Best on-road tire pressure for LT tires?
Discussion in '3rd Gen. Tacomas (2016+)' started by Black64, Jul 9, 2020.
  1. Jul 9, 2020 at 1:03 PM
    Black64
    Black64 [OP] Lowes/Home Depot Crawler
    Orlando, Florida
    2017 Red Tacoma SR5
    It's a silly question but I can't find anything on google or searching these forums. Just upgraded to new Falken Wildpeaks 265/75R16 (LT, 123 load index, 80 PSI max) and the tire shop filled them to 35 PSI, I have them currently at 65 PSI. Is this good for on-road or should I run them higher or lower? I am averaging 21 MPG currently.
  2. Jul 9, 2020 at 1:05 PM
    15ACOR
    15ACOR Well-Known Member
    2015 TRD OR
    Jesus, 65 psi must be like driving concrete blocks that are about to explode
    BGXtobe, c.morris89, erok81 and 12 others like this.
  3. Jul 9, 2020 at 1:08 PM
    Black64
    Orlando, Florida
    2017 Red Tacoma SR5
    It's actually about the same as the stock firestones, I ran them at max 44 PSI. My highway MPG is excellent, often hitting 23.
  4. Jul 9, 2020 at 1:12 PM
    su.b.rat
    su.b.rat Tacomakart
    TW
    you can do whatever you want, those tires can hold a lot. but if you're asking about tire function like grip, life, handling, etc, then the answer is obtained through a chalk test. every truck is different with weight. but if you want to run them at 80psi for added mileage then just do it. and then save for some new teeth.
  5. Jul 9, 2020 at 1:19 PM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    You're likely going to prematurely wear out the center most 3-4" of your tire tread with PSI higher than 45...
  6. Jul 9, 2020 at 1:21 PM
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Chalk test isn't perfect. Mine showed about 35 for full contact, but that showed abnormal tread wear. 38 or just above cold is what is wearing best for me. I am on 255/85r16 ST Maxx.
    GillyLink likes this.
  7. Jul 9, 2020 at 1:25 PM
    0xDEADBEEF
    0xDEADBEEF Well-Known Member
    Kansas City
    2000 4WD MT Single Cab
    Rust, dents, miles, extra metal.
    With radial tires the tire pressure has far less effect on the profile of the tire, so the chalk test isn't very useful, and you're unlikely to wear out the center of the tire faster.
    The pressure listed on the door jamb is probably the best mix of ride quality and efficiency for a stock vehicle. Add weight (or tow), and it might be worth reconsidering.
    Speed and weight-of-foot have more to do with your gas milage, unless your tires are just that flat.
  8. Jul 9, 2020 at 1:27 PM
    vicali
    vicali Chilling at YMH
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Phew, no wonder the anti E-load guys think they are rough..
    I run my 265/70-R17 E Toyo RT at 38psi, when they warm up they get to around 44psi on the highway..
    When I hook up the trailer and tow I'll boost it up to 50psi.
  9. Jul 9, 2020 at 1:28 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve not gone as high as 65psi. Do you still have all your teeth?
    I’ve experimented between 30 and 40 psi. 40 felt like a dump truck compared to the stock tires at 32. 35 has been a happy medium. I’ll try 65 and tell you what I think.
  10. Jul 9, 2020 at 1:33 PM
    splitbolt
    splitbolt Well-Known Member
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  11. Jul 9, 2020 at 1:36 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    35 all around is a good generic rule for tacoma and 4runner and sienna
    I run 38 typically but recently went to 35 all around since hitting a more rotted out connector
    road on my commute...a few lost psi does smooth out rumbles a hair
    SoCali_Guy likes this.
  12. Jul 9, 2020 at 1:39 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2019 Toyota Tundra 4WD Crew Cab 5.7L Limited with TRD Off Road Package and Cement
    There is no "best" inflation for on road use of LT tires. Dude, the tire is designed to hold weight and not deform, so if you don't have any weight, then you can run a low pressure. Don't hand me a crock of shit telling me your E tire rides as good as a P tire either. They don't. They can't physically.
  13. Jul 9, 2020 at 1:45 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    ^this
    my generic rule of 35 all around is on ordinary LT Michelins LTX Defenders and mostly empty trucky
    if I am hauling excess weight like 1000 lbs them pressures are going to MAX
    and if I am hauling weight all the time not just a few times (a real work truck)
    then I get better truck tire rating (with a worse unloaded ride)
  14. Jul 9, 2020 at 1:50 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Chalk test
  15. Jul 9, 2020 at 2:18 PM
    su.b.rat
    su.b.rat Tacomakart
    TW
    I'ma say my 30" E tires ride amazingly better than any bubblegum P or LT rated cheesy crap. 35psi here. these tires are like driving on rocks even medium low pressure.
    hiPSI likes this.
  16. Jul 9, 2020 at 2:25 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    80 PSI is intended for a fully loaded 3/4 ton or 1 ton truck with a GVWR over 10,000 lbs. You wouldn't even put that much air in a 3/4 ton truck unless you were hauling near max. Most guys with 3/4 tons run 50-60 PSI for normal driving.
    The wheels on your Tacoma aren't rated for over 65 PSI, you stand the chance of splitting your rims with that much air in them.
    The tires that came on the truck call for about 30 PSI for best ride and 44 PSI for max hauling. I always ran closer to 40 PSI with those tires.
    But the E series tires are stiffer and don't need as much air to carry the same weight. Around 30 PSI is a good place to start for best ride. If you're going to haul any weight then closer to 35 PSI. No reason for more than that in a Tacoma.
  17. Jul 9, 2020 at 2:30 PM
    Marshall R
    Marshall
    none
    I had to run 40-44 PSI with the P rated tires in order to safely haul any real weight in my Tacoma. With the E rated tires I can run them at 30-35 PSI and still haul the same weights. At those air pressures there is no difference in ride
  18. Jul 9, 2020 at 2:34 PM
    gudujarlson
    Minnesota
    I agree with most of what you said, except for the risk and of splitting the rim at 65psi. I’m skeptical about that because I routinely put 100+ psi in my bicycle tires.
    Rockefelluh likes this.
  19. Jul 9, 2020 at 2:41 PM
    salty taco
    salty taco Distinguished Member
    USA
    2018 DCLB OR
    I just got new ridge grapplers 265/75/16 and the tire shop had them at 40 psi. The ride felt very rough so I aired down to 32 and it feels much better now.
  20. Jul 9, 2020 at 2:42 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    29
    3JOH22A likes this.
