Best rainguards?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maine_Tacoma13, Jun 25, 2019.
  1. Oct 27, 2020 at 9:24 AM
    #41
    LiplessSoul
    LiplessSoul Well-Known Member
    2017 Black Tacoma TRD Sport
    Yes, they do keep your windows from sticking during ice and cold weather conditions. I have Weathertech In-channel units. And they look baaad-aaasss, too.
    TacoMV, Tacoma1845 and usmc2msu like this.
  2. Nov 17, 2020 at 1:25 PM
    #42
    Skkeeter
    Skkeeter Member
    Is there a rain guard that stops the water pouring into my truck when I open the door from the outside when getting in? I was parked while the truck was slightly tilted sideways and about a cup of water entered onto my seat and door during a rainstorm.
  3. Nov 17, 2020 at 2:07 PM
    #43
    Provist
    Provist Well-Known Member
    2020-TRD-OR-4X4-AT-DCSB-QS
    AVS 100%, got an open box on Amazon warehouse for ~$20, scratched up a bit, but it's a truck.
    Taco_Coma and Fargo Taco like this.
  4. Nov 17, 2020 at 7:09 PM
    #44
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    AVS FTMFW
  5. Nov 17, 2020 at 8:47 PM
    #45
    Tacomike18
    Tacomike18 Well-Known Member
    J
  6. Nov 18, 2020 at 4:11 AM
    #46
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    The scratching isn't from the rain guards themselves though as they're on the other side of the window (outside). Though if crap gets on the window or your upper track is dirty, it may cause some scratching on the tint as the rain guard pushes the window against the inner seal a little more than it would without them. My windows are the same way, the top 1/8" or so has a little rub on them from the window seal itself.
    The thicker the rain guard (the part in-channel) the worst it would probably be. I love my AVS low profiles.
  7. Nov 18, 2020 at 10:55 AM
    #47
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    No problem with my AVS in channel and ceramic tint. I did have an issue with one of them not sticking in the front passenger side and I called them up, they sent me a full set to replace the one with bad adhesive.
    AVS stuff i had on previous vehicles they stood behind too.
  8. Nov 18, 2020 at 11:09 AM
    #48
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    I just ordered a set, but they only have three tabs with the adhesive. Other AVS install videos show the entire length of the visor having adhesive (in-channel). Did yours have the full or three tabs? Thanks!
  9. Nov 18, 2020 at 12:20 PM
    #49
    Taco_mike73
    York, PA
    Yes these are the ones I ordered and they have adhesive all the way down. Now it is in 3 sections on the front windows. One up near the mirror the main long strip and on for the rear vertical section. There should only be a small gap between sections of the adhesive tape.
    https://www.amazon.com/dp/B018AIGLSI?ref=ppx_pop_mob_ap_share
  10. Nov 18, 2020 at 12:22 PM
    #50
    usmc2msu
    TJ
    2017 SR5
    Thank you. Hopefully these will hold up with less adhesive.
  11. Nov 18, 2020 at 12:28 PM
    #51
    Taco_mike73
    York, PA
    I hope so. I see you have the Access cab. Do those came in sets of 4 or just front windows?
    Edit.
    I see this is what you might have. https://smile.amazon.com/dp/B019NQKLPK/ref=cm_sw_r_cp_apa_fabc_ZqyTFbZTAE5VE
    Weird that they are not like the double cab front windows.
  12. Nov 18, 2020 at 12:43 PM
    #52
    usmc2msu
    TJ
    2017 SR5
    Yep, same as what I have ordered. It’s odd to me also that they either changed the design or just make the access cab option different. I’ll report back if they fail.
  13. Nov 18, 2020 at 12:54 PM
    #53
    Taco_mike73
    York, PA
    Be careful when you peal back the plastic holding it to the cardboard. That's how i damaged the adhesive on the one. The plastic tends to stick to the red adhesive backing tape.
    usmc2msu likes this.
  14. Nov 18, 2020 at 1:52 PM
    #54
    wayne0
    wayne0 Well-Known Member
  15. Nov 19, 2020 at 8:46 AM
    #55
    usmc2msu
    TJ
    2017 SR5
    Thanks for the heads up on the wrapper. It sure wanted to stick. Here’s what I actually got in the mail today. Not sure why they are showing a three tab version.
    Taco_mike73[QUOTED] likes this.
  16. Nov 19, 2020 at 9:36 AM
    #56
    Taco_mike73
    York, PA
    Looks exactly like the ones that come in the package for the front doors of the double cab. That is odd how it's pictured online.
  17. Nov 19, 2020 at 10:03 AM
    #57
    usmc2msu
    TJ
    2017 SR5
    When you first put the window up it makes a click noise on the front visor lip as the window passes it. I assume that click noise goes away after they sit for 72 hours and they sit deeper in rubber channel?
    Taco_Coma likes this.
  18. Nov 19, 2020 at 10:11 AM
    #58
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    That's where I got mine from. :D
  19. May 13, 2023 at 8:57 AM
    #59
    TerrapinOverland
    TerrapinOverland Well-Known Member
    Hillsborough, NC
    2015 Tacoma TRD Off Road Access Cab
    Dobinson's IMS with heavy duty leaf package Epoch house battery Renogy 40AMP DC to DC charger 100W Solar Panel Chrome delete: grill, etc... Tinted front headlights. A. R. E. fiberglass cap. Sits flush to top of cab w/DIY roof tracks w/modified 84" x 50" ebay roof rack ( I cut it to 72") sleeping platform and cabinets 32-in LED light bar behind the grill. Cats down under the star's bumper sticker Spock decal on dashboard passenger side. Viair 88p compressor mounted in stock truck bed storage box Rear bumper air chuck dash mount ultraguage dash mount 7"tablet
    "bumpy" :)
  20. May 13, 2023 at 9:11 AM
    #60
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    What a way to revive a 2.5 year old thread!
    lol
    For the record...I have AVS in-channel rain guards.
