Best lift kit for Prerunner
Discussion in 'ToyTec Lifts' started by abcdleines, Aug 14, 2012.
  1. Aug 14, 2012 at 10:59 AM
    abcdleines
    abcdleines [OP] Well-Known Member
    Brett
    Portland, Oregon
    2012 Prerunner SR5
    Super White, Two tone black and grey leather, AVS hood protector, AVS in channel window visors. Leer 180 cap. New TRD exhaust, TRD 17" wheels.
    Have a 2012 DCSB Prerunner with a Leer 180. Need to lift her up a little. Not so much for off roading, though I will take her on fire roads to do a little target practicing, but for easier access into the cab. I'm 6'3" , 280#. Once in, I am very comfortable. So after reading post after post after post, I'm still confused. Here is what I would like for my truck. 2 to 3 in lift, little better ride quality and NOT having to change out uppers and lowers. Last question, will I need to get a wheel alignment when all is said and done. Please remember this is for a PRERUNNER not a 4WD. Thanks all, love my truck and this forum. Brett
  2. Aug 14, 2012 at 11:03 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Look into getting the OME 3" lift from Toytec without the top plate spacers.. You will get about 2.5" of lift out of the struts and clear 285s. But what size tire do you want to run? If you are on a budget, get 5100s and adjust them to the 2.5 setting and get A AAL.
  3. Aug 14, 2012 at 11:06 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If you want to avoid replacing UCA's, then I'd stay a lot closer to 2".
    5100's with either Eibach coils, OME 883 coils or OME 884 coils for the front and Icon or Wheeler's 3-leaf AAL for the rear. Eibachs will give you 1.5" of lift with 5100's at 0 or 2.5" with 5100's at .85 (maybe a bit more because you're a Prerunner). 883's will give you around 1.5", 884's will give you about 2". Personally, I'd go with the 884's. I've got the Eibachs now and would rather have the OME coils.
  4. Aug 14, 2012 at 11:12 AM
    abcdleines
    Brett
    Portland, Oregon
    2012 Prerunner SR5
    Going to stay with the stock 16 for now, after the tread is gone I will probably go to a larger tire.
