Best portable air compressor under $100?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BaconPower, Aug 18, 2016.
  1. Aug 19, 2016 at 1:25 PM
    #41
    BaconPower
    BaconPower [OP] Well-Known Member
    Portland, OR, USA
    2013 Double Cab 4x4 TRD Offroad
    The 88P is a pretty light unit at 4.75 lb given the fairly large CFM it flows. This means less metal mass to absorb heat generated by compression, thus higher temperature.
    eon_blue[QUOTED] likes this.
  2. Aug 20, 2016 at 9:20 AM
    #42
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I was using wall current. Attempted bleeding in my driveway.
  3. Aug 20, 2016 at 10:53 AM
    #43
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I didn't. I kept seeing great reviews about the 88P and pulled the trigger. It will suit my needs just fine, i'm assuming. Can these things fit in the bed cubby's?
  4. Aug 22, 2016 at 9:49 AM
    #44
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    Got in in the mail over the weekend. Damn the thing is small. Haven't taken it out of the box yet but i'm thinking it should fit.
    mauigrown likes this.
  5. Aug 22, 2016 at 11:41 AM
    #45
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Viar 88p hands down. Best bang for your buck
  6. Aug 22, 2016 at 11:57 AM
    #46
    BaconPower
    Portland, OR, USA
    Cool. Are all the mounting tabs metal on it?
  7. Aug 22, 2016 at 12:39 PM
    #47
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    I'll check when i get home from work today and report back.
  8. Aug 22, 2016 at 2:33 PM
    #48
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If I remember right 2 are metal and 2 are in the plastic end cap
  9. Aug 22, 2016 at 2:39 PM
    #49
    benzy
    benzy Well-Known Member
    Bay Area, CA
    2006 DCSB TRD OR
    Simple OME/884/AAL lift. 32” WP’s
    I have the Viair 90p and it's worked flawlessly. Inflates from 15-35 psi in 2-3 minutes.
  10. Aug 22, 2016 at 2:40 PM
    #50
    BaconPower
    Portland, OR, USA
  11. Aug 22, 2016 at 2:50 PM
    #51
    Sandman614
    Tim
    '06 SR5 Off Road
  12. Aug 22, 2016 at 4:04 PM
    #52
    BaconPower
    Portland, OR, USA
    Did you mount it in the engine bay? Also does it have an external air filter?
  13. Aug 23, 2016 at 9:41 AM
    #53
    gkomo
    San Diego, CA
    2014 MGM AC SR5 4x4
    @Sandman614 is correct. There is a metal tab on one end and the other end has two mounting holes in a plastic part underneath the compressor.
  14. Aug 23, 2016 at 9:51 AM
    #54
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    It fits snugly in the larger bed cubby. Great compressor.
  15. Aug 23, 2016 at 9:52 AM
    #55
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I pick up the 88p a few yrs ago after doing a lot of research and I have been very happy with it. It fits nice in a little canvas bag I have. The canvas bag comes in handy when your using the compressor. I have a slab of wood that fits in the bag on the bottom, I pull it out and set the compressor on top, it keeps dirt and water from junking up your investment. Also keep a small towel to clean the hose off. Let her cool down before you pack away.
  16. Aug 23, 2016 at 10:28 AM
    #56
    Jferg614
    Jferg614 Member
    Joe
    '05 Tacoma SR5
  17. Aug 25, 2016 at 11:35 AM
    #57
    SixtyDashOne
    SixtyDashOne Well-Known Member
    Collegeville, PA
    2021 ArmyGreen TRD Sport, 2007 Regular Cab 4x4
  18. Aug 25, 2016 at 11:42 AM
    #58
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    You cant expose it to water and constant dust.
  19. Aug 25, 2016 at 11:43 AM
    #59
    SixtyDashOne
    Collegeville, PA
    hrm, can I mount it behind my seat than?
  20. Aug 25, 2016 at 11:47 AM
    #60
    moondeath
    Pa, Gardners
    You probably could. I just keep mine behind the rear seats and take it out when I need it.
    Corneeeeelius likes this.
