Best phone mounts for Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patrickday, Jan 12, 2019.
  1. Jan 15, 2019 at 1:11 PM
    #61
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    FINALLY installed a real mount yesterday:
    Panavise mount ($28, which mounts beside HVAC controls) + Pro-Clip Small-Medium Phone Holder ($35 with discounts). I custom cut some panhead machine screws to mount the Pro Clip to the Panavise . Its an expensive setup, but the holder should be reusable on future vehicles, and someone here will always be looking for Panavise mount. Works great with the iPhone 8 Plus and UAG case.
    I was tired of the Maps not rotating 180 degrees during GPS use in the cup holder..and wasn't a fan of the cheap $5 vent mount dropping a $900 phone while the cord was connected.
    Its unfortunate that proclip didn't make a good mount for the 05-15 Tacoma (left hand vent location is stupid, and next to the shift lever also isn't the best location.)
  2. Jan 15, 2019 at 1:55 PM
    #62
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I wanted a clean look but practical and cheap so I added a USB charging port with a $15 macally phone holder. Works great.20190115_153852.jpg
    Dominic4Lo likes this.
  3. Jan 16, 2019 at 12:53 AM
    #63
    Murauder
    Murauder Well-Known Member
    Adam
    2014 MGM TRD Sport DCLB
    The list is long, but distinguished.
    Upgrade your radio; I keep my phone in my pocket, wireless android auto, and CarPlay are a thing now. :thumbsup::cheers:
    Reggie4x4, cleats50, kidsmoke and 5 others like this.
  4. Jan 16, 2019 at 5:39 AM
    #64
    ctcz28
    ctcz28 Well-Known Member
    Texas
    2015 Blue Ribbon Metalic DCSB Prerunner
  5. Jan 16, 2019 at 8:21 AM
    #65
    righty
    righty Well-Known Member
    2015 Access Cab i4 4WD
    BFG K02, Ultra Vagabond wheels, Truxedo Lo Pro Q Tonneau cover, Pop lock
    I have this one that goes in the CD slot. It requires you to put a small plate of metal (included) in the back of your phone case and via a magnet the phone stays on. I have had this for about a year in my truck and car, and it works great. Very good for position for using the phone as GPS and does not interfere with seeing the LCD. However, if you are out in the trails a good bump will probably knock your phone off.
    https://www.amazon.com/gp/product/B016GNYZIC/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
    71tattooguy and 05 4x4 like this.
  6. Jan 16, 2019 at 9:00 AM
    #66
    rg37
    rg37 Active Member
  7. Jan 16, 2019 at 4:28 PM
    #67
    Neil O
    Neil O Active Member
    Neil
    Beverly MA
    08 quad cab 4x4
    I got a couple ram balls iirc from the mfg, they are all over amizon though
    HawkShot99[QUOTED] likes this.
  8. Jan 18, 2019 at 1:53 PM
    #68
    patrickday
    patrickday [OP] Member
    Todd
    2015 White Tacoma Prerunner Crew Cab 4.0
    I definitely want to do that in the near future. Just a matter of getting funds to get a newer unit. In the meantime I don't have GPS unless I use my phone. Therefore the need for something.
    swirkus likes this.
  9. Mar 14, 2019 at 9:35 AM
    #69
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Got a Bestrix magnetic phone mount which of course isn't available anymore and tried it out in a few different places using the adhesive backing. When it fell off I'd try a new location w/new 3m. Finally settled on under the middle passenger vent which keeps it down out of the glare, up in my view for nav, and clear of all controls including not blocking any vents. When I did my anytime F/R camera mod I drilled through the radio bezel for a permanent attachment. Screw is hidden by hinge. B70E96DA-D819-4000-9A6C-89D4C0001E06_zps_af7c5eb9db25fb6ea12ffd83724d49f7cf1e3970.jpg
    rightcoastsurf likes this.
  10. Mar 14, 2019 at 10:58 AM
    #70
    rightcoastsurf
    rightcoastsurf Well-Known Member
    Va Bch, VA
    14 MGM double cab PreRunner
    WeatherTech digifit mats, map & dome lights LED mod, rocky mount bike mounts, Toyota fog light kit, SALEX center console organizer, tailgate theft mod, Westin Nerf bars, toyota bed mat, backseat dual USB ports, gasshole, quickfist bedrail mount, class 3 hitch, intermittent wiper switch
    67 designs - https://www.67d.com/collections/cf-carbon-fiber-series - suction cup base, carbon fiber arm and universal aluminum squeeze holder. Easily swaps between cars if needed, fits a variety of phones/gps devices and have had no issues with suction cup coming undone while moving.
  11. May 1, 2019 at 8:07 AM
    #71
    NorthGARob
    NorthGARob Member
    Rob
    North Georgia
    2017 Tacoma TRD Off Road Manual Trans
    TheNorthStar likes this.
  12. May 1, 2019 at 9:31 AM
    #72
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    others have a similar setup woth the ram mount...non permanent solution if you want to be able to make the truck stock again.
    KTM753 likes this.
  13. May 1, 2019 at 12:21 PM
    #73
    bgreyc
    bgreyc Well-Known Member
    Brad
    Albuquerque, NM
    '19 Silver TRD Off Road DCLB
    Lighting: BD S2 Sport Flush Mount Rear Bumper Lights (Work) BD Squadron Pro Driving/Combo Fogs (Amber) BD S2 Pro Ditch Lights (White, Off Camber Hood Bracket) KC Hilites Cyclone Under Hood Lights KC Hilites Cyclone Pair - Shell Lights 30" Rough Country Black lower grill light bar Raxiom Bluetooth Light Switch Accessory Controller Suspension Teraflex 2" Falcon Load/Haul Suspension Tires BFG T/A KO2 C 265/70R-17 Wheels Fuel Wheels - Vector Gun Metal (17x8.5) MESO Mods Coin Tray Dome Light Map Lights Key Fob - Orange/Red Keys @OneMoreTaco Radio Knobs TRD Pro Grill - Runnin4Tacos ARB Single compressor (Underhood) GTFO Expedition Compressor Bracket Runnin 4 Tacos - White Grille Lights - 4 Caliraised Bed Stiffeners Redline hood struts Bedrug Bedliner KTJO4x4 Tail Gate Auto Lock Kit Dual camera setup - Anytime front/rear Camera Runnin4Tacos - TRD Off Road Emblems Victory Blitz Rock Sliders Victory Top Rack Ordered (delivered, need time) Victory 4x4 Center Console Molle Wish List Victory 4x4 Blitz Front Bumper Victory 4x4 Strike Rear Bumper
  14. May 1, 2019 at 2:59 PM
    #74
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    No, you must have a newer version? Mine is just a magnet. And I have an iPhone 6s so it has to charge plugged in :(
  15. May 1, 2019 at 4:54 PM
    #75
    SocalTRD619
    SocalTRD619 Well-Known Member
    Adam
  16. May 1, 2019 at 5:57 PM
    #76
    huskies
    huskies Well-Known Member
    Northern Virginia
    2014 Double Cab Limited 4x4 long bed
    5100s/885s/AAL/ TRD PRO Sema’s / KO2’s
    F2C8C3CA-D382-492D-87F8-89B964AC1398.jpg 6F345817-2CA9-4204-BB6D-29AC43DFF2D8.jpg DCE8B928-0470-4292-A28E-B96868EA9349.jpg
    Three options.
    wi_taco and hresendiz25 like this.
  17. May 5, 2019 at 6:05 AM
    #77
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
  18. Jul 22, 2019 at 7:32 PM
    #78
    swirkus
    swirkus Member
    2019 TRD Sport Access Cab - Cement
    Snugtop canopy
  19. Jul 22, 2019 at 10:14 PM
    #79
    Pet
    Pet Member
    2019 Toyota Tacoma TRD Pro
    No. It stays open.
    swirkus likes this.
  20. Jul 23, 2019 at 4:09 AM
    #80
    KTM753
    KTM753 Well-Known Member
    How did you get the Ram ball to attach to the Grey radio surround? Adhesive? Hardware?
    hresendiz25 likes this.
