Best option for replacing front brakes?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Robyn, Dec 3, 2013.
  1. Dec 12, 2013 at 8:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Chances are you do not. It is common practice at a dealer to recommend calipers with brakes mainly due to mileage and "wear" concerns on the hydraulic moving calipers. My best advice to you about those would be to cycle them and make sure they have a free range of motion when you are moving them all the way back in. If you want to move them a little easier crack open the bleeder screw on the caliper and push them right in. If they drag or fight you a lot when you are moving them back in, that is how you know they are fucked.
    Other then that if they have a good feel and are not wearing the pads uneven, there should be no reason to replace them.
  2. Dec 12, 2013 at 8:14 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That's the way to do it. Stealerships man..Here's some adjectives I like to use when thinking about them.
    https://www.youtube.com/watch?v=QnDxPG3KrtA&feature=youtube_gdata_player
  3. Dec 12, 2013 at 8:17 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    I got 235,000 on my calipers and they still work perfect....I think the dealer was just throwing that out there...
  4. Dec 13, 2013 at 6:10 AM
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    Replace your rotors with new Cross Drilled Slotted Rotors and install some good pads. That will improve your brakes on your Taco alot. I did and I could tell the difference.
    As for the rear brakes,..I like the rear drum brakes. Work good last looong time.
    While you are at it, installa set of Bilstein 5100's. Freekin awesome.
    Later
  5. Dec 13, 2013 at 6:22 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
  6. Dec 14, 2013 at 9:33 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bad idea on the cross drilled part. Those crack and can cause huge problems when it comes to getting them overly hot. If you want some better performance without compromise, slotted and maybe Kevlar pads are probably a good route to go. After owning a handful of cross drilled and seeing firsthand what has happened to them I would never buy or own a set on my vehicles ever again.
    Some of that Blue DOT4 brake fluid (I forget what brand it is but it is literally blue in color) is a great idea as well. That will really stiffen things up and give a more confident feel to the brake pedal too.
  7. Jan 4, 2014 at 6:32 PM
    Robyn
    Robyn [OP] Member
    Robyn
    NC
    07 Tacoma TRD Sport 4wd DC
    Thanks again for all the help. Turns out I had to change the calipers. Apparently this truck came from CA and saw a lot of salt water, so they were pretty rusty :(
  8. Jan 4, 2014 at 6:36 PM
    skabarbro
    skabarbro Active Member
    Aaron
    Pittsburgh
    08 TRD Off Road
    Brakeperformance.com
    Just ordered mine for my 08 Tacoma with 82k miles. Great options. Good price
  9. Jan 4, 2014 at 6:49 PM
    AMH3RST
    AMH3RST eat, sleep, work
    Mitch
    Las Vegas, NV
    06 PreRunner Dbl Cab
    Camburg +3.5" LT; King Shocks 2.5x8"; King Shocks 2x2" Bump Stops; Maxtrac 4" spindles; Deaver J66 leafs; King Shocks 12x2"; BAMF Rear Shock Relocate; KMC Enduro 16x9; BFG KM3 315/75R16; BAMF BTG Light Bar; 2 20" Toughlight Pro Series LED Light Bars; Cab Cage
    What is this blue brake fluid you speak of? I recently installed hawk ceramic pads with PowerShot drilled/slotted rotors and felt the difference on the way home from the shop. Had to stop fairly hard on a light that essentially went from green to red, thanks Vegas... No noise, idk about dust because I hit the desert often. But I'm happy with my choice.
  10. Jan 4, 2014 at 7:45 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Probably ATE Super Blue. They don't make it in blue anymore since Federal laws(As of Aug 15th 2013) forbids brake fluid to be any color other then yellow or clear.
  11. Jan 4, 2014 at 10:54 PM
    AMH3RST
    Mitch
    Las Vegas, NV
    Makes sense. I work at a Toyota dealer and if I saw anything but yellow I would recommend a brake flush..
  12. Jan 5, 2014 at 7:51 AM
    Fire Taco Fighter
    Fire Taco Fighter Well-Known Member
    trd
    search "brakemotive" on e-bay drilled and slotted rotors and ceramic pads they sell I put those on all my vehicles and lovem.
  13. Jan 5, 2014 at 3:32 PM
    Silence9
    Silence9 Solve et Coagula
    Alberta, Canada
    First off, welcome to the forums OP!
    I wouldn't go with drilled or slotted rotors either. There is less surface area for the pads to clamp on, thus reducing braking capacity. I have experienced they are also quite hard on the pads, and there is a chance of breaking or cracking them under high loads since there are weak points in the rotor.
    That's a shame you had to replace the calipers, they usually last years and years. As for the oil changes, get under there, you might learn a thing or two and have fun, get your arms dirty and save yourself some money. :)
  14. Jan 13, 2014 at 11:50 AM
    DaveHatz
    DaveHatz New Member
    Dave
    Elberta, AL
    2010 Tacoma Quad Cab
    This is a really good thread on brake replacements for the Tacoma, some really good input.
    I have a question on my 07 Quad Cab Tacoma. I notice when I come to a hard stop moving at fast speeds (I live in So. Cal, do I need to say more :) ), I notice that my steering wheel shakes pretty good, almost like the front end is out of alignment. I have new tires on her, about 10K on the tires. When I had the tires put on, mechanic told me truck didn't need an alignment. But, this only happens when I brake.
    I just rotated the tires last night and took a look at the pads and rotors, they all look fine. I have 46K miles on them.
    Can someone tell me why the shaking when I come to a quick stop?
  15. Jan 13, 2014 at 2:51 PM
    #35
    Dustenyourface
    Dustenyourface Member
    The reason your truck vibrates when the brakes are activated is due to rotor thickness variation. As brakes are used over time they deposit and remove particles on the surface of the rotor this creates a wavy surface that is not usually visible with the naked eye but is there. There are many ways to solve this, the most accurate way and the one I recommend to everyone is to use a procut on car brake lathe. This matches the rotor to the vehicle which is something a bench brake lathe can not do. You should be able to go to procutusa.com and find a shop in your area they also have a ton of info on why this is the best way to resurface rotors, even brand new rotors. I have serviced all automotive service equipment for the past 10 years and truly believe in this product(not a sales pitch)
  16. Jan 14, 2014 at 1:50 PM
    #36
    DaveHatz
    DaveHatz New Member
    Dave
    Elberta, AL
    I see different recommendations on which brake fluid to use. Is there a difference between the brake fluids u use?
  17. Jan 14, 2014 at 2:13 PM
    #37
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Hawk pads + rotors. Work way better then the stock stuff, and have never had a set get wobbly on me.
    Check out www.tapautoparts.com for awesome pricing on Tacoma brakes.
  18. Jan 14, 2014 at 2:15 PM
    #38
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    The pulsation or wobbly felt from bad brakes is to do pad material building up on the face of the rotor causing a variation in thickness like Dustenyourface said.
    The easiest way to prevent this is to use slotted rotors. It shaves the pad and while it does reduce pad life by 10-15%, it pretty much removes any chance of your brakes wearing uneven leading to that feeling.
