best lift for and tires for highway truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patdeal, Sep 17, 2013.
  1. Sep 17, 2013 at 6:35 AM
    patdeal
    patdeal [OP] Member
    concordia ks
    2010 dbl cad tacoma sport
    I have a 2010 tacoma that I put a lot of highway miles on every year. I want to put a lift and more aggressive tires for a better look. what would be my best option?
  2. Sep 17, 2013 at 6:44 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    how big of a lift? i have BFG AT's for tires on my truck and they're pretty smooth and i have the white lettering out so it looks cool to me atleast
  3. Sep 17, 2013 at 6:49 AM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    x2 with BFG ATs. Get billies 5100s up front and AAL. If you won't be seriously going offroad, I would just level it.
  4. Sep 17, 2013 at 6:50 AM
    patdeal
    patdeal [OP] Member
    concordia ks
    I think like a 3 inch lift. I want the biggest tires that will not rub also. I plan on getting new wheels also.
  5. Sep 17, 2013 at 6:51 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    BFG's wear well for strict highway use and look good. lots of lift options! Give yourself some time on this site before you make up your mind. Lots of info and it takes a while to go through. Good luck and welcome to TW!!
  6. Sep 17, 2013 at 6:52 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    5100's up front and either the Wheeler's or Icon 3-leaf progressive AAL for the rear. For tires, I'd check out the Michelin AT2 or Perelli Scorpion for a highway truck. If you want something that looks more aggressive, check out the Hankook Dynapro or Toyo Open Country A/T. I would not run BFG's on a pavement pounder, they can get noisy with age and usually have a higher load range that you'd need just for highway runs.
  7. Sep 17, 2013 at 6:53 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    x2 this is what i did except i got the 884 OME coils too for the full 3" lift and my truck is pretty smooth because the 884 coils are the lighter ones and its alot less bouncy then stock. im pretty sure you can run like 33's but im running 31's (265/75/16) on my truck. i would call wheelersoffroad or toytec because they can get you in the right direction. i heard wheelers has excellent customer service and i went with toytec who also has excellent customer service and answered all my questions for me and helped me pick a lift that was good for me
  8. Sep 17, 2013 at 6:56 AM
    Pugga
    Massachusetts
    884's are the 'lighter' coils compared to what? Generally, for a V6 couble cab, 884's won't get you 3" of lift, you'd want 885's for that.
  9. Sep 17, 2013 at 7:02 AM
    ToyotaKTMracing
    Shay
    West Virginia
    Yeah.. I'd probably get 885s. I have 885s and my billies on the highest setting and I have 3" of lift in the front and 4" in the back. I might lower it to 2 in the front and 3 in the back. I have 1" blocks on the back with my aal so I could just remove the blocks. Only because I like the stuffed tires look.
  10. Sep 17, 2013 at 7:03 AM
    Large
    Large Red
    A lot of highway miles, are you concerned with MPG? If so I'd skip the lift altogether.
  11. Sep 17, 2013 at 7:16 AM
    patdeal
    patdeal [OP] Member
    concordia ks
    Not really concerned about mpg. I only get about 18 on the highway anyway. What type of mpg will I get wwith the lift and bigger tires.
  12. Sep 17, 2013 at 7:18 AM
    Pugga
    Massachusetts
    Depends on what you put on for a lift and tires. I have a 2" lift all around and still running H/T tires and I can still push 20 MPG. I was still in the 18 - 19 MPG range with the lift and P265/70R17 Cooper AT3 tires. Heavier tires can compromise MPGs as can wider tires.
  13. Sep 17, 2013 at 8:53 AM
    patdeal
    patdeal [OP] Member
    concordia ks
    Can u post a pic of your truck
  14. Sep 17, 2013 at 9:05 AM
    Pugga
    Massachusetts
    2" lift with 265/70R17 tires. That pic was from last year, I've since gone back to stock 265/65R17 H/T tires but kept the lift. I'm running Eibach coils on 5100's set at 0 up front and the Icon 3-leaf AAL with the overload leaf left in place mated with TSB springs for the rear.
    Another options for a 2" lift would be the Ironman kit.
  15. Sep 17, 2013 at 1:06 PM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    I don't offroad but I do have billies 5100's in all four corners with BFG AT tires at factory level. You can't go wrong with the BFG AT tires For highway driving, I highly recommend. Good luck and welcome to Tacoma world.
  16. Sep 17, 2013 at 1:29 PM
    T1no33
    T1no33 Well-Known Member
    Spring Hill, Fl
    2012 PreRunner V6 SR5
    - Partial Badge Removal & Dipped - Removed Mud Flaps - Blacked out Emblem - Blacked out Chrome Surrounding Grill - Salex Center Console Organizer - AntennaX 13" - Tinted Front Windshield - Derped Tacoma Emblems - Bridgestone 265/70/16 tires - Tuff AT Wheels - 3 and 1 spacer block lift (mistake big time) - Black Rear Bumper - Aries Bull Bar w/light rig
    I put 265/70/16 Bridgestone AT Duellers on my truck and they do really well on the highway. We get a ton of rain down here and they go right through it with no issues. If you want a more aggressive look I'd say get bigger tires in the 285/75 range. Before adding my 3" body lift and tires I got around 20mpg hwy. I'm down to around 16-17 now even with careful driving. This is my daily driver (35 miles on way to the office) and I do some light off road driving. Good luck in your search and use the heck out of the forum here. Its been very helpful for me over the last year.
  17. Sep 20, 2013 at 1:24 AM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Rear TSB, Billys at .85, 265/75 Duratracs
    about 2 inches of lift with tires, no difference in handling
    Was pulled over for doing 80mph in a 65 on last trip to OK.
    Trooper Friendly was nice and just gave me a warning !!!!
