Best on road suspension for 2006 TRD Sport?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MrFixit420, Jan 22, 2020.
  1. Jan 24, 2020 at 10:09 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
  2. Jan 24, 2020 at 10:20 AM
    MrFixit420
    MrFixit420 [OP] Well-Known Member
    Portland Oregon
    2014 TRD Off Road DCSB
    Eibach Pro Stage 1 on 2nd clip, 3 leaf Icon AAL's in back.
    Good to know. I didn't realize the Bilstiens were under $400 for the set. That might be the way to go if I can't find a good used set.
    What about the rear? I have 155,000 on it and they are looking kinda flat. Are the lift blocks that are already in the back ok or does that also compromise the ride? I know springs would be better but again want to keep the costs down.
  3. Jan 24, 2020 at 10:37 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    i went with 3rd gen shocks and front springs
    install was easy except for my rusty sway bars bolts and skid plate bolts
    gained some front height to level it out with the 4 leaf pack from recall
    MrFixit420[OP] likes this.
  4. Jan 24, 2020 at 10:44 AM
    Clearwater Bill
    Billy
    Largo Florida
    Make the CL guy an offer. Doubtful they'll sell fast at that price.
    There is no magic in the 5100s. They are popular as they provide a cheap lift if you use a perch above 0. Which is preloading a spring, making it shorter, thus stiffer.
    You defined you goal well. Use the right stuff even if you have to wait a bit to find the pieces at the price you want.
  5. Jan 24, 2020 at 10:55 AM
    MrFixit420
    Portland Oregon
    Will do. The old lady wants it lifted because of the looks so am trying to keep about the same height as it has with the current setup. Just want it to ride better.
  6. Jan 24, 2020 at 11:30 AM
    TacoFergie
    Iowa
    The 5100's generally are around $400 mark. I would recommend installing new strut mounts on the front ones, but you can re-use the old ones if needed.
    https://www.bilsteinlifts.com/shop/...ht-adjustable-5100-front-and-rear-5100-shock/
  7. Jan 24, 2020 at 11:34 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Unless you are getting the 3rd gen setup dirt cheap and install it yourself, I don't see the point of going this route which likely will not net you the 2" lift that you currently have. Short of the CO's/full leaf pack route, I would go with 5100's and a wheeler's progressive 3 leaf pack for the rear. This would still be better than your current setup.
  8. Jan 24, 2020 at 2:20 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    FWIW (maybe this has been covered in this thread) unless things have changed since we bought our 2005, TRD OffRoad uses progressive wound springs which have a more compliant ride than TRD Sport's linear (and stiffer) springs.
  9. Jan 24, 2020 at 2:28 PM
    HoustonMike
    HoustonMike Well-Known Member
    05 Tacoma TRD OR 4x4; One-owner, 230,000 mi
    I have the Bilstein 6112's on my 2005 TRD Off-road and like them just fine on-road. However, the cheaper Bilsteins would probably be fine too for less money.
  10. Jan 25, 2020 at 9:30 AM
    MrFixit420
    Portland Oregon
    I think that on top of the stiffer valve shocking and the lift is the problem. It makes sense. :thumbsup:
    XSplicer62[QUOTED] likes this.
