Best lift for ride comfort
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andytaco2004, Mar 13, 2017.
  1. Mar 14, 2017 at 11:51 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Or portal axles :wink:
  2. Mar 14, 2017 at 11:52 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Since you're 2wd OP, you could look into spindle lifts as well.
  3. Mar 14, 2017 at 12:20 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    @Andytaco2004 I just responded to your PM. :)
    DustStorm4x4 likes this.
  4. Mar 16, 2017 at 3:51 AM
    Dannny boy
    Dannny boy Stab it and Steer
    AZ
    2002 loaded salvage, and a brand newly aquired 2000
    grey wire, buzzer yank, last click defrost, tack welded column, deckplate, intake silencer delete, led map/red overhead, led backups, underhood dual battery, onboard air, CS-144 big fucking alternator, big fucking alternator wiring, overhead rifle rack, airbag pistol safe, cab to camper 12 volt evap cooler, bug screen cab windows, onboard shower, solar panel and beer fridge!
    Cut out the fenders and stuff some 35's in there with no lift!
    - whatever rubs just cut it or hammer it out of the way. The only lift you get is from increased tire size when you look at the lowest thing on the vehicle - rear diff. Weld up a belly pan and skids for everything underneath. If you do lift it go like 1.5, 2 inches max with some 5100's not those dumb coil spacers. See if you can get it aligned. Then go buy the stiffest highest add a leafs you can find for the back.
