Best lift to get the front end up higher than back
Discussion in 'Suspension' started by YellowDog01, Dec 30, 2009.
  1. Dec 30, 2009 at 5:19 PM
    YellowDog01
    YellowDog01 [OP] Well-Known Member
    04 4x4
    Still raising up money for a toytec 3 inch, but I am going to stay with stock 265/75/16 tires. What is the best lift to get a good looking lean? (I want the front higher than the back, maybe 1")
    Thanks.
  2. Dec 30, 2009 at 5:31 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Bilstein 5100's. But if you are saving you may as well wait.
  3. Dec 30, 2009 at 5:43 PM
    Will Prerunner
    Will Prerunner Well-Known Member
    Tempe Az
    01 TRD Prerunner Doublecab
    Trail-Gear rock sliders, OME Lift, kobalt tool box, herculined fender flares, CrossFab light bar, Deck plate Mod, Differential Breather Extension, 32"goodyear duratracs Pioneer 3 way speakers, alpine head unit, Boss Bass 600 sub, custom az pinstriping
    OME or Bilstiens with a 1.5 AAL will get you the lift you want
  4. Dec 30, 2009 at 5:48 PM
    Will Prerunner
    Tempe Az
    You could go with the Toytech but it might not give you quite the lean you want because it I think it comes with the 2.25" AAl. you could try going with something similar from wheelers and only a 1.5" AAL to get a little more lean
  5. Dec 30, 2009 at 6:06 PM
    CNLimit
    CNLimit Member
    Puerto Rico
    Black 06
    Will Prerunner,
    What AAL's are you refering to?
  6. Dec 30, 2009 at 7:16 PM
    YellowDog01
    04 4x4
    I just looked at OME and the kits are like $900! That's really steep for me...I'm looking for something around the Toytec lift-$300...But want the lean.
    And the Bilsteins are adjustable? Will I need anything in the back suspension?
    Sorry, I have an 01 Prerunner Double Cab V6 if that applies. Thanks!
  7. Dec 30, 2009 at 7:18 PM
    YellowDog01
    04 4x4
    Is this all I need to get it looking how I want it? No AAL needed?
