Best product for cleaning plastic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skiergd011013, May 15, 2015.
  1. May 15, 2015 at 10:42 AM
    skiergd011013
    skiergd011013 [OP] Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    I got some meguiars scratch X onto my black tailgate handle the other day. It will not come off. It just kind of smeared and gave the black handle a cloudy/dirty look. What is a product I can use to restore/clean my handle?
  2. May 15, 2015 at 10:47 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    you can use some degrease first to get it off and follow up with lots of silicon/tire shine or mothers back to black and you should be ok
  3. May 15, 2015 at 10:48 AM
    skiergd011013
    p.s something that wont hurt paint. The tailgate is freshly painted (was scratched)
  4. May 15, 2015 at 11:26 AM
    skiergd011013
  5. May 15, 2015 at 11:45 AM
    Why J
    Why J I'm the master of my own domain.
    2012 DCSB V6 SR5 Prerunner
    OEM Roof Rack, 3" lift, 1.25" Spidertrax Wheel Spacer, Front skid plate
    Any general soap should work. I would use a spray bottle with warm water and 1 drop of dish soup. Then use an old tooth brush to scrub the wax that is on the handle. Rinse with warm water and dry.
    The soap nor the tooth brush will damage the paint or the plastic.
    The reason the wax is there is because the plastic is textured and a cloth will not get into the tiny pores on the surface.
  6. May 15, 2015 at 11:50 AM
    skiergd011013
    i will do this. thank you.
  7. May 15, 2015 at 12:43 PM
    mAtTyG04
    mAtTyG04 Well-Known Member
    Edmonton
    2019 Quick Sand OR
    6112 Front Suspension, Fox 2.0 Rear Shocks, Nitto Ridge Grappler - LT285/75R17 C, Rear Blackout Tacoma Badge, De-badged, Icon Rebound Wheels, TRD Grill Gights, CBI Ditch Light Brackets w/ Baja Design Lights, Husky Liners, JBA UCAs, Geenlane Off-road Sliders, Tacotrooper Decal, DuraBump Rear Bump Stops, Pro-clip USA Phone Mount
    If the areas are small a pink eraser like the kids use in school will remove it. Just lightly rub like you are trying to erase pencil marks.
  8. May 15, 2015 at 12:49 PM
    Pavlovsdog
    Pavlovsdog Active Member
    Tampa, FL
    07 PreRunner 2WD
    A Mr. Clean Magic Eraser and then shine it back up with Meguiars Ultimate Black
  9. May 15, 2015 at 6:59 PM
    Why J
    You have to be careful with Magic Erasers. When they get wet they actually become abrasive.
    I wouldn't recommend using magic erasers on any automotive surfaces.
