Best Oil Change Tip E-V-R
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EnonEye, Jul 18, 2018.
  1. Jul 18, 2018 at 12:58 PM
    EnonEye
    EnonEye [OP] Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    Made ya look huh? Did a search and didn't see anything about this, I'm sure someone out there has heard/used this tip but I've been changing my own oil since I was 15 and never heard this before. Just a backyard mechanic here but... changed oil 1st time last week at 3,000miles, noticed I had a drip when I pulled out of garage so I go to dealer and check and sure enough this vehicle needs a new washer each oil change, (never changed it on my Tacoma) buy gasket and 5 quarts of new oil figuring drain, add gasket and refill. I'm fortunate enough to use the racks at my local AF base, guy working there says he can use a shop-vac and I won't lose 1 drop of oil so I put it up in the air, he's standing on the rack with the shop vac hose connected to the oil fill tube with (of course) the oil filler cap off, I unscrew the oil drain bolt, put on new gasket, retighten the bolt and viola!... done, not 1 drop came out. The shop vac creates a vacuum stronger than gravity. Good as long as the power doesn't get cut (then you'd get a face full of oil and be sure to set the shop-vac on suction and not blowing out and I'd recommend cleaning off the shop-vac hose connection before attaching to your vehicles oil filler neck.. Made me a little nervous but all worked out well.
    Norton, Pork Chopper, mtip and 17 others like this.
  2. Jul 18, 2018 at 1:00 PM
    BrianT23
    BrianT23 Well-Known Member
    CA
    2014 SC/LT/BDGR POOP Tacoma 4x4
    Lol thats badass man, I haven't heard of that, but I bet it works!!
    Shark18 likes this.
  3. Jul 18, 2018 at 1:05 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Good stuff!
  4. Jul 18, 2018 at 1:11 PM
    Red Baron
    Red Baron Let's call it livabetes, no more die
    Aaron
    Lost on a roundabout
    07 Radiant Red DCSB
    Things with metal, dog hair, more metal and lights
    Dude! I wanna see someone actually try this... that's awesome
  5. Jul 18, 2018 at 1:11 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Good thing the guy standing and holding the shop vac didn’t get a phone call. You could have ended up with a mouth full of oil.
    Lester Lugnut likes this.
  6. Jul 18, 2018 at 1:14 PM
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    Yep, I heard about that trick from my friend with a big Diesel Dually....which takes something crazy like 12 quarts....He had a drip from the dealer not replacing the crush washer. He took it to a local shop to see if they had any tips before driving back to the dealer. That's exactly what they did. He said it didn't lose a drop.
  7. Jul 18, 2018 at 1:38 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Ok doing this my next oil change before I remove the drain plug. No more oil on hands. Turn off the vacuum and oil drains.
  8. Jul 18, 2018 at 1:41 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Best Oil Change Tip E-V-R is to replace the washer every time but that vacuum idea should work safely unless the oil has lots of gasoline contamination in it
    Norton, parsonsjr and 05tacomabro like this.
  9. Jul 18, 2018 at 1:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Lube shop guys have been doing that for years
  10. Jul 18, 2018 at 5:17 PM
    HPMaster
    HPMaster Active Member
    Suffolk Co., NY
    2011 2.7 5mt Access Cab
    Used this technique when I had to change the shut off valve on the bottom of my 275 gallon home heating oil tank. Not a drop lost to replace that leaking valve! It works.
    spitdog, scottalot and Ksinger4 like this.
  11. Jul 18, 2018 at 5:24 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
  12. Jul 18, 2018 at 5:26 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
  13. Jul 18, 2018 at 5:33 PM
    DukesTaco
    AZ
    ^thats how I am doing it ffomnnow on .
    scottalot likes this.
  14. Jul 18, 2018 at 5:46 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Clever trick...then maybe slip on a Fumoto valve after you remove the original drain plug and you’ll never need the vacuum again.
  15. Jul 18, 2018 at 5:51 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    I knew shops could suck oil out the dip stick tube but had never heard of this. But since there's videos on the interwebs it must be true.
    DukesTaco and scottalot like this.
  16. Jul 18, 2018 at 9:45 PM
    tbr3345
    tbr3345 Well-Known Member
    Tom
    Sacramento, CA
    2010 TRD Sport DBL Cab Silver Streak Mica
    Now my Grandson want to try it tomorrow. Told them know because on of you will turn off the vac and I will have to fill it back up with oil.
  17. Jul 19, 2018 at 5:35 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Very cool.
  18. Jul 19, 2018 at 5:48 AM
    knottyrope
    Knotty
    Bahstun
  19. Jul 19, 2018 at 1:26 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This is a great suggestion for replacing a washer on a full sump! Let's hope I remember it if/when the time comes to use it :D
    As for the shop vac creating vacuum stronger than gravity... it depends what object gravity is pulling on. With a sump of motor oil, the shop vac holds up good. For something as large as a water heater or storage tank, maybe not. Not trying to be disagreeable, but there are some applications where even a strong shop vac will lose the battle against gravity.
    PzTank likes this.
  20. Jul 19, 2018 at 1:38 PM
    Muddinfun
    Muddinfun Well-Known Member
    What about the crankcase ventilation hose that connects to the air box? Seems like air would just gleefully flow through there and into the shop vac.
