Best Motor Oil?
Discussion in '4 Cylinder' started by tacosoup89, Jan 22, 2014.
  1. Jan 25, 2014 at 5:51 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Anyone who has seen inside a few engine knows that a good synthetic oil does slow down wear and keep it clean. I use Mobile 1 10w40 or 5w30, or weight similar and change it every 5,000 miles along with Toyota oil filter at same time on my 4.0 V6.
    You can use petroleum based oil and last a long time too, but change it at least every 5k. And when you start your Tacoma DON'T rev the piss out of it until it warms up a bit! A cold engine does not have oil where it needs to be yet!
  2. Jan 26, 2014 at 3:43 AM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    I have a 2010 with 23k miles and although its a quirky motor that sometimes coughs during cold startups and sometimes ticks like a diesel, if I heard a "knock" or any sign of "piston slap" ....... I'd be heading straight to the dealer and demanding a new motor.
    I've never heard of piston slap on a newer motor. Piston slap is not normal and should not be overlooked. I'd be investigating this if I were you guys.
  3. Jan 26, 2014 at 3:01 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I agree, its uncomfortable. If you search 'piston slap' here youll find a decent number of threads regarding the cold start knocking, in both 2nd gen engines but mainly the 2.7.
  4. Jan 27, 2014 at 3:33 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
  5. Jan 29, 2014 at 8:55 AM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    ANY new oil is good, just use the grade Toyota recommends as they've changed recommendations since 2005. After all, this isn't a Porsche 911. Mobil 1 is trash though, I will never use it or recommend it to anyone. I was tricked by people on the forums into using it on my turbo Toyota and it ate it quickly and oil temp/ pressure lights came on after only 500 or so miles. Poured that trash out and used Castrol EDGE and what do you know? No significant oil burning even after thousands of miles and numerous WOT smashes. Could be different for the 2.7L Tacoma, but im staying away from Mobil 1 forever. I get my 2.7L engine oil changed at the dealer, I think they use some type of part synthetic? Runs good, good mpgs, and doesnt lose any after like 4-5k miles.
  6. Jan 29, 2014 at 9:05 AM
    Drummer0247
    Drummer0247 International Jewel Thief
    Michael
    Rio Rancho, New Mexico
    2013 Toyota Landcruiser
    I switch back and forth between amsoil and mobil one, but i always use oem filters, member did a very thourough comparison between all the major brands and after seeing some of the "premium filters" disected ill never deviate from oem.... just search for it, its a very good review....
  7. Jan 29, 2014 at 9:16 AM
    3INVERTED9S
    3INVERTED9S Well-Known Member
    Los Angeles, CA and Rio Rancho, NM
    2011 Tacoma 4X4 reg cab manual 4cyl.
    Method Standard wheels, Good Year Duratracs, Tint, K&N air and cabin filter, EBC Rotors and pads, Shitty JVC head unit, all Redline fluids, Optima battery, Bilstein 5100s, Uniden 520XL
    Redline for all fluids.
  8. Jan 31, 2014 at 6:28 PM
    GWC
    GWC Member
    Glen
    Homestead, Fl
    Had an old 20R that knocked on start up and would go away after several seconds, Toyota warranted the engine and put in a new short block. The knock sounded as though it was a wrist pin. The truck had 80,000 on it when they warranted it. I use Toyota filters and Mobil1 oil.
