Best place to buy replacement steering rack
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacovic, Apr 22, 2011.
  1. Apr 22, 2011 at 5:43 PM
    tacovic
    tacovic [OP] Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    As the title states, where is the best place to get a replacement steering rack for my 00 tacoma.
  2. Apr 22, 2011 at 6:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Try rockauto.com ,they have awesome decks and customer service.
    What's going on with your rack? Leaking,worn out?
  3. Apr 22, 2011 at 6:58 PM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    Thought it was my power steering pump but its the seals leaking on the rack. Need to be replaced. Mechanic quoted me 1200 bucks and i said screw that ill do it myself.
  4. Apr 22, 2011 at 7:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    damn....don't blame you there.
  5. Apr 22, 2011 at 7:54 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Trailgear. Just ordered mine today.
  6. Apr 22, 2011 at 8:07 PM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    did your seals leak too?
  7. Apr 22, 2011 at 8:23 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    How bout for 2nd gens? Cuz alignment shop said i needed new inner tie rods :/
  8. Apr 22, 2011 at 8:28 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    No, I just got play in it and when its aligned in specs, the wheel is still to one side and truck pulls the second I let go. Gonna replace rack,bushing, and now probably tac weld steering shaft. Better fix this sh*ty steering.
  9. Apr 22, 2011 at 8:47 PM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    I work at Carquest and priced one today for 280
  10. Apr 22, 2011 at 8:53 PM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    Is that for the whole rack? And I am assuming its rebuilt? Is there a warranty?
  11. Apr 22, 2011 at 8:56 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I have a first gen and when i went in for an oil change (Bud built skid for $24 its worth them dealing with it) He told me that both my inner TRE needed to be replaced. After about 30 seconds in the driveway i determined it was my rack bushings not the TRE's.And these people want my bussiness:rolleyes:
  12. Apr 22, 2011 at 10:05 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Dude, TRE's are a breeze to replace...you don't need to be finding prices on a new steering rack. Pop the ball joints where they connect with the steering knuckle and unscrew the TRE's from the shaft...20 minute job per side. Then replace.
    OP....I replaced my rack with a reman'd one from NAPA for $230. Works well with 30k and counting. Not hard to replace either. Good luck and let us know how it turns out.
  13. Apr 22, 2011 at 10:11 PM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    Do you think its worth going with toyota OEM?
  14. Apr 22, 2011 at 10:55 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    The guys who did my alignment said my steering rack that needed to be replaced and wanted like 800 bucks!! and all it needed was new bushings and installed them myself.
    but mine was not leaking just let the tires shake back and forth.. but now its fixed!
  15. Apr 23, 2011 at 6:40 AM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Its prolly easier on a first gen, cuz i've already replaced my rack & pinion andit took me like 2 days to do it. Its so freaking hard to manuver in there, you have to take off both wheels, sway bar, disconnect everything, lower shock stud, then you have to push the rack in all the way to one side and bring it back to the other while twisting. Fak! Im, sure I need Inner tie rods, (outers are easy to replace) but I just don't wanna go through that hassle again, its such a pain. :laugh:
  16. Apr 23, 2011 at 9:30 AM
    NegroTundra
    Land of Enchantment
    Some would say yes, I say no. Somethings are worth sticking to OEM, but since my OEM rack only lasted 53k, I was willing to try a cheaper alternative. I generally trust NAPA parts.
    frenchee likes this.
  17. Apr 23, 2011 at 10:07 AM
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    yup whole rack, reman, with limited lifetime warranty
  18. Apr 23, 2011 at 2:06 PM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    I ordered a rack from autozone, cuz I work there and it turned out to be different. I think 2wd is different from 4wd, but they still sent the wrong one. O'Reallys have the same part number, i'm pretty sure it wouldn't work. The fitting was reverse and different than my oem rack.
  19. Apr 25, 2011 at 8:20 PM
    alove0750
    Adam
    Concord, NC
    2015 DCSB 4x4
    2wd and 4wd use the same rack. mine was 2wd when i bought it and has since been convert too 4x4. 96-03 have the same suspension set-up, brakes, etc...
