Best portable air compressor under $100?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BaconPower, Aug 18, 2016.
  1. Aug 18, 2016 at 1:21 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Completely reliable. I've aired up multiple trucks after a day on the beach in the freaking hot summer. I'll just leave the truck running so there's airflow and pump me up.
  2. Aug 18, 2016 at 3:18 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    That is NOT the one I was talking about for the first pump ($130). But that is still a pretty good one. The "pro" version is 2.5cfm which is pretty quick.
  3. Aug 18, 2016 at 3:47 PM
    BaconPower
    BaconPower [OP] Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    Another candidate at $100 is the Puma DC02
    Anyone familiar with it?
  4. Aug 18, 2016 at 4:58 PM
    RobertHyatt
    Robert
    Birmingham AL
    Looks really weak / slow. 3/4 CFM is less than 1/3 of the slime pump I bought. Figure more than 3x longer to inflate a tire than a 2.5 CFM pump
    Sandman614 likes this.
  5. Aug 18, 2016 at 6:09 PM
    OldandSlow
    OldandSlow Well-Known Member
    Andrew in Austin
    Austin, TX
    2015 Tacoma Access Cab - 2.7, 5 speed, 4x4
    Not much on mods - Leer 180, TRD wheels, Mobtown sliders, rear hitch, helper springs on the rear
  6. Aug 18, 2016 at 10:12 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    @BaconPower I know you are "not concerned with PSI or other marketing mubo jumbo" but you really need to look at CFM (rate of flow, or how fast your tires will fill, greater CFM is better) at load pressure. Flow at 0psi is not very helpful for tire fill purposes.
    The Smittybilt 2780 is labeled as 2.54cfm but doesn't list at what PSI. From experience I can tell you that it drops below 1cfm at about 80psi. This compressor will fill my 265/75/16 tires from 20psi to 40 psi in 3 minutes per tire.
    ARB examples. The ARB CKSA12 (0.47cfm at 29psi) will take a lot longer to fill a tire than the CKMTA12 (4.65cfm at 29psi).[​IMG]
    wagerhope likes this.
  7. Aug 18, 2016 at 10:18 PM
    BadAndy10
    BadAndy10 Well-Known Member
    the 541
    '10 DC TRD OR
    Fox 2.5" extended travel coilovers, SPC UCA's, Wheeler's AAL & 5100's, Relentless front plate bumper, SCS F5's w/285's, Superbumps
    Another vote for the smittybilt 2780, recently picked one up for a trip to the dunes, aired up 33x12.5's no problem. Just barely fits in the storage area behind the back seat in a DC. Owned the 2781 previously and the case and everything is a lot larger and harder to store. Neither would be the one you would want to mount under the hood permanently.
  8. Aug 18, 2016 at 10:24 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    It works fine under the hood. Just needs some modification to be a closed system. Mine runs my ARB locker and fills tires.
  9. Aug 19, 2016 at 12:59 AM
    BaconPower
    Portland, OR, USA
    No doubt that at $170 the ARB is a nice compressor.
    According to these practical measurements the $60 SuperFlow mentionned above suplants some ARB compressors.
  10. Aug 19, 2016 at 2:06 AM
    mauigrown
    mauigrown Well-Known Member
    2011 4x4 DCSB TRD sport
    BlueFalconActual likes this.
  11. Aug 19, 2016 at 6:42 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I bought a Harbor Freight pancake compressor some years back for the purpose of airing up tires. It does that OK. Takes 4-5 mins to fill the small 3 gallon tank. For anything other than airing up tires and by that I meaning topping up tire pressure, pancake compressors are not very effective. I bought an air powered brake bleeder. As soon as I hit the trigger, the pressure in the tank dropped like a rock. Knob adjustment proved to be futile.
    The bigger the tank - the better.
  12. Aug 19, 2016 at 7:16 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    mauigrown[QUOTED] likes this.
  13. Aug 19, 2016 at 8:02 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    What did you use to power the pancake compressor?
    Apparently, the 400w bed AC outlet isn't enough:
  14. Aug 19, 2016 at 9:58 AM
    mauigrown
    It's not the fastest but gets the job done. $65.95 & free shipping on Amazon fit my budget. I just roll one up to pass time while airing back up :rasta:
    dleriche likes this.
  15. Aug 19, 2016 at 10:44 AM
    #35
    BaconPower
    Portland, OR, USA
    The compressor motor draws a peak current and wattage at startup, then needs less than 400W once it gets going.
    It sounds like that compressor lacks a start capacitor. Explanation of start capacitors here. If you think of adding a start capacitor make sure you know what you're doing, they are dangerous.
    tomwil[QUOTED] likes this.
  16. Aug 19, 2016 at 10:45 AM
    #36
    BaconPower
    Portland, OR, USA
  17. Aug 19, 2016 at 10:46 AM
    #37
    BaconPower
    Portland, OR, USA
    Seems like the 88P, albeit less powerful than the MV50 is much better quality. I'm leaning towards the 88P or the 90P which is similar in price but has metal feet that allows it to be mounted in the engine bay.
  18. Aug 19, 2016 at 10:49 AM
    #38
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Just purchased the Viar 88p due to this thread.
  19. Aug 19, 2016 at 12:17 PM
    #39
    BaconPower
    Portland, OR, USA
    Did you consider the 90P? It is listed as heavier and drawing more amps than the 88P on Viair's site so it seems a bit more heavy duty for about $10 more.
  20. Aug 19, 2016 at 12:20 PM
    #40
    eon_blue
    Azusa, CA
