Best lift kit height and tire size for daily driver
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jmbg, Mar 15, 2024.
  1. Apr 27, 2024 at 7:29 PM
    #41
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    If it’s a daily driver think very hard about keeping it stock. Maybe -maybe- go to 255/75r17 tires. That’s it.
    davidstacoma likes this.
  2. Jun 28, 2024 at 7:23 AM
    #42
    MWS
    MWS Member
    mark
    TRD Sport 2022
    For those that did Bilsteins with an AAl, did you replace the needle bearing? I plan on doing this lift and am not sure if I should just get the needle bearing done at the same time.
  3. Jun 28, 2024 at 7:29 AM
    #43
    Cmixgo
    Cmixgo Well-Known Member
    2022 SR 4x4 Double Cab
    I did not replace the needle bearing and have no vibrations after over 5000 miles. I’ll replace it if I need to, but haven’t had the need yet.
    MWS[QUOTED] likes this.
  4. Jun 28, 2024 at 7:32 AM
    #44
    MWS
    MWS Member
    mark
    TRD Sport 2022
    Thank you. I want the same look that your truck has, it looks great.
  5. Jun 28, 2024 at 7:34 AM
    #45
    Cmixgo
    Thanks!
  6. Jun 29, 2024 at 9:18 AM
    #46
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    Same here
