Best Lift Kit (Ride Quality)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foxyfabio808, Nov 22, 2015.
  1. Nov 22, 2015 at 1:55 PM
    foxyfabio808
    foxyfabio808 [OP] Member
    I've been a lurker here for a while now, and the one thing that almost everyone on this site agrees on is that spacer lifts are bad.
    I'm pretty new to this so bear with me...
    I have a 2012 Tacoma Access Cab with a Toytec 3 inch spacer lift (the spacer is at the top of the spring if that matters). The ride quality is garbage when i'm going over 40 mph, and i'm worried that I could ruin my suspension if I don't change it.
    What kind of lift should I switch to that gives the best ride comfort. I don't off road at all, and I would like to spend around $500.
    Or is there anything I can do with the current spacer lift I have to make my ride better and keep my suspension from falling apart?
  2. Nov 22, 2015 at 2:58 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Are you running your stock shocks?
    $500 isn't going to get you far, but I'm guessing your alignment is suffering at 3" on stock control arms.
    What exactly is going on with the ride after 40mph? Wandering? Skittish steering?
  3. Nov 22, 2015 at 2:59 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  4. Nov 22, 2015 at 4:31 PM
    foxyfabio808
    A little bit of wandering. But it feels like I can feel every bump and pebble on the road.
    http://toyteclifts.3dcartstores.com/OME-Tacoma-Suspension-lift-kit_p_231.html
    I was looking at this kit. Would this fix the ride problem and still give me 3 inches of lift?
  5. Nov 22, 2015 at 4:37 PM
    Justinlhc
    At 3" of lift your highway speed driving is going to be less than desirable if you are using stock upper control arms. I think you would benefit more from a set of SPC control arms and a good alignment.
  6. Nov 22, 2015 at 4:38 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes don't get Camburg's as I just did because at 3 inches you will not get the alignment how you want it.
    Justinlhc[QUOTED] likes this.
  7. Nov 22, 2015 at 4:43 PM
    foxyfabio808
    Could you recommend any specific products?
    And would the SPC control arms increase the longevity of the rest of truck?
  8. Nov 22, 2015 at 4:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you NEED 3" of lift for some functional reason, then you probably need to save more money for proper components.
    If you are only into 3" for looks, and aren't willing to spend a lot, you might want to consider less of a lift.
    Every choice made is a compromise of some other feature or function. Including the wallet. ;)
