Best off-road tire !
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bear-hunter1014, Dec 21, 2020.
  1. Dec 21, 2020 at 7:07 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    My e loads made my truck handle like a sports car on smooth roads with stock sport suspension. Now off road was a different story...
    So glad i went with C load.
    rlx02 likes this.
  2. Dec 21, 2020 at 7:07 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Toyo Open Country AT3
    Bannerman likes this.
  3. Dec 21, 2020 at 7:08 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    My mistake if I interpreted you comment wrong. I read it as you saying they were the worst and any search would turn up support of that.
    In any case if you had odd wear and didn't last long, that sounds more like an alignment issue. Tire wear patterns are a result of the direction they are placed in relation to the direction they are forced to go. Tires roll the direction they are pointed and when that isn't straight, they have to drag themselves back in line. This happens over and over and eventually causes wear pattern. This is similar to the effect you see on shoes when someone with pronated feet or someone that is pigeon toed.
    six5crèéd[QUOTED] likes this.
  4. Dec 21, 2020 at 7:10 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    This thread would make a pretty good poll, dontcha think?
  5. Dec 21, 2020 at 7:11 AM
    Sungod
    St Augustine
    Completely agree. There is no such thing as a perfect tire and everything is a compromise. A tire that does great in one category won't do good in another. You have to find the one that does the most for what you want with the negatives you can live with at the price you want to pay. That is whey there are so many options.
  6. Dec 21, 2020 at 7:11 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Had my front end aligned shortly after they were put on. I’m not a fan of them.
  7. Dec 21, 2020 at 7:18 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I really wanted those but they only came in E load in the size that i wanted.:pout:
  8. Dec 21, 2020 at 7:20 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    I've been a BFG KO and KO2 fan for over 20 years on several of my trucks. When I decided to build my 17 Taco OR, I wanted skinny 33s. Unfortunately I couldn't get 255/80r16 in a KO2, so I red up on the KM3 MT tire. Decided to go for them and DO NOT REGRET!
    Yes they are heavy and did knock me down a few MPGs due to the weight and additional tire size, but man are these smooth and nearly bullet proof!
    Very quiet even for a MT. Balance is dead on and so far no issues on wet pavement like some MT tires exhbit.
    Maybe consider KM3s in your desired tire size?
  9. Dec 21, 2020 at 7:21 AM
    Sungod
    St Augustine
    Understood, but how do you know that alignment was done correctly? There are a lot of lazy techs out there and it isn't hard to fake a print out. Even if it were tire related, Michelin stands behind their product. Getting a set of defective tires although extremely slim could happen and Michelin usually stands behind their products even if the customer is somewhat to blame. That is something I can't say for the vast majority of tire companies out there especially Goodyear.
    Not bashing you, but uneven wear combined with rapid wear is not something I would associate with any tire company. I get that you probably associate it with the tires and that is understandable. I won't eat Pizza Hut pizza because I got food poisoning after eating there. Probably had nothing to do with Pizza Hut, but it is in my head.
  10. Dec 21, 2020 at 7:24 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    ye but they ride the same as my sl winters so meh
  11. Dec 21, 2020 at 7:26 AM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    C load and E load have identical sidewalls. I have never found a dramatic difference in ride comfort between the two.
  12. Dec 21, 2020 at 7:28 AM
    Norsk
    Norsk Well-Known Member
    2024 Underground Gray Tacoma TRDOR Premium
    Falken Wildpeak AT3W LT265/70/17 E Rated!
    Was originally going wiht 275/70/17 until i found out that my factory wheels has huge chunk of Offset will cause more rubbing with 275 tires.
    Pics shown here!
    Hammerstorm and Interbeing like this.
  13. Dec 21, 2020 at 7:28 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Both setups looks sweet. What size are each?
  14. Dec 21, 2020 at 7:39 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    255/80R17 on both.
    boostedka[QUOTED] likes this.
  15. Dec 21, 2020 at 7:49 AM
    #35
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I have a set of Michelin’s on the truck now, been on for two years with no uneven wear and haven’t had the front end aligned since putting them on.
    KO2’s, you either like them or don’t. I don’t.
  16. Dec 21, 2020 at 7:55 AM
    #36
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    Our new TRD Pro came with Goodyear Wrangler Kevlar tires, and I'm wondering if anyone has any feedback on these tires for off-roading and snow. TIA.
    Hobbs likes this.
  17. Dec 21, 2020 at 7:57 AM
    #37
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    @Hobbs has a pretty good review on them.
    StayinStock and Hobbs like this.
  18. Dec 21, 2020 at 7:58 AM
    #38
    eurowner
    eurowner Duke Sky
    Scoty
  19. Dec 21, 2020 at 8:00 AM
    #39
    eurowner
    eurowner Duke Sky
    Scoty
    In the Rocky Mountains of Colorado, I felt that off road in loose rocky ddry mellow off road trials they were fine. In the snow, slush on roads, the Toyo Open Country ATIII is a better tire.
    For driving in snow covered/plowed streets nothing beats a dedicated winter tire.
  20. Dec 21, 2020 at 8:00 AM
    #40
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    They’re not that bad in the snow. They are pretty well siped and don’t get too hard in cold temp (I haven’t driven them in snow many times). But for mud or wet dirt they are pretty poor from what I hear (don’t have experience).
