Best place for lift install? SonomaCounty
Discussion in 'Northern California' started by TacomaTSP4, Oct 11, 2009.
  1. Oct 11, 2009 at 8:15 PM
    TacomaTSP4
    TacomaTSP4 [OP] Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    I just wanted to know if anyone knew of a good cheap place for a lift install because i dont have a spring compressor or the heavy duty tools to install. Thanks
  2. Oct 11, 2009 at 8:25 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    What kind of lift are you doing? A spring compressor can be borrowed from most auto parts stores. If you dont mind going to sac... i could help you here.
    Actually I think i might just buy a spring compressor.
  3. Oct 13, 2009 at 7:33 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    you can install rear blocks, rear shocks, and rear AAL's? what about install a front coilover and diff. drop kit?
  4. Oct 13, 2009 at 7:35 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    What type of coils/ shocks did you get? We just had a mod day on Saturday and are probably having another in about a month or so if you want to wait until then.
  5. Oct 13, 2009 at 7:52 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    i bought OME coils, TRD bilstein shocks, and coil spacers. and im installing rear TRD bilstein shocks and rear blocks with also AAL's.
    Damn thats nice. everything should arrive within the next week.
  6. Oct 13, 2009 at 7:55 PM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    would i be able to run 265/85/16 M/T's on about a 4" lift in front and 3" in rear?
  7. Oct 14, 2009 at 9:09 AM
    PreRunnerSeth
    Apex, NC
    I can help you install any of that. but you wont get 4" lift with that. 3" is about the limit for the front before you run into major issues with suspension geometry. to go higher than 3" on a 4x4 you need a bracket drop lift.
  8. Oct 14, 2009 at 11:36 AM
    TacomaTSP4
    Travis
    Rohnert Park, CA
    i cant run lift springs that give 1.5" or 2" of lift and run a 2" to 3" coil spacer on the front? whats the bracket drop kit?
  9. Oct 14, 2009 at 1:15 PM
    PreRunnerSeth
    Apex, NC
    No... any of these kinds of lifts mess up the stock geometry. 3" max before you encounter clearance issure with upper control arms and coild buckets mostly. a drop kit uses a large bracket to relocate the mounting position of the lower control arms among other things. this allows you to get more clearance on a 4x4. The drop bracket kits are usually 6". you sould spend some time in the suspension section. if you need more info on lift choices let me know
