Best phone mounts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CNEDEER, Jul 20, 2022.
  1. Jul 23, 2022 at 9:24 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    I used one about 25 years ago for a 800 mhz portable radio I had to carry around and really liked the set up. In fact I still have the goose neck, that thing is indestructable. Thanks for the link.
    mark_tga[QUOTED] likes this.
  2. Jul 23, 2022 at 9:25 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  3. Jul 24, 2022 at 10:27 PM
    mark_tga
    mark_tga Well-Known Member
    2015 Tacoma DCSB
    If you're going to use it to hold a phone you can run a wireless charger to it. I took mine apart, ran the wire from the charging pad down the goose neck inside the tubing. I used 3m tape to stick the pad to the phone cradle and now I can charge wirelessly with a mostly hidden wire. I ran the wire from the charging pad to my center console where I wired a dual USB charger.
    BlkDakDave[QUOTED] likes this.
  4. Jul 24, 2022 at 11:12 PM
    CharlieTaco
    CharlieTaco '95 long travel - Korea to Kentucky
    Charlie
    Lexington, Kentucky
    95 Tacoma Xtra Cab 2.7 L 4X4
    Solo Motorsports LT & UCA double-shear Fox Factory Series 2.5X8" coilovers and hydro bumps Anonymous Fab uniball-converted LBJs Heavy Friction Works gusseted spindles All-Pro cam tab gussets Advanced Fiberglass 3.5" fenders OME Dakar leaf pack and OME bushings OME greaseable Tundra shackles Bilstein 5125 10" stroke in factory location BFG KO2 33X10.50R15 Husky front floor liners ACC carpet - Oak color '01-'04 style side-view mirrors black door handles Hella H4 E-Code headlight housings/Philips X-treme Vision H4 bulbs BH3D Printing double cup holder Siless sound deadening 72 sq ft Noico Red 72 sq ft Custom stereo - removed
    look into Pitaka magnetic mounts.
    If you have an iPhone with MagSafe it will stick right on to the charger mount via the magnets built into your iPhone (even stronger if you have a "MagSafe" compatible case). If you also use Pitaka's magnet case, then it's even stronger than just using your phone or a typical MagSafe compatible case. The charger can also charge your phone wirelessly so you don't have to plug in your phone with cable.
    They also have cases for Samsung phones that make your phone compatible with their magnetic mounts.
    I've used the traditional type of mount and they are so annoying to fiddle with. Pitaka is the way to go! When I get in the car, there's no fiddling with those plastic mounts. Just get it close and the mount/charging pad sucks it right up. I've also never had an issue with the magnets failing. They are really strong.
    Another one worth looking into is the Anger MagSafe (or maybe they call it "MagGo") car mount. I haven't tried it myself but I've been meaning to because it mounts on the dash rather than windshield or air vent.
  5. Jul 25, 2022 at 5:16 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I would love to see more photos of everyone's setup.
  6. Sep 27, 2023 at 7:43 AM
    15ACOR
    15ACOR Well-Known Member
    2015 TRD OR
    The ram mount x-grip is absolute garbage. Toddler hands would be more reliable. My large phone in an otter box falls out at the slightest vibration
  7. Sep 27, 2023 at 8:36 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    OffRoam hands down. Best phone holder I’ve had. Sturdy all metal design. Quality is excellent.
