Best Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ravistae, Sep 14, 2015.
  1. Sep 14, 2015 at 1:05 PM
    Ravistae
    Ravistae [OP] Well-Known Member
    Travis
    2015 Tacoma DCSB
    Here goes the question that comes up time and time again. I have researched quite a bit here on the forum and it seems a majority of Tacoma owners on here go for the adjustable type of lifts with new struts and coils. These lifts only go up to 3" I really want something in the 6" range. My truck will not be taken off road for sport. With that said I do not need all of the functions of the lifts many have on here. My main concern is highway quality riding (not something that rides poorly or rough) I want a quality lift that will last that is a 6" lift $$$ is not a concern.
  2. Sep 14, 2015 at 1:08 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    4WD TRD SPORT DCSB 6speed. Sorry should of mentioned the details of my truck
  3. Sep 14, 2015 at 1:14 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    I really like the Icon set up stage 4 or 5 but I would like more lift...I understand a 6" lift will require cutting my cross member which is essentially going past the point of no return.
  4. Sep 14, 2015 at 1:17 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I'd go with a 4-5" RCD lift and add some OME 884 springs to get another 2". Custom Alcan leaf springs out back.
  5. Sep 14, 2015 at 1:18 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    http://bds-suspension.com/product?kid=815F
    Is this what they call a "drop bracket" kit? I'm new to the tacoma and trying to learn my terminology and lift options. If you don't mind giving me a brief explanation of what a drop bracket kit does I'd appreciate it.. if not I'll just research.
    I'm guessing it drops the lower control arms with that new crossmember and the bigger spindles are included because the old ones obviously would no longer work. This allows you to fit bigger coilovers and raise the truck?
    What are the downsides and do you get significantl more travel with a drop bracket kit vs stock or the OEM replacement coilovers from King, Icon, Fox etc.
    How do they compare to the LT kits? I would think LT kits would be better across the board except maybe at achieving higher lift heights.
    Sorry for thread jack but it's relevant information to the topic.
  6. Sep 14, 2015 at 1:23 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What are the downsides and do you get significantly more more travel with a drop bracket kit vs stock or the OEM replacement coilovers from King, Icon, Fox etc.
    Less clearance and travel than any 3" lift kit (yes I am being serious)
    No comparison. LT over brodozer lifts any day.
    agunday21 and Doggman like this.
  7. Sep 14, 2015 at 1:24 PM
    Doggman
    Alabama
    2017 TRD OR MT
    Wow, good to know. Thanks.
    Thanks.
  8. Sep 14, 2015 at 1:29 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    MKW I will do my research on the RCD lifts. I was not aware that you could get that much lift out of those. Also I realize that the other type of lift will not provide much suspension travel as stated earlier you can get a better performing lift and more ground clearance with something like the Icons or fox kits
  9. Sep 14, 2015 at 1:33 PM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    To me, The RCD with added lift coils would be the best of both worlds. Several folks on here have added lift coils to the RCD kit to get more lift. This way, you get more lift AND get some much needed ground clearance for the crossmembers.
  10. Sep 14, 2015 at 1:34 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    I am new to this so would it be best to go to the RCD website and look for their kit?
  11. Sep 14, 2015 at 1:36 PM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    There is a very large thread on here somewhere about the RCD lift. Just search in the 2nd gen forum. Lots of info there.
  12. Sep 14, 2015 at 1:38 PM
    geekhouse23
  13. Sep 14, 2015 at 1:39 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    The listing show a 5" kit for 2005-2014 Tacomas. Mine is a 2015 is there any differences? If so where do I find one for my year model
  14. Sep 14, 2015 at 1:45 PM
    geekhouse23
    The shock mount on the rear axle need to be opening slight with a crow bar and the shocks will slide right in. Did it on my brother's 2015 installing an OME kit. Nothing affected no issues has at least 1500 miles on them so far.
  15. Sep 14, 2015 at 1:52 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    Again. I am new to all of this. So what is the difference (advantages/disadvantages) of the RCD setup versus lets say a 6" BDS or Fabtech?
  16. Sep 14, 2015 at 2:09 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    By the way looking at the BDS 6" Coilover Suspension system with the Fox Racing struts. I like what I see so far. Its just a hefty amount of money and this truck is my baby so I want to make the best informed decision I can make before pulling the trigger.
  17. Sep 14, 2015 at 2:13 PM
    Ravistae
    Travis
    2015 Tacoma DCSB
    Would I need the performance coilover series or just the base 6" IFS BDS system? I dont mind paying more but i DO mind paying for something I simply do not need. Is the performance series more for hardcore off roading? If they provide a better handling/drive on the highway then I will go for the performance over the base IFS series
  18. Sep 14, 2015 at 2:15 PM
    geekhouse23
    6" lift and offroading = not good.
    Limited clearance and suspension travel. Not to mention you are now sitting at a higher center of gravity which means a higher chance of rolling over. If you plan to do any offroading ever, avoid 6" lift kits.
    agunday21 likes this.
  19. Sep 14, 2015 at 2:17 PM
    Manwithoutaplan
    ID
    don't even bother with a 6 inch lift they are grabage.
    agunday21 and geekhouse23 like this.
  20. Sep 14, 2015 at 2:20 PM
    Doggman
    Alabama
    2017 TRD OR MT
    While we're on the topic of "Best Lift" I'm just gonna jack this thread again.
    Am I wrong to think that extended travel king coilovers w/ resi's in the front w/ total chaos UCA's and king extended travel w/ resi shocks in the rear w/ deaver leaves is about the best you can do short of a LT kit?
