Best lift for the $$ (brand)
Discussion in 'Suspension' started by Atreuh2, Mar 29, 2017.
  1. Mar 29, 2017 at 8:38 AM
    Atreuh2
    Atreuh2 [OP] Member
    Nic
    2005 Toyota Tacoma
    '08 engine swap Injen cold air intake Exedy race clutch
    I'm searching for a 2 - 3" lift for my 05 Tacoma, but everything seems the same except for a different brand name. I've been all over and I want to get some input on which brands you guys like best, which ones last for the price and which ones I don't have to spend my entire life savings on and still get a fair lift and ride.
    YotaDan likes this.
  2. Mar 29, 2017 at 8:41 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Old Man Emu for the best all around. That is if you want a quality product for a decent price.
    Atreuh2[OP] and YotaDan like this.
  3. Mar 29, 2017 at 8:42 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    King is ,well King!
    DustStorm4x4, Atreuh2[OP] and YotaDan like this.
  4. Mar 29, 2017 at 10:02 AM
    '14RC
    '14RC WA State
    Seattle
    2014 4x4 Regular Cab 5MT
    2" Lift & 32" tires w/ Camping Setup (see details) Suspension: Dobinson 2" Coils (PN: C59-316) 4x Bilstein 5100's (base setting) SPC Upper Control Arms Deaver J66 Leaf Springs Ride-Rite Airbags Archive Garage Hammer Hangers Poly Leaf Spring Bushing Camping: SnugTop Canopy ARB awning Built a Camping Shelf in the Bed Yakima Mega Warrior Roof Basket Interior: Bucket Seat Conversion Acoustically Insulated Interior Added Cruise Control Rear Storage Organizers Traction: Yellow Wire Mod Alloy's with 265/75/16 Towing: Aftermarket Class III Tow Hitch Trailer Wiring Brake Controller (wired, not installed) Misc: ECGS Bearing NH Oil Undercoating
    Atreuh,
    I went with Bilstein 5100 Shocks up front set at 1.75" of lift with my stock coils.
    For the rear I bought a Wheelers 3-leaf pack and added it to the rear springs. To take advantage of a little extra travel in the rear I used OME N182 shocks.
    This gave me about 2" lift and it's been totally fine for wheeling. On road it is a little stiff over bumps , but some people remove their sway bar to relieve that ( and gain travel).
    I didn't have to extend brake lines and I didn't have any vibrations after doing the lift, which you'll find is what lots of folks say are after effects of going with over 2" lift.
  5. Mar 29, 2017 at 10:30 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Most all the options out there are good options, with some variances in ride characteristics. Not sure what the budget is you're working but if you are open to suggestions I would start with looking at the New Eibach Pro-Truck Shocks with some OME 2885 coils up front and if your stock leaf springs are in good shape, our 3 Leaf Progressive Add-a-leaf kit out back.
  6. Mar 29, 2017 at 10:56 AM
    Atreuh2
    Atreuh2 [OP] Member
    Nic
    2005 Toyota Tacoma
    Ok I'm open to these, i like the add-a-leaf idea but I believe mine need to be replaced, my year was one included in a leaf spring recall but I haven't done anything about it yet, mainly because I don't see any apparent signs of damage or ware. But a replacement would give me more peace of mind when I'm climbing the hills. My price range is roughly $500-1k. Still open to all ideas! Thanks a lot guys!
  7. Mar 29, 2017 at 11:35 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    That price range is going to limit your options severely. Plus unless you plan on doing the install yourself, you still have to pay for the install, then an alignment, and probably bigger tires.
    Better to exercise patience and save up a bit until you can afford what you really want/need. Ask anyone whose purchased 2+ suspensions on here. :D
    Atreuh2[QUOTED][OP] likes this.
  8. Mar 29, 2017 at 11:53 AM
    Atreuh2
    Atreuh2 [OP] Member
    Nic
    2005 Toyota Tacoma
    Thanks boogie. I like that advice, I have bigger tires already and they rub slightly if I turn the wheel all the way so I avoid that as much as possible! What brand would you recommend for a 2" kit?
  9. Mar 29, 2017 at 11:56 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Depends on what kind of off-roading you will be doing. This Saturday I'm actually installing my lift: Bilstein 5100s (set at 0) + OME 887 coils + Light Racing UCAs up front ....OME Dakars + Extended travel 5100s in the rear. With the strut assembly and extended rear brake lines, that ran me $1600 through Headstrong Offroad.
  10. Mar 29, 2017 at 11:58 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    First off, see if you can get your leafs replaced for free. If so, do it. Then get this kit which will get you ~2.5" of lift.
    http://www.headstrongoffroad.com/store/p440/Coil/Bilstein_5100_Kit_-_(HS05BK-1).html
    If you're an access cab, get 2884 coils. If you're a double cab, get 2885 coils. No UCAs and yes to strut assembly since your truck is older and it wouldn't be a bad idea to replace your tophats. For the rear lift, the deaver AAL is cheaper, but the 3 leaf AAL will ride better. That's your call.
    I had this kit and it rode great! Pretty close to stock actually.
    Atreuh2[OP] likes this.
  11. Mar 29, 2017 at 7:48 PM
    Atreuh2
    Atreuh2 [OP] Member
    Nic
    2005 Toyota Tacoma
    Hell yea thanks dudes! $1600 isn't bad so I'm sure I'll land somewhere between 10 and 16! Thanks a lot guys
  12. Mar 30, 2017 at 6:43 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Toytec Boss 2.0
