Best Plug 'N Play Lighting Upgrade?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CWB716, Dec 26, 2019.
  1. Dec 26, 2019 at 4:46 PM
    CWB716
    CWB716 [OP] Member
    Connor
    Jersey
    2005 Toyota Tacoma Prerunner TRD
    Leveling kit, Wheels&Tires
    I'm looking at doing a headlight upgrade but I am not looking to add anything wiring harnesses etc. Just plug and play and I have no idea where to start
  2. Dec 26, 2019 at 6:01 PM
    furiousbob
    furiousbob Well-Known Member
    Ron
    Without getting projector headlights to replace the reflector headlights we have, you're pretty much limited to getting a nicer incandescent bulb (keep in mind: if you get something twice as bright, it'll last half as long). Do not switch to LED or HID on reflectors. They're plug n play but they WILL blind everyone on the road.
  3. Dec 26, 2019 at 10:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Look at the output charts in this thread:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    3 options:
    1) IPF fatboys 80w low beam, stock high beam, max low beam output no harness needed.
    2) Philips Racing Vision +150, best stock wattage low beam w/ reduced performance high beam due to blue coating over the high beam filament.
    3) GE Xenon +120, best stock wattage low beam performance without reducing the high beam, but low beam will not perform as well as the others listed above.
    All data is in the output charts in the linked thread.
    Norton, BassAckwards and deadpocketss like this.
  4. Dec 27, 2019 at 9:40 AM
    MtnMan307
    MtnMan307 Well-Known Member
    Aurora, Colorado
    2010 DCSB TRD OR, 2017 Prius 4 Touring Lyft Car
    Weathertech floor mats, Bilstein 5100s front/rear, TSB leaf springs, Pioneer head unit, Mini D2S headlight retrofit.
    A projector retrofit is probably not as hard as you think. Maybe 10 hours of work and $350-400 will get you a very fine performing setup. That amount includes new housings if you need or want.
  5. Dec 27, 2019 at 10:12 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    If you don't have fog lights, they help a lot. Depending on if your truck is pre-wired it may be "plug and play"
