best options to replace lift block
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Jun 3, 2010.
  1. Jun 3, 2010 at 2:33 AM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    I have a toytec AAL along with a 1.5" block in the rear as well. The AAl is great, but I do believe that little aluminum block is the bane of the truck's exsistence and the cause of some drive line vibrations. My question is, What is the best option to replace that block and keep some height on the rear end? Are shackles a viable option?
  2. Jun 3, 2010 at 4:34 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What's your total lift amount? Are you close to 3" of total lift WITH the blocks?
    I'd replace everything and get a new leaf pak that matches the lift you need.
    In terms of vibrations.... the LIFT is most likely causing the vibration (not the blocks themselves). It's probably drive-line vibes. Anytime you lift a truck - especially that much lift, you cause the driveshaft to operate out of its normal curve.
    Do you have any pictures of your driveshaft & pinion?
  3. Jun 4, 2010 at 2:36 AM
    4421.frank
    Southside chicago
    i could get a couple up in a day or two, would that help? specifically what pics do you wnat to see?
  4. Jun 4, 2010 at 5:00 AM
    Janster
    Jandy
    Lancaster, PA
    Does the vibration occur all the time while driving? Or does it occur at certain speeds?
    If the vibration is mild, we probably won't be able to see that in a picture (of the pinion & driveshaft/u-joint).
    Axle shims are your best bet for driveline vibrations. A 2 or 2.5 degree shim would probably be what you need (that's the smallest degree available). However - you can't use an axle shim with a lift block. Two options - research and look for a lift block that has a 2.5degree shim built in (I've never heard of something like this being available), replace the entire leaf pak with a 3" lift leaf pak (getting rid of the blocks & install axle shims).
    After all that - it's uncertain whether your vibrations are going to go away.
    Are you sure its not a bad balance on a tire? Bad wheel?
  5. Jun 4, 2010 at 5:04 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Just to add to what Janster has said make sure that you have installed a carrier bearing drop as well and if you need to fine tune it you can use washers to create the correct drop to correspond with your lift.
  6. Jun 4, 2010 at 5:24 AM
    Janster
    Jandy
    Lancaster, PA
    He can try a carrier bearing drop first...... (I've never been a fan of the carrier bearing drop - and why I didn't suggest it)
    But ultimately, if he uses axle shims - shouldn't need the carrier bearing drop.
  7. Jun 4, 2010 at 5:31 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    can u use angled blocks with a lift? cause thats what got rid of my driveline vibrations. that is, if your still gonna go with blocks
  8. Jun 4, 2010 at 6:32 AM
    Janster
    Jandy
    Lancaster, PA
    Yeah.... a block with the built-in angle would be ideal if he stays with blocks.
    I didn't know they even existed.
    You gotta list where you got 'em.....
  9. Jun 4, 2010 at 6:58 AM
    Kelson
    Kelson
    Honolulu, Hawaii
  10. Jun 4, 2010 at 9:35 AM
    Janster
    Jandy
    Lancaster, PA
  11. Jun 4, 2010 at 9:39 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    yup top quality stuff...the blocks are meant to fit our leafs and are longer than universal blocks.
    alot of us lowered trucks run his stuff....because most of the time we need to run blocks because leafs can only drop us so much...and its pretty much the best blocks out there
