Best most affordable 3" lift
Discussion in 'Suspension' started by lost1700, Nov 23, 2009.
  1. Nov 23, 2009 at 11:47 AM
    lost1700
    lost1700 [OP] Well-Known Member
    Blake
    Florida
    2010 DC PreRunner
    I know, I am new, use the search, there is a million threads, etc...Let's be honest here, if everybody used the search there would be nothing to talk about, plus you know you guys like answering these questions.
    On to the important stuff, I just bought my 2010 DC PreRunner and I am interested in lifting it 3". I will be lifting it strictly for looks. What is the most affordable 3" lift to keep as close to a factory ride as possible?
  2. Nov 23, 2009 at 11:53 AM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    hockey pucks:D
  3. Nov 23, 2009 at 11:58 AM
    lost1700
    Blake
    Florida
    2010 DC PreRunner
    What is a hockey puck? I live in Florida.
  4. Nov 23, 2009 at 12:00 PM
    Bachenstien
    Bachenstien Well-Known Member
    Andy
    Portland area, oregon
    Tacoma SR5
    3" Fabtech coil overs/rear block, Front and rear diff locked.
    Im sure he means coilover spacers.
  5. Nov 23, 2009 at 12:03 PM
    Ewang
    Ewang E Wang
    Eric
    So. Cal
    2009 Prerunner TRD Sport
    BFG All-Terrains, 18" Flat Black Incubus Crushers, 3" Spacer life, Flowmaster Super 40 Exhaust, Black Billet Grill, P.A. System, JBL and Kicker sub audio system, HID Lights.
    I have your answer!
    Toytec 3" spacers.
    Its 100 bucks.
    Toytec only makes their parts for toyotas and some of the dealerships even put them on their trucks.
    I have it on mine. It looks great.
  6. Nov 23, 2009 at 12:15 PM
    lost1700
    Blake
    Florida
    2010 DC PreRunner
    I have a feeling using spacers only does not retain the factory ride, someone correct me if I am wrong.
  7. Nov 23, 2009 at 12:16 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    it does not, really stiff. if you want the best ride and 3" get coilovers
  8. Nov 23, 2009 at 12:17 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Give us your budget on just how much you want to spend on the lift kit alone. Not including wheels, tires, alignment & labor cost. Thanks.
  9. Nov 23, 2009 at 12:35 PM
    lost1700
    Blake
    Florida
    2010 DC PreRunner
    If possible, I would like to stay as close to $500 for the kit alone if there is something in that range that doesn't screw up the ride too much. I def. want to stay as far below $1000 as I can.
  10. Nov 23, 2009 at 12:37 PM
    sirsaechao
    Tim
    CA
    You can do ToyTec lift kit featuring OME coils and AAL in the rear:
  11. Nov 23, 2009 at 1:03 PM
    lost1700
    Blake
    Florida
    2010 DC PreRunner
    Would the OME coils, AAL, and 5100's all around ride nice? Is the AAL better then the whole leaf pack?
  12. Nov 23, 2009 at 1:06 PM
    bajamoon
    STEVE
    Whittier
    the aal is not better than a new leaf pack but does the job just fine. that setup is fine.
  13. Nov 23, 2009 at 1:37 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Make sure you get the 885 coils because you have the DC. And yes, that is a nice setup. ;)
  14. Nov 23, 2009 at 1:50 PM
    lost1700
    Blake
    Florida
    2010 DC PreRunner
    I want it to ride nice though
    thanks
  15. Nov 23, 2009 at 2:05 PM
    sirsaechao
    Tim
    CA
    A lot of people choose the 5100's all around but the OME shocks are better valved for the OME coils. Full leaf is always better then an AAL.
  16. Nov 23, 2009 at 2:16 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That^ The bilsteins are great if you are going to lift without new springs. If you are going to the 885/886 springs- Get the shocks that are built to work with them. Just MHO.
    AALs work just fine. If budget is your thing....It's 60 bones for an AAL versus 350 for a new leaf pack....And upgrades down the road are always an option.
  17. Nov 23, 2009 at 5:23 PM
    lost1700
    Blake
    Florida
    2010 DC PreRunner
    so basically I should just get the OME kit with new springs, OME shocks all around, and AAL, and the spacers if I want a full 3"? Will adding the spacers worsen the ride at all? That kit lifts the front 3" and the rear 1.5" to level it off?
  18. Nov 23, 2009 at 5:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Keep in mind that along with a lift, comes a more firm ride. Be it "Coilovers", OME, or Eibach set ups, increaseing spring rate will make the ride more firm. Most Coilovers have a 650# spring rate, Eibach uses a 600# and a 620# (depending on the spring), and OME uses 590# and 650# spriings. Stock is 550#. When getting new springs, you need to consider new shocks too. The stock shocks are not designed to dampen after market springs with a higher spring rate. The ride will be bad.
