Best Overland Bed Rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by irishrye, Aug 8, 2016.
  1. Jan 10, 2018 at 9:22 AM
    #161
    sjvicker
    sjvicker New Member
    does anyone know who makes this rack? [​IMG]
    solarservant likes this.
  2. Jan 10, 2018 at 10:04 AM
    #162
    cadamson
    cadamson Active Member
    CJ
    Black FJ TT
  3. Jan 10, 2018 at 11:22 AM
    #163
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Surprised no one has posted the LEITNER rack yet, just installed mine and I LOVE it. Its the most overbuilt rack I've seen on a Tacoma so far, the rear load bars extend down to the floor of the bed and bolt directly to the frame. This gives the rack a static load capacity of 1,000lbs and a dynamic load capacity of 500lbs. I've yet to see any other racks rated this high but I could be wrong.
    After cracking the ARE shell on my 1st gen and almost ripping off the topper on my 2nd gen I realized shells just aren't strong enough for what I need from them (able to carry 300lbs of gear while offroading HARD) and after looking at several other rack designs I wasn't really confident enough in any of them to load 300lbs and rip through whoops as none of them seemed to have proper cross bracing for dynamic loads. After speaking with the Leitner rack designer (Bernhard) it was clear this guy knew his shit, he's a full blown engineer and career fabricator, used to be the head of engineering for AMP Research.
    Haven't taken pics of my personal rack yet but here's a factory photo of the Leitner truck:
    The rack itself is incredibly light for its weight capacity, only weighs 68lbs! Plus its modular so I can slide the cross bars forward and still fit in my dirtbike, as well as being super easy to mount all sorts of accessories (rotopax, maxtrax, awning, Rtt etc.. it mirrors the bedrails system we already have). Also love the lockable storage box accessories (picture aboved).
    I know RCI, CBI, plefrey etc all make great stuff. But this rack downright blew me away. Only drawback is I think its the most expensive rack setup for our truck :/
  4. Jan 10, 2018 at 1:05 PM
    #164
    Double Phister
    Double Phister Punch it Chewie
    Sacramento, CA
    2017 DCSB TRD OR
    Looks like it's 250# off-road.
  5. Jan 10, 2018 at 2:01 PM
    #165
    Jaque8
    2017 Inferno TRD OR
    Yeah that's the harshest rating though, 500lbs dynamic is fine for the type of offroading most people do.
    The 250 is the rating for what I'm interested in, doing donuts and powerslides with my RTT on top :)
    Kinda makes me nervous that I couldn't find ANY other racks with an advertised offroad capacity. They all list static weight limits which doesn't really tell you much :/
  6. Jan 10, 2018 at 2:10 PM
    #166
    Double Phister
    Sacramento, CA
    2017 DCSB TRD OR
    Wilco Off-Road rack lists;
    On road: 400 lbs
    Light-duty off-road: 250 lbs
    High-speed offroad: 150 lbs
    Static (vehicle in park): 650 lbs
    Might be because part of the rack is floating above the cab.
  7. Jan 10, 2018 at 2:20 PM
    #167
    Jaque8
    2017 Inferno TRD OR
    Never seen a Wilco rack but good on them for publishing the vital information. I think other rack companies don't want to publish an actual # just for liability purposes which I kinda understand. Guys like me will throw all sorts of abuse to a rack and you can't really test for every possible real life situation so I think they just avoid it all together by not giving you a # at all.
    I was kinda shocked that I couldn't get straight answers on offroad capacity from a lot of BIG companies, I was still set on getting an actual shell but even when I contacted Snugtop about their "reinforced" shells that supposedly accommodate RTTs (I've cracked a shell before so I really wanted to know if the reinforced versions would avoid this) and all they could tell me is "500lbs max", when I asked does that mean 500lbs in offroad situations?? "NO"..... so whats the offroad rating? "Not rated, offroad at your own risk" (paraphrasing but it was something like that) totally avoiding giving me the info I actually need. I felt if I put even a 150lbs on the top of the shell and did a powerslide it'd crack just like my last one :/
    At least Leitner gave me a #... 250. 250 is what I can put on and be assured I can offroad fast and hard and not fuck anything up indirectly. They also said that's mainly for weight on the actual cross bars (which in my case is just my 130lb rtt so I'm about 50% load capacity there). The weight on the sides (cargo box, max tracks and fuel) isn't as important to the 250lb rating although its not easy to give me a separate answer such as "150lbs on cross bars and 175lbs on the sides is still ok". But with bed stiffeners and front cross bracing I did I'm pretty confident on my setup while offroading fast. I have 300lbs fully loaded on the rack with only 130 of that on top via RTT.
  8. Jan 10, 2018 at 2:22 PM
    #168
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    What model tent is that?
    NM you answered in a later post lol.
    Arlaghan[QUOTED] likes this.
  9. Jan 10, 2018 at 2:34 PM
    #169
    Arlaghan
    Arlaghan Well-Known Member
    Alex
    Redmond, WA
    2017 Red TRD Off-Road
    Tent is pretty bad ass. To save others from paging, it's Mt Shasta Summit plus the 55" Summit awning off the back.
    Superman likes this.
  10. Jan 10, 2018 at 3:10 PM
    #170
    Dudeman86
    Dudeman86 Well-Known Member
    Scottsdale, AZ
    2016 Black DCLB OR
    I spent a lot of time in this thread before deciding on having one made. I was able to pick what I liked about several models and incorporate them into this rack.
    Made by @JeepAndrew near Tucson.
    I wanted to still be able to reach into the and grab stuff, so low profile was ideal. Also, note the rotopax mount bar is curved inward slightly. This will make it harder for branches and other trail hazards to catch the can and rip it off. I can also reverse the monkey fist mounts to the opposite side, or have another set of mounts created if I want to hang other items.
  11. Jan 10, 2018 at 7:37 PM
    #171
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    I like idea of headache rack i wondered why you extended it abit past cab. Woukd this interfere with a shell? Or would the shell fit with just the cabrack
  12. Jan 11, 2018 at 6:40 AM
    #172
    Dissent86
    Dissent86 Well-Known Member
    Ben
    2016 trd offroad Tacoma.
    The shell would fit just fine.
    I do however plan to make a cab/canopy rack combo as well.
  13. Jan 11, 2018 at 12:59 PM
    #173
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    The most expensive I've seen is Nutzo...which is a good name for their prices, especially when you add options.
  14. Feb 17, 2018 at 4:54 PM
    #174
    Hal9001
    Hal9001 Well-Known Member
    KB Voodoo - on your premium bed racks - are the lengths of the uprights between the 18" & 10" interchangeable? or not because of the angles created? I'm just thinking if I start with the 18" and then also want a 10" for other times is that a whole new rack?
    And also do you still have any forum discounts?
    thanks
  15. Feb 17, 2018 at 6:17 PM
    #175
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    You might want to check out this thread KORE Bed Bar group buy. and possibly also this one , second post Introducing KORE
    He fabricates custom designed bars, racks and other stuff. Good luck!
  16. Feb 18, 2018 at 2:31 PM
    #176
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The crossbars aren’t interchangeable because of the angle.
    Pm inbound for the discount.
  17. Feb 19, 2018 at 7:30 PM
    #177
    AGENT-X
    AGENT-X Well-Known Member
    Austin, TX
    13' DCLB 4x4
    Current: 2018 TRD ORP 4runner Eibach pro truck lift TRD pro wheels 2013 Tacoma DCLB 4x4 5100's all around, 885s front, rear ToyTec AAL and Ride Rite Airbag rear. 265/75/16 BFG AT KO2. Previous: 2007 DCSB TRD OR Toytec OME 3" w/ 885s, TC UCA's, 265/75/16 BFG MT's
    Will the maxtrax not connect to the mid height rack? Looks like you have a modified connection in the pic.
  18. Feb 19, 2018 at 7:42 PM
    #178
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Maxtrax does indeed work on the mid height rack.
    AGENT-X[QUOTED] likes this.
  19. Feb 19, 2018 at 8:16 PM
    #179
    AGENT-X
    Austin, TX
    13' DCLB 4x4
    Thanks for the quick response.
  20. Mar 2, 2018 at 2:25 PM
    #180
    TacoBe11
    TacoBe11 Member
    Tim
    Hayward, California
    17 TacO TRD off road
    Anyone knows of a rack that would fit over the factory bed cover for a 3rd gen short bed?
