Best place to connect recovery strap?
Discussion in 'Towing' started by Silence9, Jan 12, 2014.
  1. Jan 12, 2014 at 12:40 PM
    Silence9
    Silence9 [OP] Solve et Coagula
    Alberta, Canada
    Hey everyone. What is the best place to connect a recovery strap to 2nd gen Tacomas? There are those two holes in the steel near the receiver, or the receiver itself? Is it safe to put the loop inside the receiver and hold it in with a pin? My ex hit the ditch twice in one day and I didn't have a strap in my truck so I am in the market for a 3" 30' one. Thanks in advance for any input. :)
  2. Jan 12, 2014 at 1:07 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    The receiver is the best place. A couple companies sell shackles that go in the receiver. I have a warn one and its worked very well for me.
  3. Jan 12, 2014 at 1:21 PM
    Silence9
    Alberta, Canada
    Like as in a D-Ring, or just a heavy duty pin? I've heard using those D-Rings is just about as bad as using hooks.
  4. Jan 12, 2014 at 1:26 PM
    Tacoma Mike
    Southern Maine
    The main idea is not to twist the frame while pulling. A center pull is the best.
    Some use a insert with a d ring, some a hook. A loop and pin will work.
    I try to stay away from a loop end and hook. Seen some disconnects that could have caused some damage and injury.
    Just some common sense goes a long way.
    Make secure connections, clear the area, and pull smartly.
  5. Jan 12, 2014 at 1:26 PM
    Silence9
    Alberta, Canada
  6. Jan 12, 2014 at 1:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  7. Jan 12, 2014 at 1:36 PM
    Tacoma Mike
    Southern Maine
  8. Jan 12, 2014 at 1:39 PM
    Silence9
    Alberta, Canada
    Thank you. So those D-rings are safe for a massive load without breaking? Heard too many horror stories about hooks and rings. I will go check out Princess Auto and see if they have any. I'm not sure where else will have them other than online :eek:
  9. Jan 12, 2014 at 1:40 PM
    Silence9
    Alberta, Canada
    Another question. If she or anyone else I tow out of the ditch doesn't have that part and they probably wont, where is the best place to connect to theirs? Sry for being a towing newb. :eek:
  10. Jan 12, 2014 at 1:46 PM
    voodoojk
    voodoojk Well-Known Member
    Yes they are made for that. I never heard of a shackle breaking but I'm sure somebody has. Not sure about canada, but most agriculture like stores ( tractor supply type place ) or even trailer store should have them.
  11. Jan 12, 2014 at 1:51 PM
    Tacoma Mike
    Southern Maine
    I've recovered hundreds of cars and trucks and the each vehicle is different with different hook points and angles.unless you hook with the right equipment and pull correctly, major damage will occure. And you will be liable for your error In judgement. My advise is stick to your own and similar vehicles that you know and leave the others alone. I've seen MAJOR damage done before I got there and it was a simple extraction.
    In this case being a Good Samaritan will burn you.
  12. Jan 12, 2014 at 1:52 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Those hitches are nice. Strap wont fall off.
    the second gens don't come with a front recovery point?
  13. Jan 12, 2014 at 1:52 PM
    Canadian Taco 705
    Canadian Taco 705 Well-Known Member
    Windsor Ontario Canada
    2010 Black 2.7L 2WD Debadged
    Interior: Hardwire GPS Hardwire USB x2 Extra Cig Lighter Mag Light Mod x2 Exterior: Debadged TRD hood Bull Bar Halo Headlights 6000K Lumens HID 50% Windshield Tint 5% Window Tint
    Go to princess auto- its like crack for me- they got everything you will ever need.
  14. Jan 12, 2014 at 1:56 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    Instead of using a D-ring hitch i just put the loop of the recovery strap over the ball on the hitch....the D-ring is probably safer and won't come loose but i haven't justified the $30-40 yet. :thumbsup:
  15. Jan 12, 2014 at 1:56 PM
    Silence9
    Alberta, Canada
    Thanks for the advice, I don't want to be wrecking my truck or anyone else's, but I do want to help when I can. It makes sense that you can incur major damage if you pull at an angle or from the wrong point, but going relatively straight shouldn't harm it right? These aren't Hyundai's :p
    Your picture didn't work capetaco.
  16. Jan 12, 2014 at 1:57 PM
    Silence9
    Alberta, Canada
    Agreed! Princess Auto is the best.
    I've heard you shouldn't connect it to a ball, it may shear off.
  17. Jan 12, 2014 at 2:01 PM
    Tacoma Mike
    Southern Maine
    right side has a "T" slot
    And a loop on the left.
    At least on my 11...
  18. Jan 12, 2014 at 2:01 PM
    AR15xAR10
    Noted...It may, but i've never seen it. Yanked out bushes, pulled on stumps (with other trucks)...never sheared one off but i bet it wouldn't be a healthy experience to any by standers....
    Seen one if these on a chevy full size sheared off...but never a ball...
  19. Jan 12, 2014 at 2:04 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Yea I deleted it darn computer. The ones with the d-ring are preferred BC you can leave the strap attached and hung in the bed. They also have one with a steel hook welded to it. (they are less prone to failure than the ones on a strap.) When you do tow someone out try to tow from the rear of your truck. In reverse you are putting strain on the weak side of the gear and more prone to making it go boom.
  20. Jan 12, 2014 at 2:06 PM
    Tacoma Mike
    Southern Maine
    A ball has one secured point.
    I guess it's possible although I have not seen it however I would be more worried of it popping off.
    Yes and don't pull from a modern bumper. That's an instant fail....
