Best Off Road Tire
Discussion in 'Wheels & Tires' started by tcnoblet, Jul 21, 2013.
  1. Jul 21, 2013 at 1:19 PM
    tcnoblet
    tcnoblet [OP] Member
    Thomas
    Speedway, IN
    I have a 2012 double cab Tacoma 4x4, which came with "BF Goodrich Rugged Trail T/A tires(P265/70R 16). What Off-Road tire for this truck would you recommend?
  2. Jul 21, 2013 at 1:25 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Purely for off road performance or do you want one that will actually last longer than 15K miles?
  3. Jul 21, 2013 at 5:58 PM
    tcnoblet
    Thomas
    Speedway, IN
    Will want one that will last than 15K. Only go off-road in the fall.
  4. Jul 21, 2013 at 6:19 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    BFG A/Ts wear like iron and will last you 100,000 easy. But they suck ass in winter. (This is from a Canadian, you can take that advice to the bank.)
    No expert on the Duratrac but a lot of people have been running it with favourable results. However popular consensus is the sidewall is lacking a little. (If you just off road a little you'll be fine.)
    I have the BFG A/Ts which I'm trying to burn through (Fucking things just don't die!) and M/Ts (Mickey Thompson MTZ's) and for winter a dedicated tire (Yoko Geolander I/T GO72.)
  5. Jul 21, 2013 at 6:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All depends on the terrain involved. Many tires excel in certain areas.
  6. Jul 21, 2013 at 6:42 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Thomas - What kind of off roading in the fall do you do?
  7. Jul 22, 2013 at 4:16 PM
    tcnoblet
    Thomas
    Speedway, IN
    Deer hunt in the fall. Travel off-road through cut corn and bean fields.
  8. Jul 22, 2013 at 5:13 PM
    Warputer
    2011 TRD Off Road
    With just a quick search on the web, it seems that the selection of "off road" tires in that size is kind of limited. Only one I saw that I'd spend money on is the BF Goodrich A/T KO, as Krazie Sj mentioned above.
  9. Jul 24, 2013 at 11:41 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Also look at 265x75R16's. Fit on a stock truck perfectly fine and you'll find a wider selection of tires to choose from.
