Best option for grounding battery cable to frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Apr 8, 2013.
  1. Apr 8, 2013 at 10:04 PM
    Crom
    Crom [OP] Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    What is the simplest way to run a new aux battery ground cable to the frame? I'm using #2 AWG cable with copper lugs. Would a large self tapping screw work? :help:
    This is for an auxiliary battery in the bed of my truck, not the primary starting battery. Thanks in advance.
  2. Apr 8, 2013 at 10:55 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I always bolt it to and existing bolt.
  3. Apr 8, 2013 at 11:13 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I would drill a hole, clean both front and backsides of any paint, use a bolt with a nut and a star washer against the frame on the backside and lug against the frame on front.
  4. Apr 9, 2013 at 12:30 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This. ^^^
    I always use copper bolts, nuts and washers also. A little locktight is also good.
  5. Apr 9, 2013 at 12:34 AM
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Sounds cool, If it is going to be hooked up to main battery, why not tie into main battery ground wire?
  6. Apr 9, 2013 at 1:30 AM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    It's a separate battery located in the rear of the vehicle. Frame is common ground.
  7. Apr 9, 2013 at 12:18 PM
    Crom
    Crom [OP] Outside
    Nick
    San Diego, CA
    Millions
    Thanks. Drilling a hole it is then. I'll have to go find a cobalt drill bit to do the work. :)
  8. Apr 9, 2013 at 12:56 PM
    nat
    nat Well-Known Member
    South San Francisco Bay Area
    2007 DC SB Tacoma
    Bestop, MP3 Aux Input
    On my rig, there is a factory ground at the rear of the truck. Look at the frame behind the drivers side rear wheel. I just hooked my battery up to it yesterday.
  9. Apr 11, 2013 at 11:07 PM
    03f5sp
    Bill
    Wisconsin
    Why would you drill a new hole when there are plenty of bolts that you can use instead of wasting time and money?
  10. Apr 11, 2013 at 11:24 PM
    Crom
    Crom [OP] Outside
    Nick
    San Diego, CA
    Millions
    I made the thread before I inspected the frame. So it was from a theoretical point of view. As it turns out, there is a 3/8 hole on the passenger side near the wheel well that's perfect for my application.
