Best rear leaf springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ecr6cyl10, Jul 28, 2013.
  1. Jul 28, 2013 at 6:34 PM
    ecr6cyl10
    ecr6cyl10 [OP] Well-Known Member
    Eddy
    Gilbert, AZ
    10 Prerunner Dble Cab Offorad
    Defiant Light bar with 12" LED light bar and 2 Rigid dually floods. 3" Icon lift in the front with TC UCA's and 1.5" add a leaf in the rear [url=http://www.tacomaworld.com/gallery/showphoto.php/photo/198098/cat/500][img]http://www.tacomaworld.com/gallery/data/500/medium/My_Truck54.jpg[/img][/url]
    I have a 2010 Dbl cab prerunner and I flatten my stock springs with the aal in them. I need to get some new ones what are the best for 1"-1.5" rear lift and good offroad.
  2. Jul 28, 2013 at 6:37 PM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    The smallest lift rear springs I know is Ironman 4x4. They are well priced, but I believe 1.5-2" of lift.
    Most people use Dakar leafs from OME. A little more lift than you want though.
  3. Jul 28, 2013 at 6:42 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    I am ok with a little more lift I just want to have springs that will last awhile.
  4. Jul 28, 2013 at 6:48 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Im happy with my dakars. I removed a leaf and i got about 2" of lift give or take
  5. Jul 28, 2013 at 6:52 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    do you remove a particular leaf? top, bottom? and do i need to order anything else besides OME shocks"?
  6. Jul 28, 2013 at 6:53 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    What spring would you pull out?
  7. Jul 28, 2013 at 6:55 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  8. Jul 28, 2013 at 6:56 PM
    OZ-T
    Peter North
    British Columbia
    3rd down from the top
  9. Jul 28, 2013 at 6:58 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I removed the 3rd leaf down in the pack. You can also remove the upper overload. You may need to order new bushings for the rear eye of the dakars depending on who you order from, most vendors include them, i know down south motorsports does not. Longer u-bolts are needed but they are included by most vendors. You might want either a carrier bearing spacer or axle shims to adjust the driveshaft angles if you get vibrations from the lift.
  10. Jul 28, 2013 at 7:02 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    When did they start offering these? Do you know who makes the springs?
  11. Jul 28, 2013 at 7:02 PM
    OZ-T
    Peter North
    British Columbia
    Over a year ago
    No , I don't know
  12. Jul 29, 2013 at 5:26 AM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    Anyone using the Alcan leaf?
  13. Jul 29, 2013 at 12:15 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
  14. Jul 29, 2013 at 12:23 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    You can look into Wheeler's HD 5 leaf pack as mentioned above or General Spring HD leaf pack:
    http://www.tacomaworld.com/forum/product-reviews/266183-generalspringkc-com-hd-leaf-springs.html
    http://www.generalspringkc.com/product_p/90-297hd.htm
    They are made by Alcan. (Wheelers' HD 5 leaf pack)
    http://www.tacomaworld.com/forum/suspension/247480-leaf-springs-no-lift.html#post5962700
  15. Jul 29, 2013 at 7:07 PM
    smd3
    smd3 Well-Known Member
    I use the wherler's HD pack with a leaf removed. It lifted the bed about an inch, maybe a hair under.
  16. Jul 29, 2013 at 9:00 PM
    ecr6cyl10
    Eddy
    Gilbert, AZ
    I have narrowed it down to the deaver 10 pack or the Alcan springs. Any thoughts on either one of these?
  17. Jul 30, 2013 at 5:33 AM
    ecr6cyl10
    Eddy
    Gilbert, AZ
  18. Jul 30, 2013 at 5:35 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Check out OMD (4wd) He's "local" and uses Chevy leafs to revive stock leaf packs.
  19. Jul 30, 2013 at 5:45 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I just put the General Spring stock replacement 3 leafs in my double cab last week. I'm very pleased so far. Picked up the rear of the truck probably 1.5" and no more axle wrap.
  20. Jul 30, 2013 at 2:11 PM
    hellsbay
    hellsbay Well-Known Member
    SW Florida
    13 PreRunner TRD OR
    I too am looking at Alcan's 8 pack. I want to be able to tow my TT with a tongue weight of 300-400#'s and have another couple of hundred pounds of stuff in the bed without dumping the rear. I also want to be able to go off road and not have my rear wheel articulation limited. I already have an Icon stage 4 suspension. The front is up about 2 inches and I would like the back up about 3 inches unloaded.
