Best place to route wires on aftermarket rear camera and XM antenna?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by banjoandbikes, Feb 28, 2010.
  1. Feb 28, 2010 at 5:39 PM
    banjoandbikes
    banjoandbikes [OP] New Member
    NC Triangle
    06 PreRunner
    camper shell
    Purchased by first Tacoma (06) pre-runner a few weeks ago and love it! Just joined the forum.:)
    Ordered and aftermarket Pioneer head unit (double DIN w display) from Crutchfields so I could get XM and a monitor to install rear camera. Question: (1) Will the XM antenna work on the dash? If not, I'd rather route through the firewall for a hood area mount (have camper shell on back and don't want to remove it to get to the cab 3rd brake light) - where is the best place to route antenna through the firewall?
    (2) Will be installing a camera in the hitch receiver (making insert so I can remove it to tow) and need to find the best place to route the RCA wires (1 audio, 1 video from the rear bumper, through the body (double cab), and to the head unit.
    Thanks in advance for your assistance!
  2. Feb 28, 2010 at 5:48 PM
    jbparrish
    jbparrish Member
    Jim
    Rockford
    09 Pyrite mica Dbl cab 4x4 off road
    I ran my wires for my powered tailgate lock along with the taillight wires all the way to the front of the truck then came under the drivers floorboard with the rest of the wiring harness. I poked a hole in the seal then resealed it with black silicone.
  3. Feb 28, 2010 at 5:52 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Sold the ol girl
    ran my sat radio antenna through the firewall on the left side of the pedals (arund where the clutch would be, then up the weather stripping on the windsheild and centered it on the top of the windsheild
    can kinda see it here
  4. Mar 1, 2010 at 5:03 AM
    banjoandbikes
    NC Triangle
    06 PreRunner
    camper shell
    Jim - Thanks for the response! Did you have to fully remove the carpet to route from under the seat to behind the dash?
  5. Mar 1, 2010 at 5:05 AM
    banjoandbikes
    NC Triangle
    06 PreRunner
    camper shell
    Carson - thanks forthe reply! Were you able to hide the antenna wire under the weather stripping or did you have to tape it down? Was concerned about leaks if in the weather stripping around windshield? Thanks!
  6. Mar 1, 2010 at 5:16 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Welcome to TW....and thanks for your service!
