Best Leaf Springs for 1st Gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldtaco1, Mar 28, 2025.
  1. Mar 28, 2025 at 9:55 AM
    goldtaco1
    goldtaco1 [OP] Member
    Zach
    2001 Tacoma, 4x4
    I know this has been debated on the forums time and time again but I want help getting to a definitive answer.
    I have a full fox shocks setup front and back but am running stock leaf's. My topper is roughly 225 lbs. and I'm sick of sag.
    I don't want to do fab work to install the chevy springs that people love because I'm not off-roading this truck much so my choices are the heavy duty leaf's by American Springs or Old Man Emu's. I have never heard anyone talk about the heavy duty American Springs Leaf's and people say that old man emus still have sag. Deaver's are a out of my price range. I plan on getting the greaseable shackles with the leaf's as well.
    What have leaf's have been the best for you?
  2. Mar 28, 2025 at 10:11 AM
    eon_blue
    Azusa, CA
    Custom set from Alcan. Went through 2 Old Man Emu setups and a set of All Pro Expos previously. Finally caved and put down the extra money for a custom set with Alcan - they work with you either over email or by phone to determine what you need and then build them for you. That was 5 years ago for me and I've never looked back, worth every penny.
    Deaver is another one that will custom make you a set. If you have an old school spring shop in town they probably would, too.
  3. Mar 28, 2025 at 11:11 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    "Best" is subjective and depends on application. Here's a list of what's generally considered the "right" springs for various applications. For each option noted below, there are a couple different products you can use, as outlined in the guide.
    Sounds to me like you're in the "Option 2" range, from your description.
    Replacing Leaf Springs on a Tacoma – AdventureTaco
    Option 1: Stock Replacement
    This is a good option if all you want to do if you use your truck as it was originally intended from Toyota and are happy with the performance. Likely, you are replacing the leaf springs because - over the last couple of decades - you've simply worn out your existing springs and they are now sagging. Replacing them with a stock replacement will mean that you maintain the relatively soft ride of a stock Tacoma, can carry moderately heavy loads rarely, and are not looking for additional lift (beyond lifting the truck back to its original height - which may be 2-3" higher than where it sits with worn leaf springs).
    Option 2: 0-3" Lift with Small-to-Moderate Intermittent Load
    This is a good option if you still want to use your Tacoma as a daily driver - sometimes with moderate loads in the bed; sometimes empty - while also adding a few inches of lift and the ability to carry heavier loads (up to 350+ lbs) on a relatively infrequent basis, for reasonably short periods of time.
    Option 3: Custom Lift with Heavy Constant Load
    This is a good option if you are constantly carrying heavy loads (600+ lbs) over all types of terrain, and rarely using your Tacoma as a daily driver. Generally, a 2-4" lift while carrying heavy loads will also be incorporated. The ride with an empty bed will be extremely rough, and the lift may increase beyond even 4". This is by far the most expensive option, but also allows for complete customization of the performance characteristics of the leaf pack.
    Option 4: Custom Lift with Heavy Constant Load and High Performance
    Ready to do some fab work?
    Black97v6MT likes this.
  4. Mar 28, 2025 at 11:32 AM
    02hilux
    Planet: EARTH
    Alcan FTW but will be out of your budget if you’re saying Deaver is
    LOLLY and Wulf like this.
  5. Mar 28, 2025 at 11:46 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    You should change the title to "Best Leaf Springs for 1st Gen Under $700".
    Wulf and time623 like this.
  6. Mar 29, 2025 at 8:09 PM
    LightsOff
    LightsOff Well-Known Member
    2000 SR5, V6 4WD
  7. Apr 16, 2025 at 10:28 PM
    goldtaco1
    Zach
    2001 Tacoma, 4x4
    that was a ton of help! decided I'll go with some dakars when it makes sense
  8. Apr 18, 2025 at 10:16 PM
    Pithy
    Pithy Well-Known Member
    Christopher
    Idaho Springs, CO
    2004 3.4L V6 4x4 SR5 Double Cab Impulse Red
    Over the holidays there was a deal at Wheeler’s for the All Pro leaf springs and rear shock bundle. I bought the Expedition since I want to add weight and still have a good lift. Haven’t put them on yet so I have nothing to say about them. Price was decent and I read good things in my heavy research.
