Best keyless entry option for non power door locks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, May 18, 2010.
  1. May 18, 2010 at 11:43 AM
    Vrbas
    Vrbas [OP] Well-Known Member
    I didn't know where to post this thread so i just came here.
    I'm looking at a Tacoma that does not come standard with power door locks. Everything else about the car is fine and i really like it save this feature. Is there an easy way to "add" power door locks or at least a keyless entry without getting too messy?
  2. May 18, 2010 at 11:45 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    coathanger??:notsure:
  3. May 18, 2010 at 11:48 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
  4. May 18, 2010 at 12:11 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    You need a keyless entry/alarm. To lock/unlock, you will need actuators. They are $20/each at Best Buy. Best Buy charges an additional $60 per actuator to install.
