Best Oil Filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota4Life!, Mar 12, 2019.
  1. Mar 15, 2019 at 10:29 AM
    #41
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I'd rather stay with filters I trust ..... such as
    Baldwin
    Wix
    K&N
  2. Mar 15, 2019 at 12:49 PM
    #42
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Yes US Marine, & that's exactly what everybody else does. Nobody has anything to base their decisions on, other than That's what my grandpa always used & he never had a problem, or that's what my mechanic uses, so I'm using the same thing, or the advertisement says these catch more dirt, & I like this one I wouldn't have one of those old cheap filters. I don't think anyone can really base their decision on anything other than that's the one they feel comfortable with.
    Wixo, b_r_o and US Marine like this.
  3. Mar 15, 2019 at 3:08 PM
    #43
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Factory Toyota
    Norton likes this.
  4. Mar 15, 2019 at 4:15 PM
    #44
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Toy filter by the case online.
    Change with cheapest walmart Dino oil every 5k
    Almost 209k miles and 420 miles per tank with original stock plugs.
    NAAC3TACO likes this.
  5. Mar 15, 2019 at 9:59 PM
    #45
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    I'll say the only filter I've ever seen fail was a K&N. My brother ran them on his 370Z and developed a leak after a few thousand miles. It turned out that the filter case inside the nut that is tacked on the end fatigued during pressure cycles and cracked.
    I use the OEM filter on the Tacoma.
  6. Mar 15, 2019 at 10:58 PM
    #46
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Any name brand filter and oil will do that. 1gr-fe is a rock. Super easy on oil and Toyota’s idiot light at 5k helps even more.
    Oem(or any filter) is fine for 5k changes. If you want to extend your OCI move to a synthetic media filter like Mobil1, wixxp, or Fram ultra.
    End thread.
    BillsSR5 and Armkb[QUOTED] like this.
  7. Mar 15, 2019 at 11:05 PM
    #47
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    The only oil filter I have had fail was a $14.00 K&N.
    thewarriordinghy and b_r_o like this.
  8. Mar 16, 2019 at 6:10 AM
    #48
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    K&N oil filters......the welded nut is meant for easy removal
    Not for the installation process.......tighten by hand only....tightly
    US Marine and NAAC3TACO like this.
  9. Mar 17, 2019 at 8:51 AM
    #49
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    I use Toyota oem only for the oil filters. Buy oem by the case on ebay or Amazon.
    I use M1 5w-30 from costco. They have sale on it once a year.
    Air filters I usually shop around a lot.
    I did the same thing on my 97 4runner for 20 years. 2002 prius for 12 years,
    2005 corolla for 5 years
    oem oil filters work.
    #49
    Norton likes this.
  10. Mar 17, 2019 at 10:20 AM
    #50
    DaveB.inVa
    SWVa
    It was only tightened by hand. I've worked around my brother my whole life and have never seen him use a tool to install a filter.
    Further, the crack was inside the welded on nut, not at the tacked points themselves.
  11. Mar 17, 2019 at 10:40 AM
    #51
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    #51
    outlawtacoma and Tacomax4 like this.
  12. Mar 17, 2019 at 10:50 AM
    #52
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    You mean Im not the only one that looks at his odometer and says "Its almost time to do X maintenance" and then a day or so later the light turns on? Down here people sometimes have what looks like a christmas tree on their dash lol
  13. Mar 17, 2019 at 11:53 AM
    #53
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    No doubt the OEM filters are good, Dolpan proved it, got 20 yrs on a 4Runner, 12 yrs on a Prius, & 5 yrs on a Corolla, all using OEM filters. That proves the OEM's are great. We replaced, the wife's, 23 yr. old, "87" 240SX Nissan in 2010, when the clutch gave up. It was showing 213K & the odometer didn't work for the last 7 yrs. I bought my used "82" Dodge Ram 50 4X4 in "84", It was 25 yrs. old when it broke a shaft in the transmission, we replaced it in 2007, had appx. 200K on it. Since back in the "60"'s I've always just used whatever filter was on the shelf, or whatever the Quick lube oil change place, or Wal-mart oil-change screwed on it. I guess it could be said that the OEM's are just as good as the mixture of filters I've used over the years., "OR". The mixture of filters I've used, over the years are just as good as the OEM's, as neither of us have had any filter problems. Like said earlier, Whatever you feel comfortable with will be fine, I promise.
    TacomaSport86 likes this.
  14. Mar 17, 2019 at 12:32 PM
    #54
    jeepsrwack
    jeepsrwack Well-Known Member
    2014 Tacoma trd sport
    My oil analysis was good to go using oem oil filter to 10k with Mobil 1 5w30 EP. Stick with oem, it’s good for 10k miles. Scientifically proven, end of discussion. Boom.
  15. Mar 17, 2019 at 12:34 PM
    #55
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    I second this. Napa gold is a wix filter for half the cost. I run Napa synthetic oil with a Napa gold filter
    JJ Customs likes this.
  16. Mar 17, 2019 at 12:36 PM
    #56
    JJ Customs
    Jay
    NV
    Thank you for supporting Chase Elliot!
  17. Mar 17, 2019 at 12:37 PM
    #57
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    Hey they make good stuff for car maintenance... But I buy my Duralast gold brakes from autozone...
  18. Mar 17, 2019 at 12:38 PM
    #58
    JJ Customs
    Jay
    NV
    LOL, you should check out the adaptive one pads from Napa. That's all I run.
  19. Mar 17, 2019 at 12:40 PM
    #59
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    The Duralast gold have lasted me longer than anything else ive used, but ive yet to try Napa pads
  20. Mar 17, 2019 at 12:42 PM
    #60
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    :deadhorse:
    Norton likes this.
