Best leveling kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rwood, Aug 11, 2023.
  1. Aug 11, 2023 at 2:11 AM
    Rwood
    Rwood [OP] Well-Known Member
    Raymond
    WNC
    15 TRD Off-road
    I have a 22 limited and want to level it and am thinking about going with the eibach pro lift stage 2R, or bilstein 6112’s and 5100’s. Maybe going with UCA cause I would like to go to a 285 tire. Just not sure what kit to go with. Could go with something else just don’t want to get into spending more than $3000 on lift. All help is appreciated. Thanks I’m advance. Also right now but at sometime I want to add a RTT.
  2. Aug 11, 2023 at 5:47 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    You definitely don’t want to be leveled if you plan on adding weight to bed etc. Just saying.
  3. Aug 11, 2023 at 8:26 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    1" 5100s up front will level your truck. Boom yer done.
    If you ever get around to adding an RTT, then work on the back suspension... And you could still lift your front another 1" if you want to...
    Junkhead, 71tattooguy and Burns like this.
  4. Aug 11, 2023 at 8:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    Leveling is for lookers.
    Rake is for users.
  5. Aug 11, 2023 at 8:50 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :amen:
    gilligoon, 71tattooguy and Chew like this.
  6. Aug 11, 2023 at 8:52 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    correct
    nobody wants to be sqautin' with anything more than groceries in the bed
    Stevie17, Junkhead and 71tattooguy like this.
  7. Aug 11, 2023 at 10:34 AM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    Put some weight in the bed boom leveled for free.
    But as stated if you intend on doing any truck stuff leveling is terrible. They should level out when loaded. Otherwise you get all kinds of light float feelings in your steering.
    gilligoon, Chew and Junkhead like this.
  8. Aug 11, 2023 at 10:41 AM
    spicy_fish_taco
    spicy_fish_taco Well-Known Member
    '18 2.7L Taco 4x4 Access Cab
    leveling a truck is the best way to say "i dont need a truck but im getting one anyway" congrats!:thumbsup:
    gilligoon, BmTaco91 and Junkhead like this.
  9. Aug 11, 2023 at 10:53 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Well, OP sure got his answers.:oops:
    I do agree with others though, “leveling” a truck makes absolutely no sense whatsoever. To me it doesn’t even look good.
    Chew likes this.
  10. Aug 11, 2023 at 10:54 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    He prolly has a few bags of groceries in the back there.
  11. Aug 11, 2023 at 2:27 PM
    Rwood
    Raymond
    WNC
    15 TRD Off-road
    So what would be the best way to do it? To be able to fit 285’s
  12. Aug 11, 2023 at 2:38 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
  13. Aug 11, 2023 at 2:49 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Lift doesn’t help clear larger/wider tires on Toyota IFS. You can fit 285s on stock suspension with right offset and caster alignment.
    Can always go with 33x10 255/80/17 or 255/85/16. Fits very easy even with stock mudflaps.
  14. Aug 11, 2023 at 2:53 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    265/75r16s unless you want to rub and/or cut. They will look plenty big.
  15. Aug 11, 2023 at 2:55 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Negative sir.
    275/70/17
    255/80/17
    255/85/16
    285/70/17
    285/75/16
    235/85/16
    Will all fit on stock suspension without cutting with right offset and/or alignment.
  16. Aug 11, 2023 at 3:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    The wheel specs matter more than lift.
    If you're interest is in the 33" diameter more than the 285 width, that can be accomplished with 255 85 16 or 255 80 17 with no modifications to the truck on OE wheels or wheels with OE specs.
    If the 285 is your need, on OE wheels, 'some' folks have some rubbing in certain spots in certain conditions.
    Bigger tires cost more, are heavier and will often ride worse. If more tire is what you need for how you drive, that's one thing. But if your driving requirements just require a better-than-stock tire, that can be done with many selections, and even have a slight + size over stock.
    You choose as you wish. A few of us just want you to know there are alternatives to the cookie cutter level/wheel/tire choices that many make.
    71tattooguy and Junkhead like this.
  17. Aug 11, 2023 at 3:26 PM
    Rwood
    Raymond
    WNC
    15 TRD Off-road
    Ok great thanks everyone I appreciate the help
    Junkhead likes this.
  18. Aug 11, 2023 at 4:34 PM
    gilligoon
    Goon
    Watoosa Ridge, GA
    "with right offset and/or alignment" = WON'T FIT.
    Definitely won't fit with mud flaps. Probably won't fit if you ever need to do a 3 point turn on a tight road with a ditch and side hill.
    Pushing tire size beyond the practical limit is a tuner bro level mistake. Why?
    255/85/16 gets a pass... definitely useful/practical.
  19. Aug 11, 2023 at 5:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    There are quite a few dudes that run 285s on stock suspension. Negative offset is the enemy.
    My 255s clear with stock mudflaps at full
    Stuff, stock alignment.
    71tattooguy likes this.
