Best price on a TRD Pro Grille?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by schultzj01, Mar 2, 2018.
  1. Mar 5, 2018 at 10:22 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Oh I dunno, I got mine from someone on here. There are listings on Amazon and ebay though iirc
  2. Mar 5, 2018 at 4:17 PM
    Fedup13
    Fedup13 Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    They told me it only fits 2018 models and is on national backorder.
  3. Mar 5, 2018 at 5:01 PM
    coolbhavin
    coolbhavin Well-Known Member
    Tempe, AZ
    2017 TRD Sport; 285's; Method NV's
    Did you order it or did you go into the store to buy it?
  4. Mar 5, 2018 at 5:29 PM
    SavageTacoma
    SavageTacoma NorCal-Taco
    Dillon
    NorCal: Wine Country
    16' AC Grey TRD OR
    285/70r17s Pro comp 3" lift
    149 on Amazon from Chinese company, fitment works and accepts the TSS sensor, just need to order the front radar cover from dealer
  5. Mar 6, 2018 at 4:09 AM
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    I wonder if we’ll ever be able to buy the pro grilles again (2018 versions)
  6. Mar 6, 2018 at 7:37 AM
    samwoo2go
    samwoo2go Well-Known Member
    SoCal
    2018 Taco TRDOR DCSB Cement
    I bought a chinese grille first, but had to buy again oem because the Chinese grille I had did not accept the garnish without modifications, so I had a chance to compare side by side. The oem one is definitely better quality.
    - oem is slightly heavier, prob from thicker plastics.
    - better constructed with no seams, there are some odd seams on the chinese one.
    - better finish, no burls or other blemishes.
    - oem has more of a satin finish, wile chinese is more flat black, which I actually would’ve preferred because it matches with the OR fender flares better.
    Overall, the Chinese one is good enough for the job for sure, it’s def sturdy and I would’ve kept it if it accepted the garnish. But not the same quality. I’d say they are each worth their respective price.
    shakerhood and arnette64 like this.
  7. Mar 6, 2018 at 7:40 AM
    samwoo2go
    SoCal
    I ordered it online. After talking to Gunny here. Some one posted his username a few posts back, he works there, pm him.
  8. Mar 6, 2018 at 7:43 AM
    ejewels
    CT
    Gunny told me we can't buy the 2018's anymore... 3 days ago. Man I hope there is another way to get the OEM.
  9. Mar 6, 2018 at 7:47 AM
    samwoo2go
    SoCal
    It’s actually 2 separate parts. The grille. And the garnish. What did he say that you can’t buy?
    Because the grille is the same across all years, just the garnish is new.
    shakerhood likes this.
  10. Mar 6, 2018 at 8:04 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    As said above you can just get a 17 Pro Grille but you will need the 18 Garnish.
  11. Mar 6, 2018 at 8:06 AM
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    I got mine delivered in about a week. Cost $111. A few tabs were broke so I mentioned it and the seller refunded my money and told me to keep the grille. Free works for me!
    Norsemanvike and Fortunt1 like this.
  12. Mar 6, 2018 at 8:08 AM
    ejewels
    CT
    Oh I thought the '18 grille had some plastic on it and was slightly different. Also I heard the '17 is more expensive. He told me only the grille he can't get. But I thought I read its hard to get the garnish too? If I can do this easily without NEEDING the '18... I'm game!
  13. Mar 6, 2018 at 8:20 AM
    shakerhood
    Southern Ohio
    Correct, the only difference is the plastic Garnish piece.
  14. Mar 6, 2018 at 8:25 AM
    Breaky0self
    Breaky0self Well-Known Member
    Jupiter fl
    2011 Trd Sport metallic grey 2wd
  15. Mar 6, 2018 at 12:05 PM
    #35
    Sungod
    Sungod Well-Known Member
    St Augustine
    16-17 OEM grille does not have the opening for the garnish. You can't use it on an 18 with TSS-P. Not to mention it is a lot more expensive. This is what the 18 grille looks like out of the box without the sensor. SensorOpening.jpg
  16. Mar 6, 2018 at 12:36 PM
    #36
    shakerhood
    Southern Ohio
    I have a 17 Pro Grille, it does have that same exact opening, just a different style Garnish that closely matches the Grille making it blend in.
    TUDBALL likes this.
  17. Mar 6, 2018 at 2:19 PM
    #37
    dmc1
    dmc1 Well-Known Member
    SC
    2017 TRD OR SBDC
    So, will the 18 grill fit a 17? Does the garnish that goes with the 18 grill blend with the grill?
  18. Mar 6, 2018 at 2:41 PM
    #38
    coolbhavin
    Tempe, AZ
    Yeah the 18 grill will fit a 17, but you can't get an 18 without having a 2018 TRD Pro.
  19. Mar 6, 2018 at 2:41 PM
    #39
    coolbhavin
    Tempe, AZ
    I wonder why there is such a big price difference between the 18 grill and the 17. I would rather buy the 18 cause it is so much cheaper than the 17.
  20. Mar 6, 2018 at 2:47 PM
    #40
    shakerhood
    Southern Ohio
    You can put the 18 Grille on the 17 but would have to source a garnish piece either 17 or 18 style.
