Best Lift Shocks?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03tacoma4x4, Sep 26, 2016.
  1. Sep 26, 2016 at 8:54 PM
    03tacoma4x4
    03tacoma4x4 [OP] Well-Known Member
    Western NC
    2002 Silver Tacoma TRD V6 4x4
    2016 Tacoma Wheels
    I have an 02 extended cab v6 4x4 that I was getting ready to lift with a set of Bilstein 5100 shocks. However I just saw a post on here where multiple and I mean multiple people have had problems with the 5100's leaking fairly soon after they had them put on. This kind of makes me leery of taking the 5100 path. So, does anyone else have a recommendation as to what other brand of Lift shock to go with? Ideally I'm wanting to stay stock in the rear end (with new shocks) and give the front around 1.5 inches. Any advice/recommendation is appreciated.
  2. Sep 26, 2016 at 9:22 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Ome suspension is a tried and true good option .
    Wulf and geekhouse23 like this.
  3. Sep 26, 2016 at 9:29 PM
    Medina33
    Medina33 Well-Known Member
    Erik
    Lax
    2010 dcsb 4x4
    I had fox 2.0s you can pick them up at 4wp for 400$-450 each. I loved them!
  4. Sep 26, 2016 at 9:31 PM
    Midnighttaco08
    Midnighttaco08 Traffic Direction Moonlighter
    Sam
    Gilbert, AZ
    08 DCSB Indigo Ink TRDOR 2017 CM Tundra TRD OR 4x4
    Some Bubble Gum and Duct-Tape IG** Midnighttaco03 Camburg uni-ball UCA w/ CO Rear Dakar with Fox 2.0 bottom overload removed GG G3D radius bar 50" roof mount GG G3 straight 32" front valence Rago fab bed clamp pod mounts 2 GG amber pod rear OTRATTW custom switch panel in sunglass holder K&N cold air Gibson exhaust Alpine INA-W900 head Mr. Marv box and amp rack IDQ-10 - Interfire Mono Focal fx45 component front Alpine type S Co-ax rear Homer taco TRD Grill GG LED low/high beam TRD seat covers OEM bed mat Weathertech floor mats with replacement TRD-OR decals Weathertech in-channel vents GG Flush mount pod replament fog light kit GG green ditch mount 3x2 pods Fog lights anytime Tailgate hoseclamp mod LED dome light LED map lights LED reverse lights LED license lights Rear window decals: Mall rated, Tacomaworld.com, U-Haul power tow, soundtech, mammoth.
    I have sway away front coil overs and fox 2.0 in the rear.
    Both have been an excellent ride on and off road.
  5. Sep 26, 2016 at 10:00 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    First off shocks do not lift anything... it's the springs that determine lift.
    The shock simply dampens or slows down the up and down motion.
    If the shock's seal begins to leak prematurely...
    It is more commonly the fault of the installer
    Because the shock's travel is either too long or too short
    and is either extending or bottoming prematurely before the suspension does.
    This is a why bump stops are adorned (or even lengthened)
    as the suspension should bottom on those, not on the shock itself.
    Some folk even install limiting straps to ensure
    the suspension cannot droop too far
    and allow the shock to extend excessively and cause impact to that.
    I personally have never needed limiting straps.
    Because out back the leaf spring(s) extension is for fact the limitation.
    I utilize the Bilstein 5125's on mine (designed for 1" - 3" lift)
    5100's are generally utilized when retaining the stock ride height.
    My lift is approximately 2.5"
    The first Gen Tacoma have unequal length shocks out back
    due to their offset mounting positions (factory mounts).
    Don't remember the full part #'s off hand
    but do know they end in different #'s (--52 and --53 respectively)
    The 5125's are generic and designed to fit a chevy or ford I think.
    But if the eye bushing are changed to the correct size.
    Then they will mount to the original Tacoma shock mounts properly.
    Check out Wheeler's Off Road
    as they sell the appropriate length 5125's for the lifted 1st Gen Tacoma's
    and I believe they include or may pre-install the proper eye bushings.
    Bilstein I believe comes with a life time warranty...
    But not the 5125's... not sure why... but is what it is.
    I have had my 5125's installed since 2004
    and they do not leak... nor ever have.
    I feel they were more then worthy of my initial investment.
    And it's now 2016 and they're still doing their job without failure.
    geekhouse23 and Midnighttaco08 like this.
  6. Sep 26, 2016 at 10:07 PM
    Midnighttaco08
    Sam
    Gilbert, AZ
    :bowdown:
    lol I suppose it does good to actually read OP's entire post
    03tacoma4x4[OP] likes this.
  7. Sep 27, 2016 at 8:22 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    youl be fine with 5100s all around. fronts on the middle setting. they last a long ass time with just regular driving and theres always the warranty.
