially if you plan on upgrading your stock speakers or adding a sub in the future.
  7. Jan 9, 2010 at 5:46 PM
    ekard
    ekard Well-Known Member
    San Jose, CA
    2011 DC SB 4X4 OR
    TRD Exhaust, Bilstein 5100's, Eibach coils, TSB Leaf pack, Toyota Bed Mat and D-Rings, Dakine Tailgate Pad, Wet Okoles, WeatherTech Floormats, PA15-TOY iPod Adapter, Goodyear Duratracs 265/75/16, SCS F5 wheels
    If it's hardwired, it's not an FM transmitter. It's just a line-in that uses the FM jack.
    I'm debating the same thing. $150 for an adapter or just wait and save for a full deck. I'm just not super excited about loosing the bluetooth and steering buttons of the stock JBL system. So if I do change decks, then I still need adapters of some sort...
  8. Jan 9, 2010 at 6:48 PM
    Yeahbabytr6
    Yeahbabytr6 Member
    The Couve
    Stocker
    I installed the Harmon/Kardon Drive-n-Play system in mine. It can be used as a FM tunable or a input jack device. Cool little controller which can be mounted almost anywhere. I mounted the display up next to the rearview mirror. The pod is in the passenger glovebox out of sight.
  9. Jan 9, 2010 at 6:53 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    I think the Grom V2 something something may be what your looking for. There is a write up on it, but I think the OP used the V1 (the OP also sold it, I was asking in that thread a while back).
    http://www.tacomaworld.com/forum/audio-video/44735-grom-usb-adapter-installation-pics.html
    I went to the links for the Grom that whippersnapper02 posted and found this one, which is what i was talking about:
    http://www.gromaudio.com/store/ipod_adapters/grom-i2-toy.html
    I may be getting this sometime soon, or my little cousin may (when he gets his sorry ass back to CA, damn vegas.. n.m).
  10. Jan 10, 2010 at 6:51 AM
    soilsample
    soilsample Well-Known Member
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    So can anyone tell me if the Grom interface will allow for full volume?
    The setup that I have now has REALLY POOR volume. I have to play at "Max level" to get it loud enough to barely get any decent sound.
    I'd say that my setup puts out about 1/2 the volume of using the aux jack.
  11. Jan 10, 2010 at 6:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    PA-15 TOY!!
    Yeah, Its a bit pricey, you can find them for $120.00 or so. But they are WELL worth it. I love mine.
  12. Jan 10, 2010 at 7:04 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    For the price, you'll get more bang for your buck with a new HU, and it will sound a thousand times better. The stock radios suck.
  13. Jan 10, 2010 at 7:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I really dont think mine sounds bad. For an OEM radio, I think it sounds pretty good actually. :eek:
  14. Jan 10, 2010 at 11:26 AM
    garrettc134
    Whats the best HU for looks and for integrating the iPod?
  15. Jan 10, 2010 at 3:21 PM
    07TacoRidah
    "Integrate your iPod into car audio system easily
    Get CD quality sound from the iPod through existing car stereo
    Control and operate your iPod with car stereo buttons or steering wheel controls
    Convert iPod into virtual CD changer
    Disk 1 allow to control iPod from its clicking wheel. Select your music from iPod and have it played. Stereo will control iPod
    Disk 2-6 mapped to playlists you create on iPod. Full control from car stereo. The following information is displayed: Disk #, Track #, time etc
    MIX, REPEAT work as usual
    SCAN allow to skip +-10 tracks for faster navigation
    Playlist positions are preserved for fast operation
    Shuffle songs, switch between tracks, playlists and adjust volume - all by using head unit controls
    Have your iPod charged"
    the one before this didn't let you do that. I have the same adapter that you have and it SUCKS!!!! It an upgrade I think, my taco came with it, but man I wish I would have just gotten a headphone jack connection instead.
  16. Jan 12, 2010 at 7:22 PM
    garrettc134
    No cheap dvd player recomendations?
  17. Jan 13, 2010 at 3:23 PM
    garrettc134
    Does anyone have any picutres of the Jensen VM8023HD in their taco?
  18. Jan 13, 2010 at 3:32 PM
    BAP_29
    BAP_29 Well-Known Member
    Ben
    North Carolina
    05 Prerunner DC TRD Sport
    Bilstein 5100s at 2.5" and Toytec 1.5" AAL Eagle Alloy 063 Wheels on 285/60/18 Cooper Zeon LTZ tires Alpine iDA-X305 Head Unit MB Quart DKD 116 Discus-Line 6.5" Front Speakers (Baffles by Marv) Alpine 6-Disk CD Changer Toyota All-Weather Floor Mats Kobalt Low-Profile Toolbox 13" Wicked Flow Muffler w/ Chrome Tip
    I have the Alpine iDa-X305alpinered_d39f8d95f5ffd6a4489197092e36a7d21f5731b4.jpg
    The wheel in the middle controls the radio and iPod just as you were using an iPod itself. It looks great and has a full color screen. The wire you see there is because i hadnt strung it through to my glove box yet. But i love this HU. I think its a great option if you want to play your iPod in the truck
  19. Jan 13, 2010 at 3:55 PM
    garrettc134
    I liked that one except for the fact it didn't have an front aux port
  20. Jan 13, 2010 at 3:57 PM
    BAP_29
    Ben
    North Carolina
    why do you want the front aux port?
