Best Rear Hydro Bump Stops
Discussion in 'Suspension' started by DefinitelyThor, Mar 6, 2020.
  1. Mar 6, 2020 at 7:48 AM
    DefinitelyThor
    DefinitelyThor [OP] Well-Known Member
    Utah
    2018 Black Trd Pro
    While im waiting on my stealth lt kit from simmons built i want to throw on some rear hydro bumps real quick to get better control of the bottoming out since i have added more weight to the back for until i get the lt rear going. So my question is likely easier said that answered, what is the best bump stops and mounting hardware for them?
  2. Mar 6, 2020 at 10:47 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    What suspension kit are you going with? Brand shocks?
    Total Chaos has a bolt on rear air bump kit for Fox bumps and King has their own bolt on kit. Both very similar.
    What shocks do you have in the rear?
  3. Mar 6, 2020 at 11:12 AM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    im going to use 3' triple bypass in a cantilever set up, most likely from king, and i would like to work my way up to sua. Simmons built in provo ut, just created bolt on cantilever with 19+ with an sua. Out of curiosity what springs would u recommend since i don't want to go full lt in the rear with the front still being mt? Im running about 700 extra lbs of weight but i would like to grab a cbi high clearance bumper in the nearish future. Unless i decide to turn it into a prerunner in 15 years.
    Gunshot-6A likes this.
  4. Mar 6, 2020 at 11:18 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Love that Simmons kit!
  5. Mar 6, 2020 at 11:29 AM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    how's it treating you, and and i ask what the rest of you suspension set up is? and how hard have u taken it, any jumping or anything else absurd?
    Gunshot-6A[QUOTED] likes this.
  6. Mar 6, 2020 at 11:31 AM
    AccuTune Offroad
    El Cajon, CA
    You will most likely need to get a custom leaf pack for that much weight and travel, especially for something that custom.
  7. Mar 6, 2020 at 11:35 AM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    ok, i know the kit was build around a deaver sua spring, is there a spring that would be passable for the time or with the 14" with the stock spring should i just go for that and throw a block on it for a year or so, or is a custom spring not all that much?
  8. Mar 6, 2020 at 11:55 AM
    Gunshot-6A
    Conner
    Everett, WA
    I personally don't have it, although I was gonna be one of the guinea pigs. But have ridden in his "overland" setup with the extra air cans that's in my buddy Ben's truck. Like you, he's MT in the front. Compared to my truck on regular kings and dakars, he def has a softer rear end over the rough stuff.
  9. Mar 6, 2020 at 12:10 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    ahhh, ok, do you know what springs he was running? thats the last question i have once i decide if I want to switch to kings or not when going for the bump stops since i need those to save me from ending up like my friends with everything broken, but i know the second i have "long travel" and a properly valved setup im gonna be in the air
  10. Mar 6, 2020 at 12:16 PM
    Gunshot-6A
    Conner
    Everett, WA
    He had Dakar heavies in before he took it in,. so I'd assume thats what he's running now.
  11. Mar 6, 2020 at 12:19 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    ok, im thinkin that the move just so i dont have to run blocks anymore
  12. Mar 6, 2020 at 12:21 PM
    Gunshot-6A
    Conner
    Everett, WA
    If you're going to all that trouble, I'd def run proper leaves and remove the blocks
    whatstcp likes this.
  13. Mar 6, 2020 at 12:31 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    for sure, i just dont want to go to sua quite yet since i don't want to go full lt yet and i don't want to go for a custom spring if im just gonna change it out when im able to take it to the next level and go full lt. But its a bit pricey the canti is just not that much more expensive than a bed cage and its a bit more step by step for going full lt.
  14. Mar 6, 2020 at 12:33 PM
    Gunshot-6A
    Conner
    Everett, WA
    Yeah I agree. Dakar springs are pretty cheap and theres plenty of demand for them in the SLC area so you could run them while you need, then sell them as you progress.
  15. Mar 6, 2020 at 12:38 PM
    DefinitelyThor
    Utah
    2018 Black Trd Pro
    yea, if im lucky i might even be able to find a cheap pair used while im on the hunt for some uca's
  16. Apr 2, 2020 at 10:04 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Does he have a build on here or anywhere I could check it out ?
  17. Apr 3, 2020 at 6:57 AM
    Gunshot-6A
    Conner
    Everett, WA
    No. You could look up Simmons Industries of FB. Thats where youd get the best views of it, etc.
