Best looking HID color
Discussion in 'Lighting' started by tacomaLS53, May 29, 2013.
  1. May 29, 2013 at 9:59 PM
    tacomaLS53
    tacomaLS53 [OP] Well-Known Member
    I'm stuck between getting 6000k or 8000k for my headlights on my 2012 silver taco, if anyone has pictures that would be great
  2. May 29, 2013 at 10:02 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    4300k
    6000k isn't bad, but it's getting to be a touch blue.
    8000k wastes usable light. 4300k appears brighter than either to the human eye. It's a true white that matches sunlight, and is what is used by the auto manufacturers.
  3. May 29, 2013 at 10:06 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    5000k. Gives you great light output while still having an ever so slight hint of blue for pulling bitches.
  4. May 29, 2013 at 10:09 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Stick with 4300K, but no higher than 5000K. Any higher than that and you automatically turned your Tacoma into a Honda Civic.
  5. May 30, 2013 at 12:50 AM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Daylight is a hell of a lot cooler on the Kelvin color temp scale than 4300k. That being said, the human perception of light tends to favor the reds/yellows over the greens/blues in the cooler color temps. I've done photometric's as well as lumen measurement with 3500k, 4100k, and 5000k and the 5000 read just as bright as the 4100 with 3500 reading the lowest. The 4100 did look brighter to me though.
  6. May 30, 2013 at 12:52 AM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Somewhere between 4300 and 6000. But I wouldn't go higher than 5000
  7. May 30, 2013 at 12:52 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    i run 6000k....
    don't go past that
    I ran 8000k's
    teal color, blah blah high school blah blah COULDNT SEE SHIT AT NIGHT
  8. May 30, 2013 at 12:54 AM
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    I vote 4300K or 5000K. Not big on the blue look, plus the more you get into the cheesy wannabe racecar blue tint, the less effective your headlights actually become... the higher up the scale you go, the more you sacrifice performance (brightness)
  9. Jun 6, 2013 at 8:17 AM
    YotatechMatt
    YotatechMatt Active Member
    Moncton, NB
    Haha you should see the guys running green and pink hids.
    Pink looks cool doesn't quite blind you but the greenies rip your eyeballs out of the sockets.
    4300k for me.
  10. Jun 6, 2013 at 8:20 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    No higher than 5000k. I have it and lights up the road like no bodies business :)
  11. Jun 6, 2013 at 8:23 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    I'm running 8000k and it looks white. All depends on the brand I find. Have 6000k in the fogs with them as a different brand tand the two look the same.
  12. Jun 6, 2013 at 8:23 AM
    Goofballracer
    Goofballracer Well-Known Member
    Brennan
    San Diego
    2002 Toyota class 7 race truck
    Full cage fiberglass cab 35" tires ford 9" with spool
    4300- 5000k
  13. Jun 6, 2013 at 6:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Only way an 8000k looks white is if it's a 55w... and then it just looks "less blue" because the intensity washes it out a bit... or, if you bought from DDM, they likely shipped you the wrong lamps like they did to me twice, and the color temp is not indicated on the lamp.
    Mine were stamped on the box, but one was smeared and hard to read.
  14. Jun 7, 2013 at 1:38 AM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    The actual bulb itself wasnt marked but the plastic bulb housing was marked 8000k. Just looked. It's also a 35w. Check out some of my pics in my albums and see what you think.
  15. Jun 7, 2013 at 2:41 AM
    nickberg
    nickberg Member
    Nick
    CA
    2012 MGM DCSB 4X4 TRD Off-Road
    Modest mods and lift
    Morimoto Elite 5000k 35w FTW! Its a very crisp, pure white. I prefer it over my old DDM kit because the DDM had a pink wink
  16. Jun 7, 2013 at 9:12 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    There's a reason oem's send out cars with philips 4300K
    Ur still gunna have a blue colorband.
    Its hype and misconception that leads ppl to buy blue lights.....u lose usable light, u can't see shit in rain,dust, fog, and blue also is irritating to the human eye (including you the driver) and causes fatigue.
    Onlookers will see blue when they are below the cutoff anyhow.
    Stick with 4300K to 5000K...................................ur own eyes will thank you
  17. Jun 7, 2013 at 9:19 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    True to an extent..........
    Some sellers do not require the QC involved to properly rate a bulb.....some manufacturers don't use the right amount of salts (or whatever it is) or types......and u end up with off the wall actual temps instead of the standardized Kelvin scale.
    That's why I always ran philips.
    TRS is also supposed to have higher standards when it comes to QC compared to many places, and iirc they did work hands on with their manufacturers to establish their needs. Others like ddm can spit out cheap items due to a lower qc standard.
  18. Jun 7, 2013 at 9:35 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
  19. Jun 7, 2013 at 4:11 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It's the cutoff.
    On a proper projector, the light separates almost like a prism at the very edge of the cutoff. The oncoming driver will see blue when the cutoff is just below his line of vision. It fades back to white as the oncoming vehicle is farther or closer... or if the driver hits a bump/dip in the road, the oncoming driver will be a blue "flash" as the cutoff passes over his eyes.
    A lot of OEMs have gone to a Fresnel lens to reduce the sharpness of the cutoff, and it also eliminates the blue line at the edge. It is better for oncoming drivers because the pattern more closely imitates halogens, and it gets away from the heavy intensity change when the driver hits a bump/dip.
  20. Jun 7, 2013 at 4:24 PM
    06yfz450ridr
    06yfz450ridr Well-Known Member
    Austin
    CT
    HID's
    55w 8000ks look nice light tint of blue but over time they will fade to a lighter whitish blue.
    also of you arent going with projectors make sure they have the little shields on the bulbs or make your own so the cutoff isnt horrible looking
