Best replacement headlights. Plug & play plz
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lexi0216, Jun 12, 2023.
  1. Jun 12, 2023 at 7:57 AM
    Lexi0216
    Lexi0216 [OP] Member
    Lexi
    Toyota Tacoma
    Looking to replace my headlight housings on my
    2011 Tacoma but don’t want to do a bunch of wiring, looking for the best plug & play headlights that you’ve used and would buy again. Thank you.
  2. Jun 12, 2023 at 8:15 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Are you looking for the lamp or the whole housing? Regardless OEM. I got OEM takeoff (housing) at a reasonable price. I use Hella lamps. Pure plug and play, whiter light, lasts years.
    AllTacosFloat and Lexi0216[OP] like this.
  3. Jun 12, 2023 at 12:46 PM
    Lexi0216
    Lexi
    Toyota Tacoma
    I’m looking to replace both housings, getting foggy. Just want to find something GOOD that won’t leak in a year.
  4. Jun 12, 2023 at 1:51 PM
    rnish
    Tacoma 2nd gen
    I got a deal on Toyota OEM housings. People do conversions. The bargain aftermarket housings I’ve used leaked in a year or so.
    Lexi0216[QUOTED][OP] likes this.
  5. Jun 12, 2023 at 3:05 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  6. Jun 12, 2023 at 3:17 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Depends what you want out of them, performance or looks. :)
  7. Jun 12, 2023 at 3:47 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    OEM pro housings. Don't waste your money on the chinesium knock offs
    Naveronski and ace96 like this.
  8. Jun 12, 2023 at 4:30 PM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    as others have said...buy once cry once...OEM are the best...
  9. Jun 13, 2023 at 12:11 PM
    Lexi0216
    Lexi
    Toyota Tacoma
    That’s what o keep hearing is that a lot of the after market ones don’t last and leak. I like the look of them but not worth it if they leak
  10. Jun 13, 2023 at 12:14 PM
    MSgt O
    2013 Tacoma
  11. Jun 13, 2023 at 2:19 PM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    If they are just getting foggy, restore them!
    https://www.autoguide.com/top-10-best-headlight-restoration-kits
    I had to do my 2013 as they were also getting foggy. I'll have to do it again this year...
    It's pretty quick and easy with a cordless drill :)
  12. Jun 13, 2023 at 5:17 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note in restoring you remove the UV protection. Most kits come with a UV protectant coating, but it is not permanent. It needs to be reapplied at regular intervals like a wax, which is fine but just needs to be on the maintenance list. When the protection wears off, or if it was never applied, headlights become quickly worse in fogging/hazing than before the restoration. Many companies make headlight UV protection products for the purpose.
    ace96 likes this.
