Best remote start?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Heath101, Jan 17, 2020.
  1. Oct 26, 2021 at 7:15 PM
    #141
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    You'll need to purchase the Viper edition which would be the VSM550 or DSM550 (both identical, both will work on Viper only). We don't use these due to the negative perception they've received over the years from other dealers in the industry that we speak with from time to time. We've only "heard" not validated this, but that they "suck" seems to be the common word used by MANY that have come to us for a complete swap out. And their subscription is a flat $99/year whereas ours is only $39.99/yr. $99 with us, gets you THREE years! Hopefully this helps. Good luck!
    VaToy and Dam325[QUOTED] like this.
  2. May 23, 2023 at 1:29 AM
    #142
    GunthorNC
    GunthorNC Well-Known Member
    2017 Tacoma Offroad Access Cab 4x4
    Is there any workaround for this? Do other brands do the same thing? I just received my N2, but I'll return it and get something different if there's a brand without that "hiccup" that still works with my factory key fob.
  3. May 23, 2023 at 3:10 AM
    #143
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    They all do it. Go ahead and install the N2.
  4. May 23, 2023 at 5:07 AM
    #144
    Takemehome678
    Takemehome678 Member
    Robin
    Carter Lake, Iowa
    2020 Black Tacoma SR
    iBoards, Rims, seat covers, bed liner, decals, bug guard, tonneau cover, window deflectors
    I have a Compustar and it doesn't shut off when I open my door. The low tire pressure light comes on though. They warned me it would and it doesn't bother me. It goes off after I get in and start driving. I have a key ignition. Idk if that matters.
  5. May 23, 2023 at 5:54 AM
    #145
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Yes. That is the reason it does not shut off. Push-to-start turns off when opening the door, H-Key does not.
  6. May 23, 2023 at 7:25 AM
    #146
    1dayKapaa
    1dayKapaa Well-Known Member
    Northern VA
    2019 Tacoma DCLB
    I have 12v for mine and my wife’s 4R. Great customer service and got it on sale for under 200 each. Had issues with my wife’s but they took care of it all.
  7. May 23, 2023 at 8:29 AM
    #147
    Gen3TacomaOBX
    S
    I too have a 12Volt.Solutions remote start. Any new user attempting to search on "12v" would be screwed. I don't think their company naming is doing them any favors in the modern age of product searching.
  8. May 23, 2023 at 10:52 AM
    #148
    1dayKapaa
    Northern VA
    2019 Tacoma DCLB
    Never thought about this.. thanks for pointing it out. I think they all work the same. I was just looking at deals.
