Best replacement battery?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tbar71, Feb 11, 2023.
  1. Feb 11, 2023 at 5:16 PM
    Tbar71
    Tbar71 [OP] Active Member
    Troy
    Pace, FL
    2020 Cement Tacoma Limited
    I’ve had bad luck with Toyota batteries over the years. My 2020 Tacoma Limited is about to turn 3. What is the best replacement these days?
  2. Feb 11, 2023 at 5:18 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It's a battery brother, pick one! Spend good money on a quality unit and you really can't go wrong here.
  3. Feb 11, 2023 at 5:27 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Or get the Interstate from Costco for less than most. Mine in my 4runner is 7 years old and going strong in this MN winter still.
  4. Feb 11, 2023 at 5:29 PM
    Tbar71
    Troy
    Pace, FL
    Unfortunately I don’t have Costco near me. Just SamsClub and BJ’s.
  5. Feb 11, 2023 at 5:29 PM
    Trail Limo
    Trail Limo Well-Known Member
    This. I used to sell batteries, and they are all basically the same. Pick your favorite flavor, with a good warranty and you will be happy. Regardless of brands they all have an average life of 3-4 years.
    drizzoh, AZ Pete, knayrb and 4 others like this.
  6. Feb 11, 2023 at 5:39 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would go to dealer and have them replace it if it's going bad. Take a free one. I know you are saying you have had bad luck, but shit it's free. They replaced mine after 3+ years. No charge. New one has been fine.
  7. Feb 11, 2023 at 6:28 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I've never gone wrong with an Interstate...
    tneynop and hiPSI like this.
  8. Feb 11, 2023 at 6:51 PM
    na8rboy
    WI
    Best battery in my bass boat, won't run nothing but interstate.
    tneynop likes this.
  9. Feb 11, 2023 at 7:05 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I have had great luck with the AAA rated Napa battery.
  10. Feb 11, 2023 at 7:08 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I run interstate. Just replaced my wife's CRV battery with interstate. Not fancy, not expensive, no frills, just good reliability and consistency. This is probably my 20th replacement battery I have purchased throughout the years. I have bought Optima, Duralast, etc but interstate is a known quantity and consistency. It simply works for a good amount of time.
    tneynop and Tbar71[OP] like this.
  11. Feb 11, 2023 at 7:23 PM
    Corrugated
    Corrugated 2023 TRD Sport Premium
    Surrey, British Columbia, Canada
    2023 Tacoma TRD Sport premium
    AGM, 100%...Odyssey.
    D.A.S. Taco and Mully like this.
  12. Feb 11, 2023 at 7:29 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Agm Northstar from batteries+ 24F
    Mully and Corrugated like this.
  13. Feb 11, 2023 at 7:37 PM
    Martian__
    Martian__ Well-Known Member
    Southern California
    I hear that the interstate AMG battery is amazing. I’m going to try it after the optima goes out.
    Corrugated likes this.
  14. Feb 11, 2023 at 7:51 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Interstate does not make batteries; they are a battery marketing and distribution company. Their batteries are made mostly by Exide and Clarios, but others as well. Not saying they are bad. Just not much different than getting a walmart or autozone battery, except green is prettier. I get Costco Interstate myself, but will vouch for East Penn Deka Intimidator battery if you can find it.
    https://www.eastpennmanufacturing.com/wp-content/uploads/Intimidator-Automotive-Flyer-1737.pdf
    SWPA Tacoma and Tbar71[OP] like this.
  15. Feb 11, 2023 at 8:59 PM
    Gatafly
    Shawn
    Yeah most names on the battery are not the ones making them, nothing new there. Many battery names are made by the same company but that does not mean they are all the same except for the label.
  16. Feb 11, 2023 at 9:13 PM
    MoneyB86
    MoneyB86 Well-Known Member
    Reagan Country, CA
    2019 MGM Tacoma Double Cab
    AGM from Walmart. Cheapest AGM and comes with a 4 year warranty
    D.A.S. Taco and Tbar71[OP] like this.
  17. Feb 11, 2023 at 9:20 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    My Tacoma OEM battery lasted 3 1/2 years. Honda OEM battery in my Accord lasted over 7 years, second OEM over 5 years. Interstate, Duralast have lasted me 3 1/2 -4 years in Accords (I’ve had 3).
    My choice for replacing my Tacoma battery last month:
    They didn’t have the premium Everstart in stock so as an experiment and for fun I chose this one, reports are it lasts from 6 months to over 4 years. I post this here to trigger the AGM! and “gotta pay as much as you can!” TW members lol.
    Tocamo, Hugh Jashole and Chuy like this.
  18. Feb 12, 2023 at 4:50 AM
    DannyR
    DannyR Well-Known Member
    Daniel
    El Paso, TX
    2020 Quicksand TRD Off Road 4x4 DCSB
    I have always had good experience with optima red or yellow tops as well as odyssey batteries, all 3 are AGM batteries. Haven’t ran them in my Tacoma yet, but I have a lot of experience with them in other vehicles and machinery.
    Corrugated and Mas Olas like this.
  19. Feb 12, 2023 at 5:07 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    wi_taco and Corrugated like this.
  20. Feb 12, 2023 at 5:27 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    What did you have to do, if any, to get it to fit? Just the tie-downs? Thanks!
