best leveling kits
Discussion in '3rd Gen. Tacomas (2016-2023)' started by metsfan6734, Feb 19, 2018.
  1. Feb 19, 2018 at 9:52 AM
    metsfan6734
    metsfan6734 [OP] Well-Known Member
    Eric
    Upstate NY
    2017 MGM TRD Off-Road DCSB
    Looking for the best leveling kit under 200$ I want 2" in the front and probably stick with a 2" block in the back. What are your thoughts?
  2. Feb 19, 2018 at 9:55 AM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Id just do bilstein 5100’s front nothing in rear for about 1.5” lift up front. Could go 1” block in rear if they make them or a single add a leaf. Blocks and spacers get alot of nasty ocmments on here. You want about an 3/4” to inch difference for level
    Bilsteins are 120$ for a set Use stock springs.You will probsbly wanna move this to the suspension tread in forum if you can
  3. Feb 19, 2018 at 9:56 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Don't get blocks or spacers. My .02
    offthewallsurfer and Hank Heel like this.
  4. Feb 19, 2018 at 9:59 AM
    offthewallsurfer
    offthewallsurfer Well-Known Member
    ZekeH20, Hank Heel and Friedtacolover like this.
  5. Feb 19, 2018 at 10:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    All you're doing here is raising it the same F/R and the rake stays the same. Not 'leveling'.
    Leveling is a looks only thing, removing rake that's engineered into vehicles for a purpose.
    With the right tires and decent driving skills these trucks are quite capable. So my thought is wait until you find you need a lift of some type to help off road performance, then do it with quality bits.
    Friedtacolover likes this.
