Best phone mounts for Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patrickday, Jan 12, 2019.
  1. Jul 11, 2020 at 12:40 PM
    #161
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    I feel pretty confident that nobody else has my setup, but I love it.
    My phone has wireless charging so the mount had to have that. Had to be pretty beefy, as lots of mount look pretty chinsey.
    I bought this mount for my motorcycle and loved it so much that I decided I needed to see if I could install in my truck.
    I have a Techdeck installed under my stereo, that I like to have the phone mounted on because of the location. Unfortunately this motorcycle mount is set up to clamp onto a handlebar. There is a extra piece that comes with it that can be bolted to a motorcycle's mirror stems. I felt that was the best rout for me to take. Unfortunately the holes for the techdeck are to small to put the right size bolt through, so I had to drill a larger hole in the techdeck. I them put a bolt through the included adapter and attached the phone mount.
    (the loose wire is for my work headphones, I just store them behind the mount.)
    I really like the mount as its super solid. When putting the phone n the mount, as the tiny dot in the center gets pressed by the phone, the corner supports snap close and hold the phone tightly(tight enough that I trust it as I drive my motorcycle). To open it, just squeeze the tabs on the side of the phone and it opens easily.
    They mount came with a 6-8' wire that ran into the engine bay to my auxiliary fuse panel. I set it up as always on so the phone can charge when the truck is turned off.
    https://www.amazon.com/gp/product/B07YQ3K49C/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&th=1
  2. Jul 20, 2020 at 3:48 PM
    #162
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
  3. Aug 3, 2020 at 2:28 PM
    #163
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    Do you have a link to that one? I bought one that slid into the CD player, but it was total junk. That one looks much better.
    Thanks.
  4. Aug 3, 2020 at 2:30 PM
    #164
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Here ya go
    SCOSCHE MAGCD2 MagicMount Universal Magnetic Phone/GPS/Tablet CD Slot Mount for the Car, Home or Office https://www.amazon.com/dp/B01MYHD29Y/ref=cm_sw_r_cp_apip_sE6rqKDIYP21Z
    gavonder[QUOTED] likes this.
  5. Aug 3, 2020 at 3:23 PM
    #165
    Ross09
    Ross09 Well-Known Member
    Greeneville,TN
    2009 DCLB base 4x4
    Tech deck and a ram mount is the way my friend
  6. Aug 3, 2020 at 4:14 PM
    #166
    wbeard365
    wbeard365 New Member
    2015 Sport 4X4 DC Long Bed
    Stock
    This I like
  7. Aug 22, 2020 at 4:21 PM
    #167
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Biscuits likes this.
  8. Aug 22, 2020 at 4:31 PM
    #168
    Mr.Pink Taco
    Mr.Pink Taco Well-Known Member
    Tim
    Jersey
    2020 TRD Pro Black
    Minor stuff.
    I have a ProClip iPhone holder with a RAM base screwed directly into the center console and I run the USB wire u der the console to the USB plug. Works for me, out of the way and works with CarPlay. And it’s very easy to get to the phone if I needed to.
  9. Aug 23, 2020 at 7:10 AM
    #169
    gavonder
    Ct
    pdaddy[QUOTED] likes this.
  10. Aug 23, 2020 at 7:15 AM
    #170
    pdaddy
    Preston
    Central AL
    :thumbsup:
  11. Sep 16, 2020 at 7:31 PM
    #171
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Next to and above the 4wd knob.
    Sig45[QUOTED] likes this.
  12. Sep 17, 2020 at 2:36 AM
    #172
    Sig45
    Mark
    Maine
    Thanks. Can you share a pic?
    Biscuits[QUOTED] likes this.
  13. Sep 17, 2020 at 3:40 AM
    #173
    Biscuits
    I'll post one this afternoon.
  14. Sep 17, 2020 at 3:44 AM
    #174
    Sig45
    Mark
    Maine
    Appreciated!
  15. Sep 17, 2020 at 5:04 AM
    #175
    Sig45
    Mark
    Maine
    Here's what I'm dealing with. I don't really want anything with a long arm (want to keep it as inconspicuous as possible). I'm now using the Wizgear vent magnetic mount and it works great. But with fall/winter approaching, I don't want the heat blasting directly on the phone (can't close the vent with the mount attached).
  16. Sep 17, 2020 at 6:53 AM
    #176
    HawkShot99
    Kingston, NY
    I originally had a vent mount holder but had to ditch it because of the heat overheating the phone come winter.
    My solution was to install a Tech-deck under the stereo. I then just attached the vent clip to the metal lip. I have since switched to a different non-vent style mount, but still use the tech-deck. Its got. Great location soni can use the GPS very easy while driving, but doesn't block my dash at all.
    http://www.birddawgindustries.com/tech-deck.html
  17. Sep 17, 2020 at 4:12 PM
    #177
    Biscuits
    It looks like where I mounted mine is not going to work for you unfortunately because of the slight interior differences between the 2005-2011 and 12-15 Tacomas. :(
    Here is where I have mine mounted:
  18. Sep 17, 2020 at 4:14 PM
    #178
    Biscuits
    @Sig45
    The open area on your radio by the CD eject button may work. The adhesive used for the mount of the Mod mount is extremely strong.
    Sig45 likes this.
  19. Sep 17, 2020 at 4:15 PM
    #179
    Sig45
    Mark
    Maine
    :fistbump:
    :annoyed:
  20. Sep 17, 2020 at 4:17 PM
    #180
    Sig45
    Mark
    Maine
    Hmmmmm...that is my preferred location.
    That surface is pretty slick/glossy and textured.
