Best Lift to fit 33"s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rez, Oct 14, 2011.
  1. Oct 14, 2011 at 1:36 PM
    Rez
    Rez [OP] Well-Known Member
    Vancouver BC
    TRD Sport
    Hey guys,
    I am new to Tacoma but not new to offroading.
    I just picked a 07 double cab TRD, looking for a good lift kit to fit 33x12.5/16
    I like to lift it just enough to fit those tires, and I am looking for a good road/offroad ride.
    every now and then I will load up my snowmobile too.
    So what do you guys suggest for a good but not super pricy lift kit!
    Thanks
  2. Oct 14, 2011 at 1:38 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    This may sound like jibberish, so check out toyteclifts.com
    5100's preloaded to the highest setting, add a leaf in the rear. Depending on your rear shocks you may wanna toss some 5100's back there too.
    If you have a little more money to burn, look into getting some OME or Eibach front springs with the 5100's, you can preload them at the lowest setting for 3 inches of lift.
    Good luck
  3. Oct 14, 2011 at 1:47 PM
    Rez
    Vancouver BC
    TRD Sport
    Thanks guys,
    I did check those 2 sites before posting but there is mostly info about the lift kit itself, not about the size of tire that can be fit
  4. Oct 14, 2011 at 1:48 PM
    Rez
    Vancouver BC
    TRD Sport
    Thanks
    did you have to use wheel spacers?
  5. Oct 14, 2011 at 2:00 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Typically for a wheel wider than 265 you need a spacer, I've heard 275's clear, but 285's definitely need a spacer.
  6. Oct 14, 2011 at 2:07 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Your going to have to get a 4.5-6" lift to clear a 33x12.5" tire unless ypu want to cut up your inner fenders/cabmount.
  7. Oct 14, 2011 at 2:20 PM
    Rez
    Vancouver BC
    TRD Sport
    Thanks again
  8. Oct 14, 2011 at 2:21 PM
    Rez
    Vancouver BC
    TRD Sport
    I am buying new wheels, I can get them with less backspacing, maybe 3"!! to clear the inner fender
  9. Oct 14, 2011 at 2:23 PM
    Rez
    Vancouver BC
    TRD Sport
    I used to have a Tracker with 8" lift and 35"s, had to trim a lot. I dont want to do any more trimming
  10. Oct 14, 2011 at 2:28 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    Get some spacers or 33's. I had to do some cutting and purchase spacers.
  11. Oct 14, 2011 at 10:40 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    Im running eibach coils on 5100s. Its only 2.5" lift on .85" setting. I added a small top plate spacer for 3".
    Fits fine with 285s, no rubbing on/off road. I have TC UCAs as well, set the caster properly and it wont rub on the cab mount. I might try the ome 886 next time.
