Best paint for sliders?
Discussion in 'Off-Roading & Trails' started by Mxpatriot, Jan 19, 2010.
  1. Jan 19, 2010 at 4:26 PM
    Mxpatriot
    Mxpatriot [OP] Well-Known Member
    '06 4x4 AP LT and Locked
    Been spraying them with black krylon for a while and it's getting old repainting them constantly. They'll peel from heavy rain, and the minute they touch dirt or a rock all the paint in that area is gone.
    I primed them, and then put three coats on...what gives?
    they're welded on the truck, so I'm limited to stuff that can be done with them on the truck. would also prefer stuff i can do myself to save some coin.
  2. Jan 19, 2010 at 4:28 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    well i think linex would work the best but ur talking 150 bucks
  3. Jan 19, 2010 at 4:30 PM
    BravesFan
    BravesFan The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    bedliner?
  4. Jan 19, 2010 at 4:43 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I talked to Jason Demello about a set for my truck (have to wait for some funds to free up and don't really need 'em till next summer at this point), and when I asked about possibly using line-x instead of powdercoat (to get a matte rather than gloss look), he said it can be done, but the liner will fall off in sheets when the bars get bumped. Apparently is has something to do with bedline being so much better at adhering to itself than to the metal the bars are made of.
    Have you tried something like engine enamel? That might give you better adhesion to the metal. You could also look into some sort of epoxy paint, but most forms of that stuff will cost double or triple what it should just 'cause you may have to go to marine or aviation supply to get it.
    Might try asking a local body/paint/hotrod shop in your area, they might know what's got the best grab on steel or have some tips on surface prep.
  5. Jan 19, 2010 at 5:21 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i've been using spray bedliner rattle can style from auto zone, etc, and only tie i've had to retouch is after taking long gouges from rocks
    C41n likes this.
  6. Jan 19, 2010 at 9:47 PM
    DuderAbides
    DuderAbides Well-Known Member
    Tom
    Vista, CA
    2010 DC SB TRD OR 4X4
    I'd like to ask a small question as well regarding painting sliders and armor in general, what paint would one use if they were painting their sliders/armor a different color...IE bronze?
  7. Jan 19, 2010 at 9:49 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I used rustleum hammered on mine. Sucks. So I will be masking and doing spray on bedliner.
  8. Jan 19, 2010 at 9:51 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    yea that bedliner would be the best... and toughest as far as rattle can...
  9. Jan 19, 2010 at 11:04 PM
    DuderAbides
    Tom
    Vista, CA
    could you use bedliner as a primer per se? Throw down a coat of that, and then use the color paint you intend to go over it?
  10. Jan 19, 2010 at 11:20 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I suppose you could. But if the paint color chips or scrapes you will have to keep touching it up.
  11. Jan 19, 2010 at 11:22 PM
    DuderAbides
    Tom
    Vista, CA
    naturally, but I really can't think of a heavy duty spray paint, with the exception of maybe krylon to use to paint sliders and armor?
  12. Jan 19, 2010 at 11:26 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    No matter what you coat it with, rocks will be scrapping the sliders. Nothing is going to hold up to a rock.
    slander and bagleboy like this.
  13. Jan 19, 2010 at 11:34 PM
    DuderAbides
    Tom
    Vista, CA
    not dis agreeing with you on that at all, but i'd assume you'd have to touch up just as much with bed liner as you would anything else. I'm just curious as to what would hold best to the metal, i'd assume that krylon rattle can paint, im sure i'll be able to find it in the color i want.
  14. Jan 19, 2010 at 11:36 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Well, when offroading for me, most scratches from rocka are on the bottom of my sliders. So I just spray that really quick. Scrathes from bushes and what not are on the side of them, but those are not strong enough to take the paint off.
  15. Jan 20, 2010 at 3:11 AM
    The_Hodge
    SC
    bedliner wont just fall off w/ rain like the OP was talking about. only touchups i've had were gouged to the metal from rocks that any material would have to redo...bedliner keeps my vote. rattle can is the best since it doesnt cost shit to do it urself and touch it up
    C41n likes this.
  16. Jan 20, 2010 at 11:37 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I used Krylon fusion in a satin finish and it's help up beautifully. I didn't even prime it because you don't have to with that line of paint. I sprayed two coats and it's been rained on, mud thrown on it and used om some rocks. Obviously you will need to repaint them if they get mangled on rocks, but that paint has done really well for me so far.
  17. Jan 20, 2010 at 11:43 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Bedliner on the top of the sliders for traction when standing on them.
    Rattle can the underside because that part gets all ripped up no matter what. Easiest to touch up the underside with spray paint.
  18. Jan 20, 2010 at 11:48 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Rustoleum Flat Black. I used 3 coats to start when I got my Sliders in October. Ive had to touch them up 2x since then due to trail runs. I know what you mean about the paint comming off. I use my sliders as steps and the driver's entrance area of the sliders comes down to bare metal about every 6 weeks due to wear, I guess. I just get used to touching them up and remember that it only costs me $7 for a can of paint instead of $$$$ to powdercoat them for a more solid finish.
  19. Jan 20, 2010 at 12:25 PM
    Masada
    Taylor
    Laveen, AZ
    If you don't want to take the time to do the bed liner and still want grip for the tops, then look at 3M grip tape it's cheaper and works just as good :)
    That's what I have for the tops of mine and it's great. I only used one role for both sides; I was originally going to go with bed liner but it was going to be too time consuming to tape off and what not. This was much faster and has held up great. Just another idea :D
    remgu2000 likes this.
  20. Aug 15, 2010 at 10:58 AM
    IamTacO
    IamTacO red balls got me!
    adam
    QC az
    01 Prerunner SR5 TRD-Offroad
    4x2 Prerunner. Hankook Dynapro ATM rf10 265-65-16, e-locker FTW! Morimoto d2s bi-xenon HID projectors, Philips 85122+ 4300K, Cobra 75 w/ 3' firefly, Kenwood KDC-MP342U w/ SIRIUS, Line-x bed liner, 4' coretrax(black)
    since i have zero rattle can ability, i was just going to use a dark grey primer vs a paint. i'm guessing it should be fairly easy to maintain. debated on whether or not to use a clear coat to seal the primer layers, but in the end, it will get scratched off as well. don't think i'm going to put too much thought into the painting process. i'm sure it will get scratched up just during the weld on portion of this. i'll let you know how it comes after the install. worse case scenario is that i tape off the truck and paint them after the install.
