Best Mod for fuel increase
Discussion in 'Technical Chat' started by ToysRus, May 26, 2008.
  1. May 26, 2008 at 5:44 PM
    ToysRus
    ToysRus [OP] Member
    KANSAS CITY
    99 SR5 TACOMA 4X4
    NERF BARS
    Need input for an xtra couple miles to gallon. Have already went w/ a very small hwy tire. Is there anything else I can do thats guaranteed to increase fuel mileage on tacomas. GEN. 1 or 2. (chip/exhaust/air intake/??)
    Fuel is going to $5. It's just a matter of time..:mad:
  2. May 26, 2008 at 5:51 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    ScanGauge2, it gives you real time MPG so that you can alter your driving habits accordingly.
  3. May 26, 2008 at 5:53 PM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    I noticed a difference when I switched from 87 octane to 93 octane. roughly 2-3mpg better with my 20's and 37's. so if you are stock you should see a bigger improvement i would believe.
  4. May 26, 2008 at 5:53 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    When you say 'very small highway tire' do you mean the height or width?
  5. May 26, 2008 at 5:54 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Jump in on the AFE Pro Dry filter group buy! I have one in my V6, and picked up 2-3mpg. Was getting around 17-18 before, and I've been getting 19-20.5 for the last month it's been in.
    Also, for $50 it'll pay for itself in the time it would take you to replace the stock one 3 times even if you don't get better mpg! :D
  6. May 26, 2008 at 5:58 PM
    piercedtiger
    Jon
    Southern Tier, NY
    The real question though is "does the mpg increase offset the higher cost of higher octane gas?"
    I ran 89 instead of 87 for a month. Got better gas mileage, more miles tank, but it was the same $/mile so I wasn't getting anywhere. Filling up 1 day later than before, but spending more each time.
  7. May 26, 2008 at 6:15 PM
    GotLift37
    North East AL
    07 4Runner 4WD
    You do have a point. But so do I. Say I put 20 gallons in. Say 87 is $3.90/gal and 93 is $4.10/gal. (which is the prices around here for now) 20 gal of 87 @ $3.90/gal = $78.00. 20 gal of 93 @ $4.10/gal = $82.00. I used to get average 12mpg on 87. 20 gallons X 12mpg=240 miles to tank. Now im getting average 14.5mpg so 20 X 14.5=290 miles to tank. Now the extra $4.00 that I spent in one week I can go another 50 miles. To me its worth it. To some people it may not be. I drive 18 miles round trip from home to work and back home. 3 sometimes 4 times a week. If all I did is go back and fourth to work I could do it for lets be safe and say 15 days of just going to work and coming home. Thats 2 weeks and a day of $82.00. Lets just say 2 weeks even. So devide that by 2. $82.00/2=$41.00/wk. In my book, im not necessarily saving money, but an getting better mpg.
  8. May 26, 2008 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just courious, Did you do the test after the engine was fully broken in? After 15,000 miles? My Tacoma, and the one before that, gained 2-3 mpg after I rolled past 15,000 to 19,000 miles on the odo. :)
  9. May 26, 2008 at 6:33 PM
    GotLift37
    North East AL
    07 4Runner 4WD
    yes, i have 39,000 miles on my tacoma
  10. May 26, 2008 at 6:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OK, thanks. :)
  11. May 26, 2008 at 7:43 PM
    Archery Ham
    Archery Ham Green Eggs and Ham Radio
    Muscle Shoals
    08 Tacoma
    Auxilllary backup lights, removed secondary filter,
    What about this for better MPG:
    What if I could direct air more directly into the breather box instead of air coming from the fender well?
    I had thought about making the fake, triangular grill next to the turn signals into a working grill (with holes) and using that to direct air into a tube and into the airbox.
    Kevin
  12. May 26, 2008 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A friend and I did this to his Tacoma. We took out his passenger side marker light. We used it as a mold for a fiberglass intake scoop. Ran the air right into the airbox. On the dyno, we saw no gains until we held a leaf blower up and aimed it and the new scoop. We stood about 5ft. away and saw an increase of 6 h.p.. We figured you wouldnt see any real gain until 60 m.p.h. or so. The afn at the shop couldnt blow air that fast. Bottom line is, it worked. Was it worth it? I wouldnt do it to mine, but he liked it, so its one of those things that you may have to try. :)
    Oh, the small fake grill next to the turn signal is too small. You would want to use a larger intake scoop.
  13. May 26, 2008 at 8:27 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    My MPG mods are
    Scangauge
    aFe Dry Pro S filter
    Remove the secondary filter
    tonneau cover
    2 extra PSI in the tires
    My last 2 tanks have been 27.5 MPG :D
  14. May 27, 2008 at 4:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Tonneau cover....
    Slightly higher air pressure in tires....
    Take some weight off your right foot....
    (I have a Scangauge also, but that doesn't affect MPG. It just allows you to see the results)
    I've removed my secondary air filter when I first bought the truck
    I use synthetic oil
    and I will be getting an AFE dryflow hopefully soon (group buy).
  15. May 27, 2008 at 4:47 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Drive like their is an egg between your foot and the pedal.
  16. Jun 18, 2008 at 4:35 AM
    Al Swearengen
    Al Swearengen Old Noob
    TRD Toyota rugged trail off road package.
    wondering if anyone has tried using denso iridium plugs gapped 20% over for any mileage increase. i have used bosh platinums this way for years in several vehicles without any ignition problems or any problems to speak of. just not sure in my new Tacoma.
  17. Jun 18, 2008 at 5:08 AM
    Roland
    Rhode Island
    An update since I was quoted.
    My last 3 tanks average is now 27.91
    27.516 MPG
    28.114 MPG
    28.066 MPG.
    My fuel log
    The 4 cylinder Tacoma has iridium plugs from the factory so I won't be looking into trying anything new there for another 80,000 miles.
    P.S. Welcome to TacomaWorld Al!
  18. Jun 18, 2008 at 5:39 AM
    Al Swearengen
    hey thx Roland, just something that has worked in a 96 Honda Civic, just not sure if i want to mess with my new warranty or not for a couple miles per gallon extra. the gap increase would go from .44 to .53 on this particular truck. i may have to try it for a tank or two of gas just to see if i get any problems or improved mileage.
