Best options for 2012 prerunner 6 cyc sparkplugs.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by phil2surf, Jun 23, 2017.
  1. Jun 23, 2017 at 9:09 AM
    phil2surf
    phil2surf [OP] New Member
    Phil
    2012 tacoma v6 access cab
    none
    What replacement plugs are you folks running out there? I am thinking about Iridium
    NGK LFR6AIX-11. The users manual is specific about replacement plugs, but various
    sources say these are ok to use, any thoughts or suggestions?
    ChadsPride likes this.
  2. Jun 23, 2017 at 9:23 AM
    DanoDavis
    DanoDavis Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    I just stick with the factory copper plugs.
    Denso K20HR-U11
    My truck is very modded as well, and I have zero issues with the copper plugs.
    Lester Lugnut, Gabezz and ChadsPride like this.
  3. Jun 23, 2017 at 1:20 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I use the irridium. Have had them in for 31k miles and so far so good.
    I don't care to have to changer copper plugs every 30K when I dont have to
  4. Jun 25, 2017 at 7:45 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I installed Denso iridiums in all of my Tacomas. They're cost effective and they work. Not designer or snake oil-ish, they just do the job.
    outlawtacoma likes this.
  5. Jun 25, 2017 at 7:51 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I'm running great on these.
  6. Jun 25, 2017 at 7:56 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    What I have heard is that not using the copper plugs and changing every 30k miles voids the emissions warranty, which I think is to 90k miles. Not sure if that is true, but just in case . . . I just stick with the stock Denso/NGK plugs since there is other maintenance going on every 30k miles. Easy to do, easy to remember, cheap, works great, and you know you've got good plugs.
  7. Jun 25, 2017 at 7:59 AM
    Plain Jane Taco
    USA
    Just in California, I believe
  8. Jun 25, 2017 at 9:07 AM
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    I actually just installed these in my truck yesterday. Stock plugs made it to 103k and look like they could have did 20k more. Truck feels a little more peppy and no issues with install. Good luck with your choice but the ones you specifically named seem fine.
  9. Jun 25, 2017 at 10:16 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    I recently swapped out my Tacos plugs at 39.5k miles. They looked decent but I was concerned with them since my trucks prior life was rough. I followed advice here and just replaced with denso plugs from the dealer. Hope it helps.
  10. Jun 25, 2017 at 10:22 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Wait, you ran stock plugs on a V6 for over 100k miles?
  11. Jun 25, 2017 at 11:57 AM
    Gabezz
    Gabezz Well-Known Member
    Gabe
    Los Angeles, CA (Montebello)
    '12 Tacoma TRD Off-Road DCSB
    Volant CAI w/Ram Air Scoop, Volant Throttle Body Spacer, Flowmaster SS Dual Exhaust, JBA Cat4ward Headers, Body Armor Side Steps, ProComp 3in Suspension w/Pro Runner UCA's and shocks, Various KC Hilites LEDs.
  12. Jun 25, 2017 at 12:33 PM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I go with the recommended denso's and change every 30k miles. I'm kinda boring I guess
  13. Jun 25, 2017 at 12:47 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Regular old copper Denso plugs. Can't be beat.
    Lester Lugnut likes this.
  14. Jun 25, 2017 at 3:34 PM
    Slow Internet
    Slow...
    Wiper Blades
    I bought the truck in april with 94k on it. Changed them yesterday at 103k. Had Denso on pass. side and NGK on driver side, so I assume it was still the stock set up. Plugs actually looked pretty damn good if they were indeed the stockers.
  15. Jun 25, 2017 at 5:44 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    That's what I have in my Taco and coming up on 96K with them. At 80K I took them out for inspection and the ground electrodes were quite worn out, to about .055'ish; gap should be .043. NGK recommends against re-gapping Iridium plugs, but I had no choice as I had no replacements on hand. I re-gapped and installed, and the engine be running as smooth as ever. I now have Denso SK20HR11 on hand to replace the NGK's. These Denso's have a platinum tip electrode to reduce wear.
    BTW, those same NGK Iridiums came stock on wife's Lexus ES350 and recommended plug change is 120K. I replaced them at 118K and have same ones on hand for replacement at 200K.
