Best option for chip/programmer
Discussion in 'Performance and Tuning' started by Logan22, Jul 6, 2015.
  1. Jul 6, 2015 at 10:59 AM
    Logan22
    Logan22 [OP] Well-Known Member
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Tonneau Cover, Tube Steps, Kenwood Excelon KDC X895, Boston Acoustics Speakers, 12 Shallow Mount Rockford Fosgate punch p3s sub, Rockford Fosgate Punch 400 watt amp 18 in. xd spy's 285 60 18 terra grapplers
    I have an 06 tacoma 4.0L auto and was wanting to get more power out of it. Especially in the lower because I drive back and forth to college on freeways going about 80 and it wants to shift down to 3rd every little hill you go up. I have 275/65/18 duratracs..I know that's not helping anything but I'd like to get more power all around but for sure some out of the lower end rpm range. I also have a flowmaster super 44 but I've read they don't do much. I've read a lot about the bully dog tuner and quite a few people on here seem to not like them or the customer service they have. I've also been looking at the urd reviews and it seems that a lot of people have the maf calibrator but if I understand right, it is only for when the engine is At wide open throttle. Id like to know if there are any other tuners or urd accessories that would do what I want. Also what exactly does the apr x-1 do and how expensive is it? Id prefer to stay under $600.
  2. Jul 6, 2015 at 11:01 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Under $600 you won't find a tuner that actually works for our trucks. You are an 06 so that's good, you can look at URDs UCON system, but it's pricey. There aren't really any cheap ways to get your truck to go faster
  3. Jul 8, 2015 at 9:28 AM
    Logan22
    Logan
    Kentucky
    06 Tacoma TRD 4X4
    Thanks for the info
  4. Jul 8, 2015 at 10:02 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You can also get a plug n play harness and wire a MAF Calibrator into it. That will gain you a little. Map-ECU 3 is the next better choice. There is also a Megasquirt.
    URD's UCON is the easiest as far as tuning is concerned.
  5. Jul 17, 2015 at 9:00 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    the maf cal will also help add power to the low end with a trade off in mpg.... I just got the unichip but not installed yet.... or one on of the urd controllers that can add timing, adding fuel helps a lot but mpgs go down, adding timing is free HP.... and the 4.0 runs at 18-20 while accelerating and that's way too low....
  6. Jul 18, 2015 at 11:11 AM
    eivad1
    eivad1 Active Member
    dave
    canyon lake ca
    2007 toyota tacoma 2wd
    stock
    why is it so hard to break into the computer and tune it
    mahaloTaco likes this.
  7. Jul 18, 2015 at 11:24 AM
    eivad1
    dave
    canyon lake ca
    stock
    people can hack into celebrity phones but not into car computers, wtf what is toyota hiding
  8. Aug 9, 2015 at 8:45 PM
    TacoDan723
    TacoDan723 Well-Known Member
    Dan
    Pacific Northwest
    2015 MGM Tacoma Limited
    Amazing when you think that they do this for every diesel that comes out and they make significant HP improvements! There were a ton of options for my Duramax!
